Review:Nitefighter L1A first impressions (serious problem)
28 posts / 0 new
power911
power911's picture
Last seen: 2 days 9 hours ago
Took me a while to decide on a headlamp until ChibiM recommended me this light and having djozz disassemble his unit is what convinced me to get myself a unit
I asked here and ChibiM linked me to this post
Just some notes:
I am not sure if this comes from banggood or gearbest as I believe I cancelled my order from gearbest but this package arrived without indication from banggood. I usually get some form of notification it’s from banggood on the package but I am not sure.
Anyway here is the light.
Box arrived in an abused state with plastic getting dinged up by the light itself.
Light is safe with no scratches though
Pretty deep textured reflector revealing actual XPE and not some fake chinese copies
I really liked the threads. They are triangular but they feel butter smooth as compared to my Fenix LD12 grainy square threads. They come mildly lubed.
Tool marks from the factory on the head side. Not something I’m happy but it’s okay
Decent magnet. Not as strong as Olight S15 but it gets the job done
Headband is pretty nice I gotta say. It is a tad small but having it on my head with sweaty forehead doesn’t get me sores or annoyance.
The headband clip is on the hard side. Less flex on the plastic but mine doesn’t feel like it is going to break from use as it slides in and out with ease but grips firmly. Most importantly I don’t have to remove the pocket clip to use the headband.
But I don’t like the pocket clip. It comes off the light too easily.
Nasty ringy beam like everyone said. But the tint is okay. It is similar to my Convoy C8 XML2 U2 1A tint.
It comes with 4 modes via electronic switch.
High, Low, Fast strobe, SOS. No memory. Leave any mode on for more than 3-4 seconds and you can click it to turn off immediately.
No PWM so that’s good.
From left to right
Convoy C8 XML2 U2 1A, Nitefighter L1A unknown XPE, Fenix LD12 XPG2 R5, Ultrafire with Nichia 219B
The tint is more on the 1A color with more purple blue rather than greenish tint like the Fenix LD12.
It is in a cool range but not the nasty UV colors that appear in cheapo chinese lights.
It is obviously not warm at all so it could get annoying at night with that cool blast.
dismantling the light from the driver side shows something different in reflector construction.
I saw the pics from djozz and he had some conical reflector but mine had a hybrid cone + cylinder shape.
Still can’t get the lens out even though prying it from inside or out.
I gotta mod this bad boy to use the XML2 T6 3B I had laying around.
Too much throw but it sure is a nice little light for close up soldering work
Still waiting for nighttime to try things out
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
“Humans m
Edited by: power911 on 08/27/2015 - 11:52
power911
power911's picture
Well in less than a day receiving it, it caused problems
using it under rain just somehow cause the O-Ring to suck itself in and fell into the reflector.
Still can’t get the plastic lens out so I’m wondering is there any better methods to push it out?
“Humans m
pilotdog68
pilotdog68's picture
Well… I literally drilled the lens out if mine. But now I can’t find a replacement.
Beachlogger
Last seen: 5 months 4 days ago
The plastic on my headlamp failed soon after I got mine
I put 3m removable tape over the lens on mine to smooth out the beam
hank
hank's picture
Last seen: 5 hours 20 min ago
I have one of these too, bought hoping it would be moddable.
Yeah, on mine also, the plastic C-shape thing meant to hold the light onto the headlamp broke off within a few minutes of use.
> using it under rain
Maybe you heated it up, drove some moisture out, then it cooled down and actually pulled a vacuum?
Not the first time a flashlight has literally sucked.
ChibiM
ChibiM's picture
Last seen: 4 hours 11 min ago
Sad to hear it failed on you. Hopefully there will be more brands offering these kind of lights for the price.
But reading your review and Djozz`s earlier impressions defnitely show that its not a mod friendly light!
thanks for the time to review it!
djozz
djozz's picture
Last seen: 56 min 53 sec ago
Mine is still in parts after I did manage to get the lens out in one piece. It is going to modded with a XP-L one day...
pilotdog68
I have all the parts to reassemble mine, except the lens. I bought some glass lenses from KD that should’ve worked, but they were slightly too big and cracked wayyy too easily when I tried to sand them down. Flashlightlens never responded to my request for the tiny size. So I might be SOL
power911
power911's picture
Have you tried thin Lexan sheets? Or maybe even some cassette case filed to circular shape?
I believe some CD cases even had matte surfaces that contributes to diffusing as well if you need it.
Anyway an update to what happened with my light
I eventually tried Fichtenelch method by prying the LED star.
lols
This guy is tough man
Got the whole thing out eventually with a strong POP shooting the lens and reflector far
Did manage to get everything to work even when I cracked the star AND the LED itself. One corner of the XPE was chipped off but it didn’t harm the die itself other than some EXTRA CLEAN DEDOME
Well this is the first time I manage to dedome an xpe sized LED cleanly leaving no residue or pulling too much phosphor.
I got this
Assembling it all back and give it a shine with the slight warmish neutral tint (of course the infamous green tint is there)
There seems to be less rings after a dedome. But it is still there.
(Pic shows the dedome on the left versus the Convoy C8 with XML2 U2 1A tint)
I am overall impressed with my failures despite scratching a lot of its beauty.
All I need was just some scotch tape to cover the leftover rings.
I do suggest filing the stock lens to a smaller diameter if you plan to reuse it. I filed mine and it is still a tight fit but enough to pop it with a small plier
I wanna ask something. Is the SOS mode on your unit blinks on low power or is it that way since factory? Mine blinks on low.
Plus the SOS isn’t SOS but rather SOSOSOSOSOSOSOSOS
“Humans m
power911
power911's picture
So the XPE decided to flicker and break
So here is the XML2 T6 3B in the nitefighter
Had to remove the o ring to make a proper fit even after filing the reflector for the XML2
the hole is a perfect fit
gotta say I don’t like it’s tint with this reflector. Not too sure why it looked odd. Maybe the lack of amps causing different tint? I don’t know.
It sure is more floody and brighter than the xpe
“Humans m
vēer
vēer's picture
Last seen: 5 months 5 days ago
Thanks for review, finally someone made proper review :D!
sandalian
sandalian's picture
Last seen: 3 years 9 months ago
I was about to buy this flashlight, thanks God I didn’t!
I'm switching my BLF account into LumenZilla. Thanks!
bibihang
bibihang's picture
Last seen: 1 day 10 hours ago
Thanks for sharing the details of this light with us. I’ve been looking at it and considered if I was gonna buy one… but if a light is very difficult to be disassembled it is a no-go to me. Sad
But considering its price point I think it is still quite a handy light to have, especially using it around the house or make it as one of your backup lights at outdoor.
power911
power911's picture
I wouldn’t consider this a good light just from how the O ring sank into the light from mere rain.
Maybe I got a dud but this light caused multiple problems when I try to mod it.
It is a reasonably good light if you keep it stock. Modding the light requires creative hands as I have just killed my xml2 t6 3b thanks to the light.
The light kinda pulled my xml2 LED into pieces. It dedomed my light somehow snapping the bond wires.
I gave up modding this light as it has killed 2 of my xml2’s physically.
“Humans m
hank
hank's picture
Yet another observation in the wild of a self-reviewing “so-so” flashlight. I’ve seen it on this one, and found mentions elsewhere of that pattern in other lights going back a few years.
bibihang
bibihang's picture
Maybe if you don’t use it in the rain then it is an OK light haha.
power911
power911's picture
unless you don’t mind o ring inside your reflector Wink
“Humans m
vēer
vēer's picture
Mind you it has so far happened to one light?
Only because its cheap it gets bad attitude :D? Thats not budget friendly attitude :D!
Cant dissemble for easy modding? Well, its not meant to, like most of lights, so its your fault, not the lights :)!
bibihang
bibihang's picture
I thought you mean the o-ring only scrambled inside the reflector after using it in the rain?
pilotdog68
I think I got my lens problem figured out, so I will continue working on this little guy.
For anyone who is interested in modding this light, I made a driver for it.
L4M4
L4M4's picture
Last seen: 1 day 6 hours ago
Do you think you can share the lens fix with us? Wink
I thought about glueing a new glass lens in or makiung a gasket out of POM on my lathe – but hop to get the lens out again? Silly
I would love to use a bigger-die-LED like a XM-L to increase the spot
no need for a bigger driver since I use this only as a extra work light on my work bench
pilotdog68
To get my lens out, I drilled a hole in the center of it then pulled with the drill bit still inside. So I was left with a lens (donut), the edges were still in perfect shape. What I did was fill in the donut with Gorilla super glue (which dried very clear) and sanded the glue down with fine grit sandpaper. It’s not perfect, but I think it’ll work just fine.
I still haven’t decided what to do about the o-ring yet.
A 14500 can hold a lot more energy than an eneloop, so I did the new driver more for run-time than for high performance. The most it can do is 1.14amps, but I will probably run it at 760ma.
I’m also putting in an XP-L 5A tint.
eebowler
eebowler's picture
Last seen: 2 months 6 days ago
would a heat gun or boiling the light in a zip lock bag soften the lens or the glue holding it in enough to make removal easier?
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
pilotdog68
There’s no glue, just a very tight press-fit
vēer
vēer's picture
Those of you who have taken it apart, do you know if it would be possible to put Cree MC-E RGBW LED in it? What modifications should be done then? Bigger hole in reflector, different driver?
I know its out of stock now at GB/BG, but been wondering.
Could as well mod my UF-H2 which hasnt been stellar anyway.
pilotdog68
I don’t think it’s possible. You would need to:
- Cut a bigger whole in the reflector (but the reflector is conical, so it will just get shorter and shorter the more you cut)
- Find an mcpcb that will fit an MC-E with wire pads to fit inside (I would say impossible, the solder pads are already very close to the emitter and it’s only an XP-E)
- Find a 15mm e-switch RGBW driver (which I don’t think currently exists.)
You could make it a tiny bit easier if you used an RGBW XM-L2 instead of MC-E, but you still have the driver issue.
vēer
vēer's picture
Thanks!
I see, I only found MC-E RGBW, any RGBW would be great to have in cheap host light!
Ok, next time :D!
pilotdog68
I finally got mine back together. I now remember how much I hate working on tiny, complicated lights.
I used my custom driver and an XP-L 5A tint. It’s amazing how hot this thing gets on just 1.1amps. I’ll probably take one of the 7135’s off.
