Attiny25/45/85 FW Development Thread
1911 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 10 min 17 sec ago
Mike C wrote:
ToyKeeper wrote:
It wouldn’t be a big deal to devote an extra ~500 bytes to PID on a tiny45/85. I wonder how much the response curve can be improved with PID and/or Kalman instead of the “steer really slowly” approach, and if it can anticipate over-heating conditions and start to correct for it in advance.
I do have interest in temperature control. Currently I have temperature calibration and step down, and have a few first tests of temperature controlling. What advantages would a PID controller have? My testing consists of running a “learning” routine where the light heats up, shuts off and does a few things, all timing how the heat behaves in response to turning off and so on, and then storing the values into the EEPROM. My main issue is that with some hosts the difference between doing this routine while holding the light as a lot different than doing it while it is laying on the table. Care to write a few lines on how a PID controller could be used to make all this a little easier?
The advantages, in theory, are a faster response to excess heat without “bouncing” the output. Perhaps it could even detect when the temperature is rapidly approaching the ceiling and start the step-down in advance.
The method I’m using now doesn’t care if the light is being held or not, but it steers slowly enough that it could still overheat before the step-down is low enough to help. The calibration is only one value, the ceiling temperature, and it’s a little tricky due to the lag involved in getting heat from the emitter to the pill to the MCU. It tends to exceed the ceiling for a little while before settling on the maximum usable output for that temperature.
It’d be nice to “look ahead” a little and start the adjustment early, to compensate for lag, and also to allow it to steer faster if it can be done without bouncing.
texaspyro
For those of you intrepid souls that want to wander down the Kalman filter rabbit hole, this is a fairly gentle introduction:
http://academic.csuohio.edu/simond/courses/eec644/kalman.pdf
Mike C
Mike C's picture
Last seen: 23 hours 54 min ago
That’s what my timing is for. As I time how long it takes before the light starts to cool down after the LED is off I can use this time to start lowering output in advance, and also take into consideration the lag time the sensor would expect to see the results of lowering. I’m thinking I’d use the timing when on the table, in still air and in room temperature would be a bench mark as the slowest reaction time to lowering for each host. Reaction time would be faster if holding or mounted on a bike while riding fast. I’m still just testing, but it looks like have come further with it.
So you do your lowering only once the temp reaches the ceiling? Is your lowering visible, like a mode change, or do you slowly fade?
Mike C
Mike C's picture
Mike C wrote:
Tom E wrote:
I use about always the SIR800DP FET, where it’s been reported by others to be prone to the flash problem.
Ahh, OK. That one was harder to get in Europe, I think that’s why I went with the NXP PSMN3R0-30YLD. I’ve not used another one. If I remember correctly the SIR800DP has a diffferent footprint so I wouldn’t be able to test without changing the board.
I wrote it in another thread so I might as well write it here too…
I’ve just made a version of my FET driver (http://budgetlightforum.com/node/43350) with the PowerPAK SO8 footprint and ordered from OSH Park. I can’t get the SIR800DP but I’ll get a couple of SIRA00DPs. I don’t know if they are good for this purpose, but I’ll stick ‘em on and see what happens anyway.
pilotdog68
pilotdog68's picture
FWIW, the SIR800DP has the same footprint, but no exposed tab on the back, so you need the LED- pad extended to solder to
Mike C
Mike C's picture
Nope. I use a VIA for LED- located right beside the FET’s tab. Footprint is not the same as the FET I normally use (NXP PSMN3R0-30YLD with LFPAK56 footprint). It’s about the same size though.
pilotdog68
Are you saying the LFPAK56 is different from the S08? I think most people here use them interchangeably. That’s why I didn’t think they were any different.
Mike C
Mike C's picture
I think they are interchangeably, but they are not the same. The footprint I made for the PSMN3R0-30YLD works perfectly for that FET, but the measurements and space between the pins are not the same as the S08. I know as I’ve just made my own S08 footprint for the SIRA00DP using the datasheet measurements.
pilotdog68
Well sounds like you’ve got a handle on it then Beer
Mike C
Mike C's picture
I’m going to have to take this back… I just put them over each other and they are basically the same. The SIRA00DP has a different looking tab, and the footprint for that could be made differently, but the pins align perfectly with the PSMN3R0-30YLD… So I actually didn’t have to make another footprint. Oh well, what’s done is done.
ToyKeeper
ToyKeeper's picture
Yes, it doesn’t start lowering until it hits the user-configured ceiling.
The lowering goes along a 64-step scale which is approximately visually linear. So, it’s hard to see but not impossible… and the first step is the most visible because I didn’t ramp down the 7135 at the top of the scale… it goes from 100% 7135 + 99% FET to 0% 7135 + 100% FET. The FET by itself is brighter than FET+7135, so the final step gets a visible bump up when using a full high-amp cell. The other levels are hard to see even when staring at it.
I really should ramp down the 7135 in the top few levels instead of going directly from 255 to 0, but I haven’t done it yet.
There’s also a somewhat visible bump at the boundary where it goes from 7135-only to both channels, but it’s not usually very noticeable.
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 1 year 4 months ago
Cooling for linear mode FET drivers:
Is it practical to use metal core printed circuit boards for drivers, as everyone (but the very cheapest) does for the LED? Or is there nowhere to get them made in small numbers? If not that, how about copper braid stuck on the FET with thermal epoxy?
People are already leaving a lot of copper around the FET, but more on other parts of the board might help the heat transfer (as well as helping reduce high frequency spikes).
Someone here has taken measurements and says that potting helps a lot.
More radical approaches are fans and liquid cooling. I once saw a Cray II working. It was in a fish tank full of low viscosity freon. There were streaks of tiny bubbles rising from the components.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
texaspyro
Was Don Ho singing in the background?
https://en.wikipedia.org/wiki/Tiny_Bubbles
Mitko
Mitko's picture
Last seen: 4 months 1 week ago
ToyKeeper
10x for your efforts, i finally got time today to build and that bistro driver of yours- it works great with Attiny25v 10su and ssu
It does have issues( investigating) with both Attiny25 and 85 20su/ssu – it changes modes on a random base,freely Smile
Anyway, can i use your code in order to make a simple hunting bistro firmare? Something like 1-2-3 modes selectable/offtime ofc and a temp.calibration ?
wight
Last seen: 3 weeks 2 days ago
Fritz t. Cat wrote:
Cooling for linear mode FET drivers: Is it practical to use metal core printed circuit boards for drivers, as everyone (but the very cheapest) does for the LED?
[…] high frequency spikes […]
[…] low viscosity freon […]
(a) I don’t think so. Getting the heat away from the FET and into the body of the light is the only practical thing to do. I doubt that non-DTP MCPCBs will perform better here and they are expensive and typically single sided (no spring pad!). DTP is much trickier for soldering and manufacturing AFAIK. (b) The spikes shouldn’t occur in linear mode when implemented decently. © Fluorinert?
After reading both your existing approach and TK’s I think it’s reasonable to say that a properly tuned PID should be much better than either. That said, PID tuning escapes many people. It’s escaped me so far, but I haven’t made a serious try at it. There should be plenty of demos showing PID responding to interesting situations.
Sharpie wrote:
If you look at the datasheet you’ll see that they are supposed to be interchangeable with standard SO8 (leaded) footprint. But for best thermal path, the drain pads should be extended underneath so the slug on the bottom can be reflow soldered. I think Wight is already doing this on his latest layouts.
Is also quite a large component for leadless SMD, so soldering to the pad on the bottom might help releive any stress on the solder joints due to thermal expansion/contraction. And of course, you can’t just bend a pin up to e.g. add a gate resistor etc.
This is true, apparently the intention was to make high-power parts footprint-compatible with the pre-existing low-power MOSFETs already being packaged in SO8.
I’ve been providing the thermal pad since the first FET driver I showed off. (it also provided a DPAK footprint in the same place! [Certainly this would make locating the Power-SO8 FET during soldering difficult.]) Smile
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Tom E
Tom E's picture
Last seen: 7 sec ago
Latest Narsil (requires an ATtiny85 with FET+1 driver) uploaded with a few new features:
  • expanded modes sets from 8 to 12, new mode set supports up to 8 mode levels (7 + moon)
  • An Indicator LED (SMD LED) is supported as a locator LED and low voltage indicator
  • Moonlight mode can be optionally added (enable/disable), and the moon output level custom set
Here's the summary of configuration settings:
Configuration UI Operation
The main Configuration UI settings is activated from OFF or ON by click& hold for at least 2.5 seconds. The light will display a strobe, but if you continue to hold, strobe will stop and the light will blink 2 times quickly, and once slowly to indicate the Configuration UI mode is active. There are 5 settings, listed in the table below. You can change or leave any of these settings – there’s no need to set each one. Clicks choose the value for each setting, and each click will blink the light to acknowledge the click. If no clicks are entered in 4 seconds, the light jumps to the next configuration setting indicated by 2 quick blinks and slow quicks of the number for what setting it is (ex: 3 slow blinks means the 3rd setting). You can bypass the timeout by doing a click&hold to skip to the next setting. If you continue to hold it, it will exit configuration UI settings mode altogether, indicated by 4 quick blinks.
Configuration Settings
Setting #
Function
Clicks
Defaults
1
Choose Mode Set
1-12 (1-7 is # of modes) – see Mode Sets
4
2
Moon Mode
1=disable, 2=enable
2
3
Mode ordering
1= sets lo->hi, 2=sets hi->lo
1
4
Mode Memory
1=disable, 2=enable
1
5
Turbo Timeout
1=disable, 2=30 secs, 3=60 secs, 4=90 secs, 5=2 mins, 6=3 mins, 7=5 mins, 8=10 mins
1
Mode Sets
Mode Set Order
Mode Count
Mode Percentages
Notes
1
1
full only
(full is always max FET, no 7135)
2
2
10-full
max 7135, max FET
3
3
5-35-full
5=1/2 7135, 35=mixed
4
4
2-10-40-full
10=max 7135, 40=mixed
5
5
2-5-10-40-full
6
6
TK BLF A6 7 mode
6 well evenly spread
7
7
1-2.5-6-10-35-65-max
10=max 7135, 35=mixed
8
3
2-20-full
2=1/5 7135, 20=mixed
9
3
2-40-full
2=1/5 7135, 40=mixed
10
3
10-35-full
11
3
10-50-full
10=max 7135, 50=mixed
12
4
TK BLF A6 4 mode
4 well evenly spread
Advanced Configuration UI Operation
The Advanced Configuration UI settings is activated from Battery Check mode by doing a click& hold for at least 1.1 seconds. The battery voltage reading will be interrupted, then the light will blink 2 times quickly, and once slowly to indicate the Adv. Configuration UI mode is active. There are 5 settings summarized below.
Advanced Configuration Settings
Setting #
Function
Clicks
Defaults
1
Locator LED feature
1=disable, 2=enable
1
2
Set Moonlight Level
1 - 7 (PWM value)
3
4
Battery level Indicator LED Only
1=disable, 2=enable
1
3
Indicator LED Enable
1=disable, 2=enable
2
5
Power switch modes w/mem
1=disable, 2=enable
1
Full Atmel Studio project source code, ZIP'ed, manual in docx and PDF format, and .BAT files for downloading and setting fuses posted on a google share drive here: google drive - Narsil share
Some mods running Narsil w/Indicator LED support (BLF SD10, UF-T18, ZY-T11 clone, SWM C20C):
ToyKeeper
ToyKeeper's picture
You can do anything the included GPLv3 license allows. Mostly, it means “pretty much anything, as long as you share the code”.
ToyKeeper
ToyKeeper's picture
Awesome. It’s now (finally) merged into the repository.
Mitko
Mitko's picture
U 2 contribute alot here, admiration Star
FmC
FmC's picture
Last seen: 16 min 35 sec ago
Thanks TomE Beer
Tom E
Tom E's picture
Thanks All! Notice the brightness of those LEDs? Wayy too low resistance used. On the UF-T18 there was a resistor already mounted on the switch PCB, but must be low. Probably only used for blinking in stock driver - looks ok when blinked, super bright when on steady.
Actually the UF-T18's switch LED is the ultimate low moon mode. It actually throws a pretty good amt of light (undecided).
pilotdog68
So Tom what’s the difference between indicator LED and locator LED?
Tom E
Tom E's picture
Ok – I’m calling the physical SMD LED wired to pin #3 the “Indicator LED”, but the “locator LED” is the functionality of it being ON when the main LED is OFF. Thought this might be confusing, so no prob, ask away.
Mike C
Mike C's picture
Thanks. Another thing to put on the ever growing pile of things to look at. I’ll keep it in mind when I return to temp control coding.
ToyKeeper
ToyKeeper's picture
I took only a brief look at PID before deciding on something simpler. The atmel example code I found for it compiled to like 5500 bytes and the MCU only had 2048, so I put it aside and tried to come up with something tiny instead. However, I hear PID can be implemented in far less space than what I found…
Mike C
Mike C's picture
wight linked to one that was supposed to compile in 534 bytes. I’ll start there. Space is certainly an issue, I don’t know how much I will be able to afford. My “development” firmware is getting full, but some of that stuff can be stripped out for “user” firmware.
DavidEF
DavidEF's picture
Last seen: 3 days 22 hours ago
I was just looking at Mountain Electronics and I saw that the DRJones H17F driver with lucidrv2 uses PID. And from reading about his UI, it seems fairly rich as well. That driver is using ATtiny25.
- The YKK Philosophy
Halo...
Halo...'s picture
Last seen: 3 years 7 months ago
DrJones is making some money off his drivers though, so I presume he justify putting more than just free time into them.
DavidEF
DavidEF's picture
Yeah, I’m sure he has spent loads of time on his drivers. I was only remarking that PID is definitely possible in a small(ish) space. Hoping to encourage some of these talented people working on drivers and firmware, confirming that it can be done. It wasn’t long ago that TK didn’t know it could be.
Tom E
Tom E's picture
Doc Jones is famous for getting the most of every single bit in every single byte. He’s probably got the world’s most efficient PID algorithm in terms of memory usage. Also, 2KB code space in a 25 is a nice bump.. I’m amazed what he’s done is so little space of the 13A’s.
