ELT-04 4*XPG 1200LM NEUTRAL WHITE BIKE LIGHT
Dear BLFers, please allow me introduce new light, based on the MR16 form factor driver ELT41. Driver works
as boost converter with input voltage 5.5...12.8V and have 4 XP-G LEDs on board.
Driver have very high efficiency in 2S and 3S Li-ion configurations.
Driver intended for quad 35mm Ledil and Khatod optics. With 35mm Ledil CUTE-4-SS it can provide very good
light for cycling - about 12 degree with soft borders.
ELT-04 light is based on standard MR16 aluminium case:
We can also offer external switch option. Same functions, as with the button on the light bottom, only
color light inside the switch display battery charging level.
Techical parameters:
  • 4*XP-G Neutral white LEDs, 1200 ANSI Lumens
  • Only two modes: High 100% and Low (programmable 2...50%)
  • One touch to switch between modes
  • One touch to program Low mode level
  • Switchable daylight strobe mode (High-Low-Strobe or High-Low)
  • 120 minutes run time at 100% output
  • Built-in termal protection reduces the output level, if the LED temperature is over 90 degree
  • 4*18650 Li-ion battery pack with LCD indicator
  • Water-protected to IP65
Box content:
Beamshots:
More details - http://www.eltehs.lv/pshop/en/13-bike-li
I will be glad to answer for all your questions and comments. We are developers and manufacturers of this light, so all your input will be greatly appreciated.
I like the neat looks of it. And the neutral tint is great!
Could you provide more information on the UI?
how do you turn it on/off, switch between high/(programmable low)/strobe, and how do you set brightness.
The description says "one touch" for everything, but that doesn't actually mean much.
Yes, it is really simple.
Short press - ON (last mode, stored)
Next press - switch between Low(user) and HIGH: HIGH-user-HIGH-user-...
Long press (>1.5sec) - OFF.
So, for normal usage you have two modes - Low(user) and High. Short press to switch on, short press to switch between modes, long press to switch off.
User level brightness programming: Switch on, switch off (press key for >1.5sec) and continue hold the key (>5sec). After 5 sec light is switched on and start increasing light level from 2% till 50% and back from 50% till 2%. At any time you can release the key - this level will be stored as user level.
Strobe light programming: Switch on, switch off (press key for >1.5sec) and continue to hold the key (>5sec), continue to hold the key till full brightness programming cycle finished (15sec). After that light will flash 3 times. If you release the key during this flashes, strobe mode will be enabled (or disabled, if it was enabled previously).
If strobe mode enabled, you will have three modes: user-HIGH-strobe-user-HIGH-strobe.
