beamshots "Lumapower" xm-l + 3x mc-e + 3x xr-e 44mm lens ...
31 posts / 0 new
viffer750
Last seen: 3 years 5 months ago
I made some beamshots, because I was very curious to know how perform the C8 clone lumapower mrv xm-l against my other lights.
The truth that I modified the driver of the lumapower, shorted the polarity protection diode, and got 3.5A instead of the original 2.2A.
the concrete wall is about 40m away
please don't blame my English Smile
control
1
small sun zy-c60 xr-e Q5 ~ 0.6A
2
 ultrafire wf501b mc-e 2.4A
3
mte ssc p7 modifed with an xm-l, OP ref and ~2.3A
mte
TR-1200 5xQ5
tr1200
3x mc-e 3x18650 ~3A
3xmc-e
and the lumapower xm-l ~3.5A
luma
+ some throwers
x2000
x2000
xm-l ~4A + 52mm lens
52mm
xr-e Q2 1.5A + 44mm lens
44m
3x xr-e Q2 + 3x 44mm lens
3x xr-e
unique engrish language... Smile
Edited by: viffer750 on 09/17/2011 - 05:11
miamilight
Last seen: 10 months 2 days ago
Is the 3x mc-e 3x18650 ~3A one you put together yourself or is this something one could buy somewhere?
viffer750
and long distance beamshots
The shutter speed was 3 sec, but the iso rating only 100, overall a little bit over exposed. (full moon's light on the background)
the church is 360m away
control
c
lumapower xm-l
lp
tr-1200
tr
x2000
x
xm-l 4A +52mm lens
52
xr-e 1.5A + 44mm lens
44
3x xr-e 3x 44mm lens
3x
viffer750
it's a "homemade" flashlight
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 1 year 11 months ago
Well I'm impressed forget the shutter speed.
How much for one like this?
ILIKEFLASHLIGHTS
Or for this one?  That's a bright thrower.
miamilight
How would something like a Trustfire 3T6 compare to that?
ILIKEFLASHLIGHTS
That's a good question.  I don't have one but maybe someone who does can chime in.
vawayne
vawayne's picture
Last seen: 8 years 10 months ago
Trustfire t6
小さな画像をクリックすると、下に拡大表示されます。
  • TrustFire CREE T6×3 5モード 3800ルーメン 爆光ライト_画像1
  • TrustFire CREE T6×3 5モード 3800ルーメン 爆光ライト_画像2
  • 正面の壁まで約20メートル
正面の壁まで約20メートル
jacktheclipper
jacktheclipper's picture
Last seen: 7 hours 2 min ago
Thanks for the beamshots .
viffer750
to the first post and pictures, camera settings was the following: 1sec shutter speed, and iso200
And I think my 3xmc-e light is almost the same as the new triple xm-l flashlights, trustfire sky-ray etc..., maybe a little brighter, becasue my light sucks over 3A from 3 pc 18650. I use relative old cells with this light (~150mOhm internal resistance), because of the direct drive. It could be to drive easily over 4A/emitter with newer cells, but I dont want to overstress them.
This google translate helps me alot, but I know it's not perfect. Smile
ILIKEFLASHLIGHTS
Ok I still didn't get my questions answered.  Do you sell these lights are would you build a guy one?  If no, I understand.  Just curious.
2100
Last seen: 1 year 9 months ago
Nice beamshots, nice 3 x MC-E too.  Quite noticeable donut though.  Surprised that the 5 x Q5 did not throw as well....you got the more recent versions?  (only the first batch was driven aggressively)
For those who wants to buy the 100mm diameter 3 x MC-E, can try PAlight BG-03 and XTAR D31 howitzer.  Expensive though.
viffer750
Sorry, but this is a hobby for me and I do not want to sell or build more. Embarassed
viffer750
Yeah, it would be better with xm-l -or a better reflector-  but when I made this light, there was not yet only mc-e. It's a DX triple reflector SKU 11922.
ref
My tr-1200 with 2 cells goes 2.5 ampere, it's ~ 15W or more.
Earlier I made ceiling bounce test, and tr-1200 performed "35" relative value, and the C8 clone xm-l's score  was "40" at 3.5A. The throw capability is almost the same for the tr-1200 and C8 clone.
ILIKEFLASHLIGHTS
Well if you change your mind let me know.  I would pay for a light like that if it is reasonable.
plafon
Last seen: 7 years 11 months ago
hi! viffer750, Could you show a picture of this flashlight? xr-e 3x 44mm lens (I'm impressed).
thanks.
VFMaddict
thanks.
+1
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
viffer750
as you wish
3x
and spot size and intensity
above: x2000
left to right:
C8 clone xm-l 3.5A
tr-1200 5xQ5
xm-l 4A 52mm lens
xr-e 1.5A 44mm lens
spot
2100
Your triple Q2 aspheric seems to be able to comfortably outgun the SR90.  Do you have access to a lux meter?
viffer750
Yes, I have a cheap one from ebay, lx1010bs. I don't know how accurate this. I think it measures higher value than the real (20-30%). I have only relative peak lux values from 3 meters.
x2000 Q5 1.3A ~ 2300
C8 clone xm-l 3.5A ~ 4300
TR-1200 ~ 4300
xm-l 52mm lens ~ 8000
xr-e 1.5A 44mm lens ~ 9200
3x xr-e 44mm lens ~ 24000
2100
Any info is better than no info.  BTW do you mind measuring from say at least 10m, preferably 15-20m?  What i am trying to do is to let the beam focus and smooth out, when you are farther out the hotspot peak intensity will be easier to get hold of and not only stay at a small place (it smooths out so to speak).  Also the meter sensor will not get overloaded, as you can see 24k is too much. Forget about the specs - most guys in the hobby know about the characteristics.
C8 XM-L @ 3.5 is pretty well known. XR-E @ 1.5A with a 44mm aspheric is also guessable. Yours is high but we still can make corrections and give educated somewhat accurate guesses and be around in ballpark.
Your XR-E @ 1.5A with 44mm is probably 55k region in true life (i am expecting decent heatsinking but not excellent, so you get around 1.1A-1.2A true relative performance unless you directly mount to pill). Triple XR-E aspheric is 2.6X, so you get 143k. Could be slightly higher than Olight SR90.
viffer750
okay, from 10m as I saw:
x2000 ~200                               @1m -30%= 14000lux
c8 and tr-1200 both ~370            @1m -30%= 25900lux
xr-e with 44mm lens ~810           @1m -30%= 56700lux
3x xr-e 44mm lens ~2100            @1m -30%= 147000lux
It's almost the same as from 3m.
These estimated values ​​are acceptable?
yavi
Last seen: 5 years 4 months ago
Hi, viffer750.
You got a really nice collection.
Would it be possible to show us how did you mounted the 3*xr-e?
I would like to see it and know the distance between the dies, as I cannot figure it out.
The only multi-die I had seen with Aspheric lens are some MC-E which show clearly 4- dies on the wall, but it is not the case in your pictures.
LUMEXX
LUMEXX's picture
Last seen: 8 years 9 hours ago
viffer750 wrote:
as you wish
3x
above: x2000
left to right:
C8 clone xm-l 3.5A
tr-1200 5xQ5
xm-l 4A 52mm lens
xr-e 1.5A 44mm lens
spot
Smile 3 xr-e  44mm Very nice model.
viffer750
Hi,
here is the solution:
1
 hard to find the right focal point of the lenses, but much more harder focusing the 3 beams into one point, it's a nightmare. Smile
Because the lenses are put to the head, it can be fine-tune the beams, when you rotate the head:
yavi
Haha Iove that futuristic effect.
Just one more question, is each of the three lenses 44mm? If so, what is the head diameter?
viffer750
Yes 44mm. But it had to grind the side of the lenses, because the head is only 82mm.
http://www.dealextreme.com/p/44mm-secondary-optics-glass-5-pack-4558
But be careful. I got in my first order almost perfect lenses, but some months later I got totally garbage lenses.
here is the body:
http://www.ebay.com/itm/109-LED-Powerful-Bright-Light-Lamp-Torch-Flashlight-NEW-/130424562451?pt=US_Flashlights&hash=item1e5de8e313
Chicago X
Chicago X's picture
Last seen: 7 years 1 month ago
The 109-led host is an excellent choice for a monster thrower as well.
A single, large projector lens from an automotive HID kit fits nicely in the bezel.
IIRC, the first DEFT was a similar setup.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
JohnnyMac
JohnnyMac's picture
Last seen: 2 months 2 days ago
viffer750 wrote:
Hi,
1
That is impressive and inventive! Smile
yavi
I am waiting for some new flashlights, so I should stop buying a bit till next month at least haha, but I would love to do something similar.
The best zooming I've got now is the Yezl T9 with the Ultrok x2000 big head lens (which is better than the original in the yezl), but this one looks like is far better than that in a bigger host.
Another question would be the battery/es you are using, it could be nice to do it with an 26650, which I guess could fit.
