Small Sun ZY-T43 Review
14 posts / 0 new
robo819
robo819's picture
Last seen: 23 hours 16 min ago
Hi everyone, this is my first BLF review (video). First I would like to thank Karen and Gearbest for providing this light for review. I hope I have covered everything and made a decent review, as I know there are some of you that make excellent reviews on here. There are a few things I didn’t cover in the video, so let me get to those now. First if you are planning on modding, this is not a light to mod, as it does have threads, but is glued together really well and has the side charger and side switch. Second I show the charging port and charger in video but, you can take out batteries as it also has a tailcap and 18650’s that can be charged on a regular charger. The batteries are not top quality but not as bad as a few of them out there (3 out of 4 of them, 1 was a bad cell) Small Sun brand 2400mah. There are also images showing battery orientation inside tube.The last thing is that the slight “ringy” beam in close up of stills does not show in normal use, only when wall hunting.
Video Here:
Link and coupon code here:
http://www.gearbest.com/led-flashlights/pp_170818.html
Coupon Code:coupon:SunZYGB
price:$28.59 (at time of this review)
Manufacturers Listed specs
General Brand: Small Sun Model: ZY-T43 Emitter Type: XM-L T6 Total Emitter: 1 x Cree XML T6 Lumens: 800Lm Switch Location: Side Switch Feature: Lanyard Function: Exploring, Seeking Survival, Camping, Hiking, Walking, Night Riding Battery Type: 18650 Battery Quantity: 2 × 18650 battery (included) Mode: 3 (High > Low > SOS) Rechargeable: Yes Waterproof: IPX-65 Standard Water Resistant
Specification Power Source: Battery Working Voltage: 3.7V Reflector: Aluminum Smooth Reflector Lens: Glass Lens Beam Distance: >500m Flashlight Processing Technology: Aerospace Grade Aluminum Body with Anti Scratching Type III Hard Anodization Body Material: Aerospace-grade Aluminum Alloy Available Light Color: White Available Color: Black
Dimension and Weight Product weight: 0.500 kg Package weight: 0.650 kg Product size (L x W x H ): 17.8 × 6.4 × 6.4 cm / 7.00 × 2.52 × 2.52 inches Package size (L x W x H ): 34 × 15 × 13 cm / 13.36 × 5.90 × 5.11 inches
Package Contents Package Contents: 1 x Small Sun Long Beam Flashlight, 2 × 18650 Battery, 1 x Lanyard, 1 x Car Charger
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 10/22/2015 - 06:12
kronological
kronological's picture
Last seen: 1 year 1 month ago
Nice! Excellent first video review…thanks for posting!
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
Wrathbringer27
Wrathbringer27's picture
Last seen: 6 hours 17 min ago
Nic review! Liked the country song btw! Big Smile
Words can be broken,
so can bones.
Rusty Joe
Rusty Joe's picture
Thanks for this. I enjoy your reviews.
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
gamezawy
gamezawy's picture
Last seen: 3 weeks 6 days ago
Thank you for the great review, i was wondering about this light from along time
Rolz
Last seen: 14 hours 30 min ago
Thanks for the review. I was pleased that I watched it as it gives a good understanding of the performance of the torch outdoros after a review of the internals. The plastic reflector is a bit of a dissapointment as otherwise it looks a good buy.
robo819
robo819's picture
Thanks for the replies guys. I was glad to do the review and I am hoping to have the opportunity to do more in the future. I will try to get better with each one as I am still a newbie at videos and flashlight both for the most part
DarkSide
DarkSide's picture
Last seen: 1 year 3 months ago
How about a picture of the actual flashlight?
robo819
robo819's picture
There are several pics of the light in the video, 1 of flashlight in the box, one of it taken apart, one of the head and switch, one of the body, one of the light beside the accessories, and one of the charging port that I can think of.
blueb8llz
Last seen: 1 hour 48 min ago
How does the ui work?
It sounds like I have to press a full click each time to change modes? And have to cycle through all modes to turn off.
So it’s not half presses right?
And silly question, does the light run the cells in parellel or series?
robo819
robo819's picture
The cells are in parallel.
To be honest I didn’t even try half press but I am almost certain with the side switch it is full click to change modes.
Light can be turned off in any mode though.
Hi/Lo/Strobe is the order of the UI.
And my brother has the light right now so it will probably be 7 to 10 days before I can tell you about half press to change modes for sure.
Just called him…NO half presses and yes you do have to cycle through.
blueb8llz
hmm, if the light can be turned off in any mode, then it seems like it would be half presses to change modes.
otherwise, if it was a full click to change modes, then how will the light turn off with a full click?
unless you have to hold the switch to turn off? is this an electronic switch?
but in your video, it looks and sounds as if you were cycling through all modes with a full click and then it turned off after strobe mode.
this is the only thing holding me off from buying one or two of these lights right now.
i dont want to have to hold the switch down to turn on/off light.
to turn off light is a simple press right, no holding down for half a second or anything like that?
southland
southland's picture
Last seen: 2 days 1 hour ago
Good review Robo, thanks. Wrathbringer, just so you know, that song is Southern Rock.
bibihang
bibihang's picture
Last seen: 1 week 1 day ago
Thank you for the nice review. Beer
