Driver for XHP35 LD-51
16 posts / 0 new
ReyLight
ReyLight's picture
Last seen: 10 hours 15 min ago
LD(济南东城)  as the most preferred driver manufacturer among forums,they have a lot of good drivers,such as LD-21,LD-29.
Now they realeased LD-51 for XHP35.
Dia:28mm
Height:less than 7mm
Uses TPS40210 chip. 8-14V  default 1A,  max 1.5A.
thermal resistor SMTed.
Formerly known as: WWEFANS
Edited by: ReyLight on 09/07/2015 - 23:07
zeremefico
zeremefico's picture
Last seen: 4 hours 9 min ago
Hi Rey, any details for the driver such as price, input voltage, dimensions?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
bibihang
bibihang's picture
Last seen: 1 week 6 days ago
That’s cool! Yeah, more information of this driver is welcomed. Smile
And I start to think which light can take 28mm driver…
Jubeldum
Jubeldum's picture
Last seen: 3 years 7 months ago
Rufusbduck
Rufusbduck's picture
Last seen: 7 months 1 week ago
Nice to see new drivers come out.
Scott
ReyLight
ReyLight's picture
I found it on Taobao.  12$.       Input: 2s 18650,  6-8.4V.
Size?
Dia:28mm
bibihang
bibihang's picture
Jubeldum wrote:
Only 1.5 amps?
LD-29S High Effeciency CREE MTG2 / XHP 50/70 Driver
!http://www.edc-light.com/u_file/1505/products/01/45b7b5a2c7.jpg.500×500...!
The LD-29S cannot power XHP 35, which requires 12V.
But yeah, 1.5A is too low. We need at least 5A (about 60W)!
thijsco19
Last seen: 5 hours 24 min ago
Have anyone tried it yet?
I might have interest in one of these but cant find them for sale anywhere except on taobao and I dont speak chinees..
Or does anyone else know of a 12V boost driver like this one?
cbrake10
I’ve been wanting to try the LD-35 with this emitter. I wonder if someone could test it with 4S emitters. The info I can find on the boost IC seems to indicate it should work.
-Clark
thijsco19
A 4S emitter setup would indeed work according to the specs.
I just wish the current would be a little bit higher, around 2A sounds perfect in combination with the XHP35. (around 2300 lumens, maybe 2500 lumens?)
Rufusbduck
Uses a pic mcu so likely adaptable for Attiny.
Scott
MEM
MEM's picture
Last seen: 3 years 3 weeks ago
What happens if two boost drivers share the same load (in parallel)? I.E., Could two of these be wired to one LED to run it at 3A?
Also, right now I have a bunch of spare boost drivers that output over 2.5A per channel, and have 2-channel operation. It boosts 3S voltage to up around 20V/2.5A per channel. The problem the average person may find with this driver; it is 50mm diameter. Flat Stare
I like bright lights, and I cannot lie.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 14 hours 9 min ago
Hmmmm i could make your drivers work on a custom build i would have to build a light from scratch or maybe it would work in like a SRK style light. I am currently looking for a driver for my XHP35
MEM
MEM's picture
Ah, I made a really dumb mathematical error once I looked at the wattage that sums up. It’s about 1.25A per channel, 2-channels. Not 2.5A per channel. Sorry. Those are rough numbers I figured out based on some efficiency fudge factors I made up and knowing input wattage. I’m still not sure that’s the exact numbers, but it should be relatively close. When I have a chance I will do a complete test to find the true values, as I know the drivers are capable of more power than they are running at.
tjeret
Last seen: 2 years 2 months ago
Kaidomain have them at $10.xx
Input max for 2 cell (boost)
I like how its looks, Big MLCC everywhere Smile
thijsco19
10 bucks? Hang on,I can beat that.
