Test/Review of NiZn AA 2800mWh (Green)
Official specifications:
  • Type: nickel-zinc battery
  • Capacity: 2800mWh
  • Weight: ~ 24.5g
  • Size (D x H): 14.25 x 50mm
I found these on ebay at dealer directtouch
Maximum temperature raise at different discharge currents: 1A:+3,5°C, 2A:+5,4°C, 3A:+5,5°C, 5A:+1,8°C
This rechargeable chemistry has higher voltage than NiMH and are supposed to be the superior replacement for alkaline in some applications. . In practical usage the cells has a rather low lifetime, probably because they are over discharged when used as replacement for alkaline or NiMH cells.
The official capacity is not specified in mAh, but instead energy is specified in Wh, probably to hide the fact that they has less capacity than NiMH batteries.
The two cells has different capacity, not very practical if they are supposed to replace a couple of alkalines and must not be fully discharged.
The energy is significantly below the rated value.
Conclusion
The cells might be useful for some special applications, but as replacement for alkaline or NiMH they are not very good. The higher voltage might damage equipment and the cells will be damaged when discharged to much.
The different in capacity between the two cell I have tested is not very good.
I do not believe the cells are useable as replacent for alkaline or NiMH.
Notes and links
I have also tested PowerGenix AA NiZn cells.
A better rechargeable replacement for alkaline might be Kentli
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
I’m going to try some of these in some alarm remotes I have that are very low drain and have a built in voltage cut off of 1.34v (which should prevent them from over discharging)
My “strategy” is going to be to charge them only to 1.7v
So they will always be in the range of 1.7v to 1.34v
Maybe they will do well under those circumstances.
