Attiny25/45/85 FW Development Thread
1911 posts / 0 new
ImA4Wheelr
Last seen: 11 hours 3 min ago
Thanks Tom E.  I'm going to try to install and try out this new version today in a SRK with 4 219C's today.  So it should be pretty high current.
Do you have a version of this FW that is small enough to port back to the 13a?  I have quit a few 13a's with momentary switches that I would like to update.
Tom E
Tom E's picture
Last seen: 10 min 45 sec ago
Uhhh - was think'n bout it, but right now this is 3500 bytes (3.5KB), and only 1000 bytes available on a 13A. I've been doing the bent pin thing on a 85 and swapping out 13A's. Did a few, so far so good, but almost all needed a little touch of the iron on at least 1 pin - it's not working for all 8 pins every time for me, but little careful TLC gets it fixed up quick.
I believe the e-switch support alone required more code space that a power switch driver, so can't do what TK did for sure, but even hers requires a Tiny25 (2KB).
Didn't do the same "fix" yet either for my 13A e-switch firmware yet. Not sure what you are look'n for - this full functionality or just this bug fix... For the full functionality, I'm even way past the capacity of a Tiny25 (at 2KB).
TK can, and does, compact the code down more than I do. I don't have the patience to do that level of bit tweaking that Dr Jones is so famous for - I want functionality and usability over size.
ImA4Wheelr
Sorry, meant, do you have an older version that you feel should work and would still fit in the 13a.  I totally understand the latest has many new features that just won't fit.
Tom E
Tom E's picture
Ohh- sure. Haven't touched it in a long time, but it works well - but would benefit from the same exact bug fix. Not all drivers had the flicker though.
This link google drive folder has the version for FET+1, and the older version with a single output - both 13A versions.
Update: in my test light, Supfire M2-Z, I've been using the wight 22mm FET+1 board with an 85. I experienced flaky operation on occasion all along I believe - blinks, sometimes it even locks up. I added a 0.1 uF cap on the zener pad and seems like the flaky intermittent problems went away. So, I left the stock 10 uF on the C1 pad. I believe this light and the SupFire M6 were the only two I've used this driver board on, at least with 85's, and both had intermittent problems in the stock C1 setup - caps on the zener pad seem to solve it.
ImA4Wheelr
Thanks.  I think you had a solid 85 version that you published that was still under (or very close) to 1K.  Not sure what all you had done to it.  I'll try to port it back and fix the issue you mentioned above.  If that doesn't work I can go to the 13a version you mention above.
Regarding the newest FW you released: I didn't finish my SRK to test your new FW last night.  I should finish it today and then I will report back.
Tom E
Tom E's picture
I built up this light: tinywind ultrafire UF-T18, with a 219C on a 16mm Noctigon, using Richard's driver board: https://oshpark.com/shared_projects/acdEm3rR he posted here in post #163. It works great on a laptop pull cell @3.2V, works intermittently on a Panasonic 2800 mAh @4.15v, and doesn't work well at all on a SANYO GA @4.2v.
Quick review of UF-T18: nice compact 18650 e-switch tube light, it's a real UltraFire (driver is branded UltraFire), real SS retaining ring in the bezel, easy thread lock-out on the tailcap, body mounted side switch with 3 wires: grnd, switch, and bonus: RED LED in the switch! But the side switch is not so good - lot of force needed for the thumb, works ok on the tip of the index, or can use your finger nail, but don't think the rubber would last long on finger nail use. Bottom line: the switch is a killer disappointment without a fix, but I am not a side switch modder...
The problems appear to be the same issue I had in the other lights with the 22mm wight FET+1 driver, but now I don't have any zener pad available after the diode. I'm sure the problems have something to do with the low Vf, high amps of the 219C (5000K from Richard). I'll try piggybacking a 0.1 uF on the C1 cap, and see how it works. If it fixes the problem well, this may be the ultimate solution going forward for all 25/45/85 builds.
Richard's board design is pretty good, but using a SIR800DP, there is very little pad space to solder on the LED- wire to. A 22 AWG wire barely has enough to grab on to. I don't think a 20 or 18 AWG wire would be an option - no space, too tight against the resistors. I also have all 3 sizes of PD's DoubelDown drivers (http://budgetlightforum.com/node/41546, also post #202 here) - the LED- pad looks better, but haven't tried a board out yet.
Update: the piggyback 0.1 uF helped - tried a Pana PF and seems to work 100% where before it was failing, but on a SANYO GA, strobes don't work, unexpected blinks, etc. - same old problems. Maybe try another stacked 1 uF so I'd have a 10, 1 and 0.1 in the stack?
Boy, dunno... This light is a PIA to be experimenting on - desoldering wires from a sunken LED, 3 pt. soldering of the driver to the brass pill edges.. yuk Frown. No time now - gotta assemble some furniture - my wife went shopping at IKEA... Frown
DEL
DEL's picture
Last seen: 2 years 1 month ago
Tom E wrote:
Update: the piggyback 0.1 uF helped – tried a Pana PF and seems to work 100% where before it was failing, but on a SANYO GA, strobes don’t work, unexpected blinks, etc. – same old problems. Maybe try another stacked 1 uF so I’d have a 10, 1 and 0.1 in the stack?
I am a little surprised that the 0.1 uF made any difference. It really should be right up against the MCU to fulfill its purpose. It is standard practice to have these 0.1 uF decoupling capacitors VERY close to the MCU. We are fortunate not to have more issues with the layout of typical drivers.
In this case best I can recommend is to have a 0.1 uF straddle the MCU. Glue it diagonally to the top of the MCU and run leads/jumpers directly to pins 4 and 8. Pain in the butt for programming though.
Next best option is leave out D1, at the risk of frying the MCU when reversing the cell by accident. Re-use its pads to fit a bigger capacitor.
Did you try running at 4 MHz? That should also give you more room before brownout.
Tom E
Tom E's picture
Sorry, really dunno the specifics or converting to 4 Mhz - suspect there'd be some testing. I'm gonna try the piggyback 0.1 cap now. Dunno what glue to use (?) - might just have to suspend it. Thought super glues were NG for this stuff - not sure... Again, I'm not so used to this experimentation and not set up well for it.
ImA4Wheelr
Sorry I didn't get any testing in yet.  This damn Kung is kicking my arse.  One problem after another every time I work on it.
Tom E
Tom E's picture
No prob - ImA4Wheelr
DEL - that dang little cap across the MCU worked !! SmileSmile At least so far. Before on a SANYO GA strobe didn't work at all, and now it's working flawlessly so far. Accept the dang thing gets so hot so quick. I'm using 22 AWG LED wires, added spring bypass's on the tail spring and in a tiny driver spring I added - original driver had no spring at all.
A pic of the UF-T18:
Here's the driver in it's final/current version:
Here's the driver spring w/bypass (used a 26 mm wire in there - very short):
At the tail, I got 6.3A with the GA cell - crazy #'s, but with the 219C 5000K, I'm getting about 1,000 lumens out.
Note: Both added caps above are 0.1's, but, one is 50v rated (square on the MCU), and the thinner one must be a lower V rating, but not sure what it is.
Tom E
Tom E's picture
I'm thinking we need a board design with a 0806 pad for a cap that gets + after the diode, close to the Vcc MCU pin #8, and either goes to a strong grnd, or gets to a ground close to the grnd MCU pin #4.
I dunno how it would fit on a 17mm board with the wide pads for a 45/85, but, thinking this will be the ultimate solution - using a 0.1 uF cap, or thereabouts.
I also would love to have pin #3, the spare I/O pin wired to a pad for a secondary switch, or ON/OFF LED output. I think the MCU pin #3 can work for that.
Any takers? PD68? RMM? pyro1son? Smile
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 57 min ago
FWIW, I finally merged in Tom E’s eswBrOutCfg project.
Also, I’m still eager to hear about further developments on the issues you see on strobes and other sudden flashes. The cap over the MCU is interesting; I wonder if it could be placed somewhere directly on the board or if perhaps some other solution might work better.
Mike C
Mike C's picture
Last seen: 1 day 4 hours ago
Tom E wrote:
I’m thinking we need a board design with a 0806 pad for a cap that gets + after the diode, close to the Vcc MCU pin #8, and either goes to a strong grnd, or gets to a ground close to the grnd MCU pin #4.
Now I’m really confused. I think I’ve dropped the ball on this topic…
Wasn’t the conclusion that the cap should get + before the diode? Or are you considering one before and another after? Don’t most of the drivers have the cap + after the diode?
pyro1son
pyro1son's picture
I dunno how it would fit on a 17mm board with the wide pads for a 45/85, but, thinking this will be the ultimate solution – using a 0.1 uF cap, or thereabouts.
Leave it with me Wink
10uf and 1uf caps?
Pastebin                                      &nbs
ImA4Wheelr
If space was an issue, the board could use the SSU footprint and the cap be placed under the MCU.  It would require the SU MCU package to be used and the pins to be bent in.  When this is done, the MCU sits high enough to clear small 0805 caps underneath.  Bent legs really make program clipping much easier.
Tom E
Tom E's picture
Mike - yes. The large cap should remain before the diode, small cap after, at least that's what it's looking like. Think it gives us best of both. The test light continues to run smoothly. I got 3 lights now that had the problems and fixed now, all slightly different in cap values and placement, but all have a high value and low value cap, and the low value is after the diode.
The last driver, RMM's, is using a 0.1 uF cap, not 1.0 - DEL recommended the 0.1, though might not make much of a difference (I think).
Edit: that may be a viable option bout the bent pins technique. I am a bit concerned though bout the soldering of the MCU pins - certainly not as robust as when they lay flat on the pads, normally. I've done a few though and plan on doing more, and seems to be holding up well, but usually have to touch up a pin or 2 by hand after reflowing.
DEL
DEL's picture
I vote for under the MCU.
It can even be on the opposite side of the PCB, but that would spoil the ‘single-sided’ feature. Vias also decrease decoupling performance somewhat.
The go-to size for local decoupling is 0.1 uF, but I think 1 uF will be fine as well in this case.
The tracks connecting pins 1 and 8 to this cap should be as short as possible and around 50 mils wide.
Atmel’s recommended decoupling is more concerned with noise emission from the MCU, but describes the basics well.
http://www.atmel.com/images/atmel-2521-avr-hardware-design-consideration...
Atmel also recommends a series ferrite bead, this is not that applicable to our single supply MCU’s.
Pages 3 and 4:
Quote:
1.1 Digital Supply
Looking at the datasheet for an Atmel AVR microcontroller, one can be fooled to believe that power supply is not critical. The device has a very wide voltage range, and draws only a few mA supply current. But as with all digital circuits, the supply current is an average value. The current is drawn in very short spikes on the clock edges, and if I/O lines are switching, the spikes will be even higher. The current pulses on the power supply lines can be several hundred mA if all eight I/O lines of an I/O port changes value at the same time. If the I/O lines are not loaded, the pulse will only be a few ns. This kind of current spike cannot be delivered over long power supply lines; the main source is (or should be) the decoupling capacitor.
Figure 1-1 shows an example of insufficient decoupling. The capacitor is placed too far away from the microcontroller, creating a large high current loop. The power and ground planes here are parts of the high current loop. As a result of this, noise is spread more easily to other devices on the board, and radiated emission from the board is increased even further. The whole ground plane will act as an antenna for the noise, instead of only the high current loop. This will be the case if the power and ground pins are connected directly to the planes (typical for hole-mounted components) and the decoupling capacitor is connected the same way. The same is often seen for boards with surface-mount components if the integrated circuits are placed on one side of the board and the decoupling capacitors are placed on the other.
Figure 1-2 shows a better placement of the capacitor. The lines that are part of the high current loop are not part of the power or ground planes. This is important, as the power and ground planes otherwise will spread a lot of noise. Further, the figure shows another improvement of the decoupling. A series ferrite bead is inserted to reduce the switching noise on the power plane. The series resistance of the ferrite bead must of course be low enough to ensure that there will be no significant DC voltage drop.
Generally, the Atmel AVR devices where power and ground lines are placed close together (like the Atmel ATmega8535) will get better decoupling than devices with industry standard pin-out (like the Atmel ATmega8515), where the power and ground pins are placed in opposite corners of the DIP package. This disadvantage can be overcome by using for example a TQFP package, which allows decoupling capacitors to be placed very close to the die. For devices with multiple pairs of power and ground pins, it is essential that every pair of pins get its own decoupling capacitor.
The main supply should also have a tantalum or ceramic capacitor of some μF to stabilize it.
pyro1son
pyro1son's picture
I’ve made a start and added a few extra features very difficult to get everything to fit.
Pin 3 has a 0.8mm via that leads to a 7135 that can be populated if wanted or the via can be used as switch in ect…
The pads to the right of the MCU are the extra cap. It could be moved to the opposite side later.
Don’t think I will be able to get the 85v foot print, but I’ll work on it more later.
Pastebin                                      &nbs
Lilien
Last seen: 1 year 2 weeks ago
Will this still be compatible with chinese backyard production?
Remember the soldering job on the BLF A6 drivers…
Tom E
Tom E's picture
Lilien wrote:
Will this still be _compatible_ with chinese backyard production? Remember the soldering job on the BLF A6 drivers...
DEL could answer this better, but I'd say probably not. This is more or less for us hackers Smile, but, the chinese changed the BLF A6 driver anyway, so they did not 100% duplicate the wight FET+1 driver we started with. The soldering problems were not a design issue - it was a manufacturing/production/QC issue - sloppy and rushed basically, from the looks of it.
I work for a manufacturing company, and we insist our PCB suppliers test the boards before shipped to us. We will design/engineer/produce test fixtures for them to use in order to achieve as close to 0% DOA failure rate as possible. This is one way of doing QC - you want this done as close to the source as possible.
Sorry to say the way our group buys are done here are far from ideal in time and cost. This whole cycle of sample testing in the US is very inefficient and wasteful, but not much other choices unfortunately...
pyro1son
pyro1son's picture
Sorting the layout, but never going to get the SU footprint on with everything else.
Pastebin                                      &nbs
ImA4Wheelr
Let me verify the clearance under an 85 with bent pins tonight.  I'm pretty sure that there is height for a 0805 1uF, but I haven't tested that idea yet.
Tom E
Tom E's picture
Think it will depend on the voltage rating as well - higher the voltage, bigger the part. Think we use 16v rated caps in general. I believe it helps having a higher rating - not sure.
texaspyro
Last seen: 9 months 5 days ago
ImA4Wheelr wrote:
Let me verify the clearance under an 85 with bent pins tonight.  I’m pretty sure that there is height for a 0805 1uF, but I haven’t tested that idea yet.
Cap thickness increases with voltage rating… and manufacturer / dielectric type. One cap might fit and another be way too big.
FmC
FmC's picture
Last seen: 14 hours 36 min ago
texaspyro wrote:
Cap thickness increases with voltage rating... and manufacturer / dielectric type. One cap might fit and another be way too big.
The 0805 1uF Caps I have don't fit under, but the resistors fit under with ease, if that's of any use.
Microa
Last seen: 10 hours 51 min ago
You may consider the 0603 size 1uF Caps. 1uF 50V X7R 0603K is available. Usually, for high frequency noise bypass, 0.1uF is good enough.
ImA4Wheelr
Gap under an 85 with legs pushed in most of the way to touching the chip is .028" to .029" (.72mm).  My 1uF caps in an 0805 package (I believe 16V rated) measure .034" to .035" (.88mm).  So it seems one could get away with a cap under the MCU as solder can quite easily bridge a .006" gap.
Or, the gap could be completely eliminated by slightly straightening the legs.
pyro1son
pyro1son's picture
Both use the ATTiny13 footprint
All on the top
C2 under MCU
Pastebin                                      &nbs
RMM
RMM's picture
Last seen: 1 month 5 days ago
I've been away from this game for far too long; it's time to jump back in again. Cool   I had to force myself away just when things were getting interesting around here so that I could focus on some of my "other work".
The layout on that 85 driver I did really stinks...way too much space around the MCU, but I figured that it would be easy to flash the thing a million times.  It looks like it also needed a bodge capacitor to work right.  I guess I should have labeled it "alpha".
I haven't read through everything here, but a capacitor underneath the MCU sounds like a really bad idea unless you like tedious leg bending and soldering on every driver.  I'm sure we can make it work without resorting to stuff like that.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
Tom E
Tom E's picture
Smile Welcome Back!! You were missed! A scope on the signal lines sure would come in handy for this, I don't have the tools. Had success with the extra caps though, and definitely we've had some great help going on with texaspyro and DEL stepping in.
Not sure if you read it, but I finally got a good fix to the hi->OFF->moon flashing problem -- with that sequence, many times got a quick flash when moon mode starts. It looks like it's 100% resolved now in my latest firmware update - I solved it in code, not hardware, explained above somewhere... I've seen this flashy thing happen on power tail switch's too - wonder if it can be fixed in a similar way. Haven't looked into it yet.
On the high amp problem (caps), I believe TK has been getting the same reports coming in on her 25 based driver. Not sure if she is following this thread though.
Sort of agree - I'm leaning towards the bent pin solution being what we can do with our small runs, hobbyists, etc., but not a solution for large runs going forward.
