- The Fake-Cree LED Awareness Thread - The new "low" in Budget lights.
989 posts / 0 new
JFeldschau
Last seen: 2 months 4 weeks ago
So you think for sure not Cree? Thanks for your reply!
DBSAR
DBSAR's picture
Last seen: 12 min 59 sec ago
JFeldschau wrote:
Ok. Your meaning Cree XTE? It does look like the picture in that thread. I’m about to buy 60 of these and I just want to make sure they are the real deal. So it can be a Cree and not say Cree?
The genuine XTE: > https://www.cree.com/led-components/products/xlamp-leds-discrete/xlamp-x...
JFeldschau
Tricky business! Hard to really know
moderator007
moderator007's picture
Last seen: 34 min 42 sec ago
I zoomed in on your pic and I don’t see the dot that’s in one corner of the XTE’s.
JFeldschau
Thank you for your observation. I’m an amateur at identifying fakes. I’m about to drop a couple thousand dollars on lights and don’t want to be taken for a fool.
JFeldschau
Any thoughts on the credibility of 1000bulbs.com ?
Sari33
Last seen: 1 hour 39 min ago
Very Helpfull thread,thanks!
have some old XM-L same package as original and bond wires
but die size a bit smaller than the authentic
will post photos soon
csbert
Last seen: 5 months 4 weeks ago
Anyone knows if this is a fake XM-L2 u3 or not? Got this from Aliexpress.
https://postimg.cc/vggBJ4XP
Thanks
moderator007
Thanks
It looks like the real thing to me but the bin could be anything. But you never know just how cleaver they can be.
This might help a little.
http://budgetlightforum.com/node/49725
csbert
Thanks. The dot pattern looks right. However, there is a curious writing in the corner that I couldn’t find on the internet.
thisnameisvalid
thisnameisvalid's picture
Last seen: 5 hours 7 min ago
Looks fake to me. The substrate on that is white, but on a real XM-L2 it’s black. Even the fake emitters getting decent so as long it works fine I wouldn’t worry about it being genuine or not.
csbert
I was curious so I bought a XM-L T6 on a starboard from digikey (shouldn’t be fake right?). I installed it into the flashlight and guess what? The T6 was about 160 flux while the U3 from the light was about 200 flux from about 6 feet away. So I guess these are either real or very good fake.
DBSAR
DBSAR's picture
Link is not working)
rngwn
rngwn's picture
Last seen: 7 min 23 sec ago
Is it possible that these LB’s are actually using CREE’s chip, but has worse implementation (i.e. lower quality substrate, lower grade gold wires, worse quality phosphors, etc.)?
I also have a gut feeling that LB may be cutting corner by using the blue LED chip meant for XP-Gs in the XML-like body and try to pass it off as XM-L. Of course, that results in lower overall efficiency.
Searching for High CRI leds since 2010...
Has finally gotten to the bottom after 10 years of delving deep into that rabbit hole of them high CRI lights...
High CRI, high quality lights doesn't need to be expensive, or is it?
DBSAR
DBSAR's picture
its difficult to know. the LB LEDs are less efficient, have bad CRI, and very inconsistent with quality & tint.
scosgt
Last seen: 48 min 15 sec ago
I may have gotten a fake chip in this cheap light
Cheap zoomie
It is a 6 Volt XHP 70, but when I took off the bezel and lens the dome just fell off!
See my post in modding.
rngwn
rngwn's picture
Cheap zoomie
That’s “instant dedome” feature! You should be happy about it that you don’t need to do it yourself. LOL
scosgt
rngwn wrote:
Cheap zoomie
LOL
The_Fat_Controller
The_Fat_Controller's picture
Last seen: 3 days 4 hours ago
Cheap zoomie
They run a seriously over driven Fake XHP..
But the 3amp 6v driver is perfect for an MT-G2 if you drop one of those in and swap out the cruddy plastic lens with a glass one, you get a good few more lumens and the light runs way cooler also decent run time on half decent 26650’s
scosgt
The_Fat_Controller wrote:
Cheap zoomie
I swapped in a real (hopefully) HP70.2
Where do I get a glass lens?
snakebite
snakebite's picture
Last seen: 4 days 3 hours ago
the build quality is definitely not cree.
look at the die attach adhesive.
Flail wrote:
Could use some help with this one:
Does that look like a genuine XP-E ?
snakebite
snakebite's picture
one indicator of fake is sloppy die attach.
a mature manufacturing process like cree’s wont have that.
that sloppy attach increases thermal resistance.
so far even if the rest of the device looks spot on the poor build quality gives it away.
g_sintornillos wrote:
steendp wrote:
Fake for me
The core is too small
rngwn
rngwn's picture
I don’t know if I should mention this, but I noticed a large influx of Chinese suppliers making “CREE XM/XP family” clones. There are at least three manufacturers I am in contact with are making these.
Make no mistakes, they don’t sell these as “XM-L” or “XP-G” but rather, for example: “5050 5w” (basically using XP-G sized die on XM-L case). It is up to the flashlight makers to advertise these as “CREE”.
You can probably guess what happens when they advertise the “5w 5050” as “XM-L” and push 10w into these.
PS: Some manufacturer I know may offer High CRI version of these too. (although you will most likely get in-spec CRI, but the tint will very much depend on the luck of the draw).
The_Fat_Controller
Glued on emitters Facepalm , every time I think I’ve seen everything, this has to be up with batteries filled with sand
rngwn
rngwn's picture
To be fair, CREE does this too, but in a less sloppy manner, unless the LED in question are flip-chip ones that can be soldered directly on the substrate.
The_Fat_Controller
Are the emitters on kaidomain genuine?
rngwn
rngwn's picture
Based on the earlier discussions in this thread, Kaidomain indeed sells genuine emitters. KD also includes the pics of the plastic wrap (with brand, binning and other techincal infos) where the emitters came from for some of the items.
The_Fat_Controller
Cheap zoomie
I used this one
