Just getting around to modding my Nitefighter L1A, and realized I didn’t have a driver for it yet. I suspect that this would be hard to assemble by hand, but much easier reflowing. It also requires cutting the center pin from the 7135.
Dimensions and features designed specifically for the L1A
Dual-PWM Support
LVP and RPP
14500 only, will not work with AA’s.
As always, if you see something that could be improved, let me know.
My L1A being still in pieces, I'm obviously interested :-)
So this is a 3x7135 lineair driver operated by e-switch. Does it use the common 105C parts? And what firmware is suitable? And what will be the parasitic drain (very relevant for a 14500 light)
(Btw, what is always a problem with these nice boards, I can not, and will not be able to, flash Attinies, so when time comes, I will need help from someone)
yep, it’s the same electrical layout as a 105C or Wight’s PZL. Any of the normal firmwares will work, but might need to tweak values a little bit to keep modes evenly spaced.
Yes, unfortunately it looks like they are no longer being made. I couldn’t find anywhere with them in stock.
I agree, 1amp puts out much more light than you would think. Since this is such a small light, I probably will only populate 2 of the 7135’s and run it at 760ma. I just wanted to fit 3 to see if I could :bigsmile:
