How do you like my new shower lights?
I wanted to install some mood lighting in my shower and since I had the thing torn down it was a good time to do it. I checked on some recessed lighting, but found nothing I liked and wiring the can seemed to be a pain as it needed to follow certain code for a wet area. I found some RGB sauna lights on Alibaba, but all were large in diameter. I did find 1 supplier with these very small flush sauna lights. They are waterproof as well. The beauty is that they are DC power, so pretty much no code involved there that I could find. I'm not sure they were made for ceilings, but they worked perfect for what I wanted. Drilled the holes and connected in the ceiling. I tried 2 different wall panels for the controls and didn't like any of them. I decided on 1 of those RGB remotes you can get on ebay. Believe it or not, it is very nice quality and works perfectly. Will also control other sets of strip lights once I get them installed. Will dim way low and go as bright as the power supply will allow. When the lights are turned off you barely even know they are installed.
That remote isn’t waterproof is it?
It should be :E or you can’t change the lights while you’re taking a shower.
Can you take a picture of them while they’re off? I don’t see the fixtures at all, only the light. It looks like the ceiling itself is glowing, or there are lasers shining on the ceiling.
Ooooh nice!!
Nope, the remote is not water proof, so I guess I’ll have to decide what color I want before I jump in. I’ll take a pic later with them off and also of the light itself not installed.
cool….interested to seeing this product.
