has anyone modded the TF X8>??
Yes....
original driver:
modded driver:
what driver that you are using currently??
so after replacing the driver, what's the current amps on high mode??
3,5A, because of 10x7135:
1 x 7135 = 350mA
10 x 7135 = 350x10=3,5A
With orig. Driver i measure 3,1A (2x18650).
I chanched the driver, because i will only use 1x18650 and 3-Mode(Hi,Mid,Low). ;)
are you sure the original manufacture driver is 3.1A with 2*18650?
Yes, i measure 3,14A with very full charged 2x18650.
(measure is 1,57A with 2 x 18650, that means 1,57 x 2 = 3,14A)
Definitely over 3A. ;)
i thoought it is regulated at 3a??
3A, or 3,1A....near the same, i would say, it´s regulated. ;)
p.s. (measure is 1,57A with 2 x 18650, that means 1,57 x 2 = 3,14A)
so i would conclude that this x8 driver has been manufactured according to the cree max Amps for xml t6 (max 3a), am i right?
anyway, do you see so much different on the output after replacing the driver?
the 7135 driver, normally has 2,8A (8x7135), meanwhile i use 11x7135(3,9A) and the different you can see by eyes.
i have a Fandyfire STL-V6, the original had 2,74A, measured with 38500lux
chanched only the driver to 3,9A, measured = 45000lux
the different of 3,1A or 3,5A i think, you can´t really notice....maybe a little bit.
p.s. you should take a look on the UCL, or UCLp Lens (41,8mm) on flashlightlens.com ;)
ever owned a HID?
No....i like LED lights with only 1x18650 ;)
so in your opinion, should i mods my x8 driver as well? or just keep it as original??
isnt that by modding its driver, it will actually shorten the bulb life?
It will shorted the led's life for sure. Which is 50.000 to 70% of initial output.
If you'll use your flashlight for 2 hours every day the LED life's gonna drop 720 Hours.
In 3 years you will surely buy the NEW technology which will be avaialable a that point. The Led will not even run for 5000 hours by that time, more like 2500 hours .
do you know where to get the replacement for x8 reflector and also accessories for x8 such as aspherical lens, tail cap,??
Harry
What other flashlights do you have?
well currently only x8...just got it a week ago.. but kinda feel disappoint after reading the x9 review. It seeems that x9 has better throw and the light spot is bigger than x8, also only 1*18650.
now i am thinking to get either one of these flashlights :TF-x9/UF-980L/UF-C8/KD-c8.
Let driver original ;)
Take the X9! ;)
