What Legoes with What?
152 posts / 0 new
Firelight2
Firelight2's picture
Last seen: 1 hour 4 min ago
Skilhunt DS16 legos with Manker E14 / Astrolight S41. The threads where the head and body tube match and are interchangeable.
Note however that the skilhunt is an e-switch light and lacks a tailcap switch, so the usefulness of legoing with the astrolight except for an advanced modder, is pretty much nil.
On the other hand, if you have the astrolight you can get 18650 support using the Manker 18650 tube. Note however that the Manker’s o-ring won’t be covered.
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 2 weeks ago
Ordered both the SS and AL versions of the Ultrafire C3 from DX to see if they both fit the x5.
Scott
hank
hank's picture
Last seen: 32 min 52 sec ago
Cross-reference for mention of various Convoy lights:
http://budgetlightforum.com/node/47986
Rufusbduck
Ordered done flashlights from DX on 7/11, the shipment was broken up into 3 separate packages and the first of them arrive on Friday 7/22 a new record for them. Jolly good show! In this package were a couple cheap AA lights. A Sipik SK68 and an Ultrafire C3. I was particularly interested in the C3 as I had heard a version of it would Lego with my copper X5 and this I can happily confirm. Also of interest is that those cheap no name cree AA lights from eBay also Lego with the SK 68, the tail caps are interchangeable and the tubes thread together so you can easily make an xhp50 zoomie.
Scott
mattlward
mattlward's picture
Last seen: 4 hours 29 min ago
Yup fits… need to add a wire ring behind the driver retainer for it to make contact.
!2016-07-24_10-01-53!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Rufusbduck
That’s the SS version, right? I’ve one of those in the order as well. Is that a recent purchase? Mine works without a wire.
Scott
mattlward
mattlward's picture
It is the SS, bought about a year ago. Fits well and looks pretty good. It is the 93mm version.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
mattlward
mattlward's picture
I would not fire it up with the stock C3 switch, that light will draw way to much current for that switch!
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
Rufusbduck
My SS C3 from DX came yesterday and it does indeed fit the copper X5 very well and works just fine. Although the longer threading of the X5 tube does not go all the way into the head or tail of the C3.
Scott
Rufusbduck
Hey Matt, the switch in the SS C3 is a type of Omten 1288 with a different ground connection. I suspect that given the extra number of mechanical contacts in the arrangement that higher currents will cause multiple voltage drops but the switch itself should be fine. Ultrafire seems to be fond of placing the switch in a pill and this one is much better made than the 501/502 versions and has a threaded cap on the button side. On mine this was loose causing erratic behavior but once tightened it works just fine. I did also change the button cover from the ill fitting, hard to access, concave cover to a standard convex one. Neither would tail stand but at least it’s convenient to operate now. A 1 mm oring inserted before the button cover could fix that but only if the tube threads were likewise shortened or the tail cap would not fully screw on.
Scott
mattlward
mattlward's picture
Rufusbduck, glad you pointed that out! I should have referred to the tailcap. I did melt one of them with a FET driver and lithium ion batteries… I did restore it to service and it still lives. I like the little C3 SS.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
Rufusbduck
Fwiw, I think it might be possible to change the switch to a more standard switch on pcb arrangement but it would probably also require shortening of the tube threads to gain space for the pcb and cannibalizing the aluminum module for a retaining ring. Probably not worth it in an SS host with limited heat capacity but if you’re modding it to switch melting levels you might consider it.
Scott
mattlward
mattlward's picture
I blamed the failure on high resistance points around the switch, not the switch proper.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
Rufusbduck
It would probably be much easier to alter the aluminum C3 and better able to disperse the heat as well. This ones a good candidate for one of Harleyquin’s Oshpark boost boards as stock it has the annoying five modes with next mode and no memory.
Scott
hank
hank's picture
As reported here, with a picture: http://budgetlightforum.com/comment/991746#comment-991746
pilotdog68 wrote: … the X2R [legoes] with an S2+ 18350 tube …
hank
hank's picture
xref to discussion of the Ultrafire uf10 zoomable 16340
Muto observes:
Quote:
Just going through some lights of equal diameter and found that the old cheap Ultrafire Focus-590 (18650 light) tail cap fits/threads and works.
http://budgetlightforum.com/comment/988427#comment-988427
pilotdog68
pilotdog68's picture
Last seen: 2 months 6 days ago
hank wrote:
As reported here, with a picture: http://budgetlightforum.com/comment/991746#comment-991746 pilotdog68 wrote: … the X2R [legoes] with an S2+ 18350 tube …
Just an update,
the blue 18350 S2+ tube I have from Banggood fits both my blue S2+ and the X2R perfectly, but the black S2+ tube I just got from Simon directly only works in the S2+, not the X2R. It doesn’t thread in all the way. Maybe I should try a black one from banggood? Or the astrolux version?
edit: BG actually has one that says it’s for eagle eyes, maybe that’s my best bet. Has anyone confirmed that tube fits other genuine EE lights?
djozz
djozz's picture
Last seen: 32 min 58 sec ago
I was clearing some demolished tripods (the brand is Velbon) at work (=school, adolescents can and will break anything), and it struck me that this extension tube for the tripod looked familiar. So I took one home and behold: it fits the BLF A6 like a glove. It needs some work (clearing ano to make electric contacts, extending the tail spring and driver spring a bit) but then it fits 5× 18650’s. It just needs a 20V led and driver now Or 40V of course if I add another extension Big Smile
The result ( Party )demonstrated by my son (nothing modded yet, just to show how it fits):
pilotdog68
sooo triple (3S) XHP35 HI in an A6?
hank
hank's picture
Quote:
BG actually has one that says it’s for eagle eyes …. Has anyone confirmed that tube fits other genuine EE lights?
Last I recall it people just had to order them, try them out, and ask the shippers to try again if what they got didn’t fit, like there was a grab bag of mixed parts at some shipping site.
I kept hoping that would get cleared up and I guess I gave up watching.
So, ah, how many tripods, and how many legs that have threads that fit so well? Time for a mod-something-unexpected challenge round??
khas
Last seen: 1 week 6 days ago
I have ordered six so far they all fit all my X6’s and A6’s.
The only short tube I have had problems with was the bare BLF A6, never got a short tube that fitted.
pilotdog68
Thanks. I ordered one to try. Unfortunately I ordered at the $4 price, and now they are on sale for $2 Facepalm
khas
Well right back at you, just ordered four more, $2 is the cheapest I have seen Big Smile
somnambulism
Foursevens Preon P1 Copper and Fenix E99Ti have heads that can be swapped with one another:
hank
hank's picture
Elaborating on this because of a mention in the Best Zoomable Flashlight thread http://budgetlightforum.com/node/48976
_________________
So far, the “3W Police 2AA” threads fit most of the #3 zoomie, and all of the SK68 zoom and COFLY KX – FH10 zoom flashlights I’ve tried
Xref, Keltex also has a good thread on these: http://budgetlightforum.com/node/7686
I’ve used this one: http://budgetlightforum.com/comment/761607#comment-761607
http://chinaprices.net/buy-3w-white-led-aa-handy-camping-flashlight-torc...
You use two of the sections with the ten ribs. Those sections have one male and one female thread.
With the #3 and SK68, the male thread fits into the zoom flashlight body in place of the tailcap.
So you can stack two of the “11-rib” sections, and you use the zoomie tailcap.
(in that case, you have the other battery tube section, tailcap, and emitter as a poor 1AA flashlight)
Or you can stack the one 11-rib section with the other section and keep the “3W” tailcap.
I guess this needs a picture, I’ll get one showing the variations.
With the Cofly zoomie, the female thread fits the zoom flashlight body in place of the tailcap, and you keep the “3W Police” tailcap switch, which has a female thread.
(in that case, I forget if there’s any way to use the leftover parts.
For a few years I had no problems; the last few #3 zoomies I tried had incompatible female threads though, so the extra section wouldn’t fit.
I can still find #3 zoomies for $2 intermittently, on sale at AliExpress (last ordered some a week ago though the price bounced back to $4 as of right now)
Not sure if they’ll have compatible threads til I have them in hand to try out though.
keltex78
keltex78's picture
Last seen: 1 month 1 week ago
I couldn’t resist and ordered as well, based on this thread saying they fit the Convoy S6 host:
http://budgetlightforum.com/node/46762
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
kiriba-ru
kiriba-ru's picture
Last seen: 4 hours 6 min ago
All convoy S series have same threads. Simon sais that short tube wont fit only because different length of tube over threads (18350 tubes were made for S2+ so they fit S2+ and probably S3).
pilotdog68
Btw, BG was kind enough to refund the difference that I paid before it went on sale.
Barkuti
Barkuti's picture
Last seen: 1 hour 27 min ago
djozz wrote:
I was clearing some demolished tripods (the brand is Velbon) at work (=school, adolescents can and will break anything), and it struck me that this extension tube for the tripod looked familiar. So I took one home and behold: it fits the BLF A6 like a glove. It needs some work (clearing ano to make electric contacts, extending the tail spring and driver spring a bit) but then it fits 5x 18650's. It just needs a 20V led and driver now  Or 40V of course if I add another extension Big Smile
Nice light-throwing baton! Evil
Now go blow some backs, LOL!
Cheers Party
The Light Innocent I am
hank
hank's picture
Hat tip to t18, at: http://budgetlightforum.com/comment/995602#comment-995602
Jaxman X1 and Convoy L2 half tube extension lego (9 pictures somehow presented page-by-page in a single window in a single response, lovely)
