review: nitecore TM16 - final!
51 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 5 hours 42 min ago
Hello my friends!
banggood sent me a nitecore TM16 - a Tiny Monster!
they also offer it for us to a unbeatable price Wink
you can find the other glossy advertisement pictures in banggoods webshop Wink
the Specifications: (from the shop)
Product name:NITECORE TM16 4x CREE XM-L2 U2 LED Flashlight
Brand:NITECORE
Model:TM16
Emitter BrandCREE
Emitter Type:XM-L2 U2
Material:Aerograde aluminum alloy
Total Emitters:4x
Lumens:4000lm,1780lm,680m,280lm,5lm
Runtime:45min,2h30mim,6h,16hmin,520h
Special modes:Strobe/Location Beacon/SOS
Battery Configurations:4x 18650 batteries (not included)
Peak Beam Intensity:122,500cd
Switch Type:clicky
Switch Location:body side of the flashlight
Impact Resistant1.5 meters
Max Output:4000 lumens
Range:700 meters (max)
Lens:Toughened ultra-clear mineral glass
with anti-reflective coating
Carrying Strap:included
Waterproof:IPX-8 (two meters submersible)
Color:black
Weight:506 g without battery
Size:182mm x 89mm x 53mm(length x head x body diameter)
Features
· Features advanced temperature regulation (ATR) technology
· Dual-switch user interface ensures one-handed easy operation
· Features 5 brightness levels and 3 special modes
· High efficiency circuit board provides max runtime up to 520 hours
· Integrated power indicator light displays remaining battery power
(patented)
· Power indicator’s secondary function displays battery voltage (accurate
to 0.1V)
· Direct access to ultra-low or turbo ensures flexibility and convenience
· Reverse polarity protection prevents damage from incorrectly inserted
batteries
· Stainless steel retaining ring protects the core components from
damage
· Rear tripod connector brings extra funtionality
· Sturdy HAIII military grade hard-anodized
· Tail stand capability
but now to real life!
once again - i got a box
the light is very well secured (as all nitecore lights i got since now) - no need to be afraid along the long way from china
accessories are: a lanyard, 2 O-rings, warranty card and a chinese User manual
well.... what ??
fortunately i found the english manual at the manufacturers homepage
lets look on whats mentioned in the title - the light:
the tailcap has a thread for a tripod, and 3 lanyardholes
and the tailcap is the only part with knurling
the anodisation and letters are very good - i only found one little dent
the head has some medium deep cooling fins
the light has two switches behind a rubber boot
i do not know if its on purpose that its skewed - but i see no disadvantage...
since i write about the switches... the UI is quite good!
  • a ON/OFF switch and a mode switch to toggle the 5 brightness levels from lower to higher modes with last mode memory
  • i love the possibility starting with ultra-low or turbo when holding the ON/OFF or mode button from OFF regardless the memorized mode! (most nitecore lights work that way!)
  • to enter the disco modes hold the mode button when the light is ON to activate Strobe - another hold toggles beacon and SOS (hmmm - bacon)
additional features:
  • "standby" means that the power switch flashes blue once every 3 seconds (can be deactivated)
  • "lockout" means that a (accidentially) press of a switch does not turn on the light (which happened some times while my test)
  • klicking the mode button in OFF gives 1 to 3 blue flashes - 1 means batteries are empty, 2 is below 50% and 3 above 50% Power
  • when the tailcap (and electrical connection on the batteries) is closed the blue light flashes according to the cell voltage. at 4.2 Volt the blue power indicator will blink 4 times, followed by a one second pause and another 2 blinks for example
but back to the appearance...
tailstand?
[x] check!
very clear AR-coated Lens?
[x] check!
the bright side:
the LEDs are not 100% centered
 but i do not think thats a big problem here since the beam profile is not exactly circular Wink
size comparison:
opening the battery tube shows a nicely lubes square cut thread
the tailcap has a PCB which closes the connection of the 4 batteries (i am quite sure in series...)
well made with doubled springs to lower the resistance (the bolts are just for correct positioning)
hint: the PCB is not screwed, but glued...
in the battery tube are stickers which show the polarity for each slot
BUT it may lead to confusion since (R)CR123 are not allowed!
at the driver side you see the double springs and a black plastic? foil which works as reverse polarity protection.
this prevents flat top batteries from working!
thats why i had to apply a solder blob on my Sony VTs
short batteries are a problem at all - i had to use 1mm magnets at the negative side of the cells to ensure propper function when shaking the light hard...
my Panasonic NCR18650B (near 70mm long) work perfect
at the End of part 1 i have a small gif to show mode spacing and beam profile
(ISO 200 / F5 / 1/4sec)
in the second part of the review i will try to open the light as far as possible to see whats inside and at least get rid of the reverse polarity protection thingie to make it work with all my cells!
i also try to find out how the Advanced temperature regulation (ATR) technology works and how different cells perform.
and i will have some tables...
stay tuned!
in the meanwhile you could send me a PM if you are interested in a really good offer for that light Wink
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Edited by: M4D M4X on 09/08/2015 - 15:35
M4D M4X
M4D M4X's picture
today i have some insights of that great light...
remember i did not like the reverse polarity protection?
(in fact it drove me crazy so it was the important thing i was doing after i did not manage to open the light)
it was a hard fight...
but i won (using a heatgun to soften the plastic did the job)
the contact board (i was right guessing a 4S arrangement of the cells)
despite mild force only little damage was done
now every cell has contact - but they sit a bit deep now (and some damage was done on this side too)
using rubberised gloves the bezel opened up at the end
the lens is hold/sealed within a C-shaped "O-ring"
the reflector is made of plastic...
the bright part!
the solder needed a lot of heat (i used flux core solder to alloy it)
the PTC (NTC?)
the MCPCB is made from alluminium and meassures 40x40x2 mm - it is NOT DTP (direct thermal path)
since i was not pleased with the centering i filed a bit off the stands (might be neccessary to work also on the MCPCB - i will see when i reassemble the light)
using a lot elbowgrease and a heatgun took me here (finally)
the base where the MCPCB sits is 3 mm thick
the electronics assembly is secured with this ring - it should be possible to tighten it farther down and compensate the missing reverse polatity pcastic
down there sits the contact board
i was "complaining" about the tilted switch... it can be mounted nicer Wink
the switch PCB
whis is soldered to the driver
after i desolderd that i got the whole assembly out of the tube...
the contact board in detail
the wires connection to the drivers backside (which actually facing forward when mounted)
question: what is LA----~~LB for?
another angle shows contacs for programming the MCU, the thermistor wires and switchboard
finally: the populated side of the driver:
R205 seems to be the sense resistor... Wink
i did not manage to get useful results on that ATR feature - it gets hot on high (50°C) for sure !
my observations lead me to the conclusion that the voltage on turbo is influencing the brigthness A LOT!
the different cells perform very different (might be the voltage sag?)
some raw numb3rs:
BatteryultraLOWLOWMIDHIGHTURBOTURBO
prot. Panasonic NCR18650B0.004 A0.045 A0.320 A0.99 A2.23 A
Sony US18650VT (pulls)    2,6 A
prot. Panasonic NCR18650B3 Lm377 Lm867 Lm2330 Lm4050 Lm12760 Lx@3m / 114.84 kLx
Sony US18650VT (pulls)3 Lm374 Lm859 Lm2325 Lm4350 Lm13230 Lx@3m / 119.07 kLx
LG 18650HE23 Lm375 Lm857 Lm2305 Lm4600 Lm13860 Lx@3m / 124.74 kLx
ICR18650-22P (pulls)    4450 Lm
acebeam ARC18650NP-260A    4200 Lm
acebeam ARC18650H-250A    4850 Lm15080 Lx@3m / 135.72 kLx
for comparisonM43 XP-G2 ddX60 6500TM06K40M4D
same testrun6400 Lm6900 Lm3800 Lm4300 Lm
things to be updated on this post:
reassemble the light (modify maybe?)
make more meassurements to understand input voltage/Amps to Lumen OTF
take temperature measurements vs time
my conclusion (so far):
+ i like that light!
+ powerfull / useful / good size!
+ nitecore build quality
+ great UI
- can´t use the cells I want (without voiding warranty)
- plastic reflector (can´t say what is not as good as a metal one - but its plastic...)
update 27.7.2015:
i took some time and finished my review
plasitc reflectors leak some light i was told - so i tested that:
here you see the amount of light thats actually going thru and is lost!
ISO200 , 1/2 sec
measured Vf of the 4 LEDs (at the driver)
battery typelowerlowmidhighturbo
old sony VT 4,11V10,2311,111,5712,4413,25
acebeam ARC18650H-250A  4,13V10,2211,111,5612,4613,78
Pana NCR18650B prot. 4.14V    13,18
acebeam ARC18650NP-260A prot. 4,12V10,2311,111,5812,4713,34
acebeam ARC18650NP-260A prot. 4,12V0,003A0,175A0,414A1,22A2,43A
i think: the less the voltage of the cells drops under load, the higher is the Vf delivered to the LEDs on turbo - all other modes are well regulated
the numbers fit to my lumens i measured above....
next test:
i made a run with the floating LED-board - NO cooling NO heatsink!!!
after ~50 secs on high it had ~100°C and stepped down a lot (the thermistor works)
last test:
setup:
i took amperes between driver and MCPCB and (used x10 in the graph for a better display)
temperature was measured between 2 LEDs on a blackened field with the IR-thermometer ( swinging a bit and took highest reading)
"input"voltage from the 4S cells - because i think that voltage provided under load mostly affects what comes OTF
the fan of the pure copper heatsink ran on 12V
cells used: acebeam ARC18650NP-260A prot. with 4,05V at start without load
minute012345678910111213141516171819202122232425262728293031
                FAN OFF       stepdownturbo + FAN ON      Light OFF
emitter ampere2,22,152,1252,0952,0652,035
2,005
1,9751,951,921,891,861,8351,8151,7851,7621,7771,7721,7731,7721,7691,761,7551,751,181,71,641,581,541,5051,480
temperature MCPCB °C202525252626,5272727,5282828,5282828,5283133,53637,54041,54344,547403533313028,525
voltage 4S under load15,0514,9214,8114,7314,6114,5514,5214,4914,4614,4214,3914,3814,3514,3214,2814,2614,2214,2214,1514,1114,0714,0314,0113,9814,2613,9513,9513,9513,9513,9413,9414,65
calculated cell voltage3,763,733,703,683,653,643,633,623,623,613,603,603,593,583,573,573,563,563,543,533,523,513,503,503,573,493,493,493,493,493,493,66
as graph:
 what I think to see:
  • with good cooling there is no stepdown the first 15 minutes - output Amps ran slowly down according to dropping input voltage
  • even with the fan switched off and heating up the Amps ran down according to dropping input voltage until the stepdown (to high) happened
  • after FAN ON and step back to turbo same picture...
jfong
Last seen: 1 year 1 month ago
Looking forward to more info!
blueb8llz
Last seen: 9 hours 14 min ago
thanks for the review.
quick questions….is there a step down from turbo? if so, how long?
to turn on and off light, does it require holding down the switch? or is it a simple quick click?
lastly, if possible, i would like to see a beam shot comparision with your k40m please.
M4D M4X
M4D M4X's picture
blueb8llz wrote:
thanks for the review. quick questions….is there a step down from turbo? if so, how long? to turn on and off light, does it require holding down the switch? or is it a simple quick click? lastly, if possible, i would like to see a beam shot comparision with your k40m please.
stepdown: not measured yet
on/off: single short click to memory (long for ultralow or turbo from off)
beamshots will follow soon
keltex78
keltex78's picture
How about an Old Lumens style post-review giveaway? Cash Cash Cash Cash Cash Cash Cash Cash Cash Cash Cash Cash Cash
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
M4D M4X
M4D M4X's picture
i did that already… (with a JM35, a nitecore sens AA and a kindire K1200S)
but i like this one too much Silly
will34
will34's picture
Last seen: 1 week 5 days ago
Interesting, looks like the leds are all mounted on the same mcpcb, it might make modding a bit difficult if the reflector has a flat base.
I’ve been looking for a multi led thrower to mod with XPL HI, and this could be it. Will wait for part II of your review
unknown00101
I recieved a my TM16 (DHL baby!). I too really like it. I took it out for some night fishing, during which I intended to get some beamshots, but the fish were unrelenting. In the few breaks in action we had I pulled it out and delivered some daylight to the trusses and shoreline 200yds away even through the dense air. I also finally got to test out my UF-1504 (sliced dome xpg2 3A) which was a bit disapointing comparatively. Great for cruising and spotting buoys with very little spill hitting the boat, but not enough light to illuminate a large spot.
Anyway, I think I have a new best flashlight in my collection. Smile
M4D M4X
M4D M4X's picture
if the baby ever again goes to sleep i can update post 1 Wink
tiredashell
i also made a beamshotsession (470m and 200m) with 14 lights – also in progress to resize and make a post worth reading…
xed888
Were you able to confirm the 4000 lumens for the TM16?
M4D M4X
M4D M4X's picture
see Post#1 Wink
xed888
M4D M4X wrote:
see Post#1 Wink
Thanks Max. WIll wait for your regulation results before deciding on one Silly
What does not having DTP mean for the TM16 then? Can someone explain that?
DanielM
DanielM's picture
If there is one word to describe Nitecore flashlights it’s THIN.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
MRsDNF
MRsDNF's picture
Last seen: 1 day 8 hours ago
Nice comprehensive strip down. The review needs an X rating.Smile
FlashLion
FlashLion's picture
Last seen: 2 years 7 months ago
Thanks for the great review! Great disassembling!
Definitely great flashlight. Just wish Nitecore to not take so much care for the weight of their products,which is important for the regular user,but possibly limiting the performance.
Trevi_lux
Trevi_lux's picture
Last seen: 8 months 1 week ago
Awesome job !!! Thanks for the disassembling. :bigsmile:
thanks…thanks….and thanks..
gaston01
gaston01's picture
Excellent review! Many thanks Smile
I stand waiting with the step – down Wink
Sorry for my bad English…
TheBo
TheBo's picture
tiredashell
Many thanks for that…
Did you by chance had a k60 in that 14’s lights list?
Rufusbduck wrote:
Getting discouraged is normal but doesn't finish the job.
M4D M4X
M4D M4X's picture
unfortunately not Sad
not easy to get one for cheap …
TheBo
TheBo's picture
Yeah I know…
k60 vs tm16 could be interesting maybe also a comparison with a sd75… I’m undecided for the tm16… Since the k60 claims more lumen (and I suspect they could go all with the spill since throw it’s similar) which is not a bad thing…
The driver efficiency seems better on k60 (if we just take the manufacturer specs) the low is lower, the max is higher… So it seems a better light in almost every situation… BUT acebeam reputation is… Hum… Don’t know… And I do not like their MAP attitude… So… Just taking into account the GB price and the unavailability of an equivalent good discount on k60….
Very undecided
will34
will34's picture
Thanks for the disassembly!!
If the TM16 does 135kcd stock imagine what 4x XP-L HI can do, 250kcd maybe?
It seem to fit 4× 16mm mcpcb in there with minor modifications, but I wonder how good does the plastic reflector perform, sometimes they leak light causing low efficiency.
M4D M4X
M4D M4X's picture
hey guys!
i am very busy these days and i struggle to set up a testscenario to get useable data…
so far i found out that the all modes exept turbo are very well regulated and showthe same output.
on turbo it depends on the voltage sag how it performs…
i think i have to skip lumens (maybe only ceiling bounce) to be able to measure emitter amps, mcpcb temparature and battery voltages over time.
but that needs a bit more time…
zeremefico
zeremefico's picture
Last seen: 10 hours 26 min ago
Great stuff!
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
M4D M4X
M4D M4X's picture
updated post #1
tempo
Last seen: 4 hours 37 min ago
very detailed technical informative review, excellent work there!!
Rolz
Last seen: 8 hours 11 min ago
Really good breakdown of the TM16. This gives a very good insight into the working of the torch. Thanks for working through the task and posting the details.
Werner
Werner's picture
Nice review, i like to See all the innards.
How did you find out that it is no dtp? Did you desolder one of the leds or could you measure the centerpad on the solderblob?
M4D M4X
M4D M4X's picture
there have been 2 blobs and i also scratched the mask beside a LED with a skalpel….no cuntinuity
will34
will34's picture
Plastic reflectors are a bit disappointing for such a nice light, even if it’s 5% that’s 200 lumens lost!
I’ve looking to mod a monster light like this or the TK75, which also has a plastic reflector.
Old Mate
Last seen: 3 weeks 5 days ago
Thanks M4D M4X -for such a comprehensive review. I found the reflector issue and the output difference[cell draw and current] while using a different cells very interesting. The tear down shots are appreciated as provides and insight for anyone considering modding or upgrading, great pics great review.
Old Mate
