BLF A6 FET+7135 Light Troubleshooting and Mod thread
989 posts / 0 new
Gunga
Gunga's picture
Last seen: 1 day 13 hours ago
Ok. I’m Pretty po’d now. Tried remelting the connections (they all looked pretty good) and still have no moon mode. Time to contact the professional guy. Waited over a month to get a non -working light. This sucks.
dudunphy
dudunphy's picture
Last seen: 2 weeks 1 day ago
Crap. Sorry Gunga. Hopefully you get a new head and you’ll have a spare to mod in the end….
Also thanks D.B. I was trying to do that post from my smartphone in the middle of some auto repairs. The fun never ends! Smile :_(
Dustin
Gunga
Gunga's picture
Oh well. I think I have a friend who wants it. Warts and all. Thanks a bunch for the advice. Too bad it didn’t work. I’ve contacted the professional guy and will await a response.
scotlarock
Last seen: 3 hours 38 min ago
Hey Tom, sorry for the slow response to your question. The method I now use to measure amp draw at the tail is this (thanks to Dale);
I use a 3” piece of 12ga, solid copper romex, bent into a u shape. I then do the standard bypass procedure on the tail. As you can see my readings have went up considerably since I began using this method. I, like you, was frustrated at how much different my readings were compared to other peoples, even on the same lights. The A6 that I won in Dale’s generous giveaway showed somewhere around 1A less than he achieved, when I received it and measured with my “thick short leads”.
Here’s an FYI to add more data to this topic. I bought 2 A6’s in this GB. 1 with 3D tint bin, the other with 1A tint. The 1A was the light that hit 6.7a after both springs were by-passed. I have now done the same mod to the 3D light with different results. 5.9a@4.18v with the same 25r cell, measured with the clamp meter. So it appears that binning does have something to do with the hi amp reading (as mentioned by Djozz, and Dale.
I never got around to building a “light pipe” to measure lumens, so I don’t have that data to add to the story. I did however, measure before and after lux on both lights and will post if anyone is interested.
Tom E
Tom E's picture
Last seen: 1 hour 59 min ago
I really dunno what's going on. I used to have a pretty high confidence in my UNI-T DMM equipped with the 14 AWG short length wires. It's certainly dead-on with 7135 based drivers all the way up to 4.9A or so. I work with a super tech who swears the internals for measuring amps in the UNI-T is as good as any Fluke meter. This guy has like 6 UNI-T's he uses regularly, plus a couple of Flukes. It's hard to describe this guy (the super tech), but he is one of the smartest people I know, so I always have a high degree of confidence in what he states and recommends, when he is serious that is...
I know there's a lot of anomalies going on at times in my measurements - things I can't explain. I suspect mostly it's contact/ground issues. Wire ends need to be cleaned or re-soldered (oxidation), contact by holding a wire end against the lip of a light tube is not always the best method, etc. Still, there could be major inaccuracies in 5+ amp range I didn't know was there.
ToyKeeper
ToyKeeper's picture
Last seen: 8 hours 54 min ago
If moon doesn’t work but everything else does (modes 2/3 and 3/7 should be visibly different from each other), it’s also possible that the 7135 chip could be a different type. The 350mA ones generally have a lower and more consistent moon level than the 380mA ones, and I expect there are more than just two types.
The firmware says to use 2/255 phase-correct PWM, which actually works out to 4 on “frames” in a row out of every 512. Some 7135 chips need 3/255 or even 4/255, and it also depends on the type of emitter. Old XM-L LEDs need a higher moon level than a newer XM-L2 or XP-L.
In other words, moon is pretty sensitive to relatively small hardware changes. This is a lot of the reason why cheap torches generally don’t have moon at all. And if any component changed or was out of spec, it could cause moon to fail without visibly affecting anything else. I hope BG can send you a new driver.
ToyKeeper
ToyKeeper's picture
Or, you know, it could be a symptom of the lunar eclipse which is currently happening outside. Even the real moon isn’t working right now. ;P
Gunga
Gunga's picture
Ha! Cool. You are correct TK. I have many Dr Jones programmable drivers with super low moonlight modes. They are quite inconsistent depending on the hardware. I think you are correct in your theory. Good call.
DB Custom
DB Custom's picture
Last seen: 2 hours 1 min ago
Yeah, even the real moon is wack… I tried to pull it back in line with a tractor beam, I think it worked Wink
djozz
djozz's picture
Last seen: 54 min 38 sec ago
DB Custom wrote:
Yeah, even the real moon is wack... I tried to pull it back in line with a tractor beam, I think it worked Wink
Dale, did you make that pic during the lunar eclipse? That's way cool! Cool
Boaz
Boaz's picture
Last seen: 16 hours 59 min ago
burnsd wrote:
I have size issues. I tested my order: one of each tint. The 3D didn't light up. The others did. I pulled the 3D tailcap and did the screwdriver bypass and it lit fine. The 3D tailcap on the 5A didn't light. On the 1A it will only if I really crank down. Putting a paperclip spacer in the 3D tailcap causes it to work on any light. So, the 1A lights on any tailcap. The 5A and 3D light only on the 1A or 5A tailcaps. The 3D and 5A tubes are visibly shorter to the naked eye. I can easily pick them out (1A is longer, 3D is way off center). So as I understand it, I have two short battery tubes (from 3D and 5A), and one short tailcap (from 3D). And I need to email that to heyanqing1@banggood.com Is that accurate?
I'm a bit confused here .. you have two lights that work . why not just figure out whats wrong with it and fix it . they don't all have to lego since they are the same light .what does lego have to do with it and what would you do with an extra couple bodies and a tailcap?..
 sounds like you need a body or a taillcap . not three .
at this rate it may just be more prudent to do some work on the tailcap if you can ...it sounds like what you have is a common problem on some of these lights. but what do i know i'm still waiting on mine ( while you guys are having all the fun )
i still reserve the right to complain at a later date ...
djozz
djozz's picture
djozz wrote:
bdivi wrote:
That is indeed more accurate than a multimeter but still there are 10mOhm plus two wires added into the current path (let us assume 20mOhm total including the connecting wires, connectors and soldering). 20 mOhm multiplied by 6A produces a 120mV voltage drop. This may not seem much but with the exponential VA curve of the LED 120mOhm will give you a difference in the measured current of at least 0.5A. See the attached Cree XML diagram for example. !http://i285.photobucket.com/albums/ll50/_JustinCase_/XM-LVfcurve.png! For comparison I use a wire for my clamp that is less than 2mOhm.
I'm not sure the connection set-up for the sense resistor gives another 10mOhm (I hope less), I did not check that but I can do that and report here, I'm curious too (not before tomorrow btw). The 0.5A drop at 120mA is also correct for the XP-L at 6A btw.
I just checked my current sense resistor set-up with the power supply set at 6.0A (ps reading=not dead accurate, ~0.1 á 0.2 A wrong): voltage measurent with probes directly on the resistor leads: 57.7mV, probes on top of the terminal block connectors (this is where I place the probes for current measurements): 60.3mV, probes at the end of the solid copper leads: 72.0mV. So the whole of connections of the sense resistor gives 2.4 mOhm on top of the 10 mOhm of the sense resistor. so the current drop from a XP-L at 6A caused by the sense resistor in the circuit is about 0.3A.
For perspective, I measured the voltage over a BLF-A6 tailcap with 22AWG silicon wire spring-bypass, measured from the top of the spring to the aluminium ridge that is screwed against the battery tube. When applied 6A, I get 124mV, causing 0.5A drop for the XP-L compared to directly connecting the batt- to the battery tube. So adding a well-build tailcap in the circuit is causing a bit more voltage/current drop, but is in the same range as adding the current sense set-up. That is convenient.
I'm happy Smile
ohaya
Last seen: 1 year 11 months ago
Boaz wrote:
burnsd wrote:
I have size issues. I tested my order: one of each tint. The 3D didn’t light up. The others did. I pulled the 3D tailcap and did the screwdriver bypass and it lit fine. The 3D tailcap on the 5A didn’t light. On the 1A it will only if I really crank down. Putting a paperclip spacer in the 3D tailcap causes it to work on any light. So, the 1A lights on any tailcap. The 5A and 3D light only on the 1A or 5A tailcaps. The 3D and 5A tubes are visibly shorter to the naked eye. I can easily pick them out (1A is longer, 3D is way off center). So as I understand it, I have two short battery tubes (from 3D and 5A), and one short tailcap (from 3D). And I need to email that to heyanqing1@banggood.com Is that accurate?
I’m a bit confused here .. you have two lights that work . why not just figure out whats wrong with it and fix it . they don’t all have to lego since they are the same light .what does lego have to do with it and what would you do with an extra couple bodies and a tailcap?..
at this rate it may just be more prudent to do some work on the tailcap if you can …it sounds like what you have is a common problem on some of these lights. but what do i know i’m still waiting on mine ( while you guys are having all the fun )
i still reserve the right to complain at a later date …
One of the things that is contributing to what burnsd is saying is that the threads on the A6 are anodized, and so the way that the light is designed is that the end of the battery tube at the tailcap end HAS to be able to contact the retaining ring inside the tailcap in order to complete the circuit. If the end of the battery tube is “short” by some tiny bit, it won’t contact the retaining ring and you won’t get any light no matter how tightly you screw in the tailcap (so note that this is not a battery length problem either).
That’s why putting a wire inside the tailcap helps sometimes… basically it moves the contact point of the retaining ring “forward”.
I had to put a wire ring inside my A6 in order for it to work.
I have one of the unanodized A6s coming (it is taking FOREVER to get here) and that should NOT have this problem since the battery tube is not anodized, the contact is made by the threads themselves, rather than by the end of the battery tube contacting the retaining ring inside the tailcap… that’s the theory anyway :)!!
FmC
FmC's picture
Last seen: 21 hours 32 min ago
My replacement driver arrived today.
Interesting to note that it came in a bag that was sealed with an SKU number sticker.
I ran the number through BG's site, but didn't get a hit.
Lilien
Last seen: 1 year 2 weeks ago
As far as I see it, the A6 tube is not in contact with the tailcap retaining ring (too small in diameter), it only gets in electric contact with the bare (not anodized) part (ring) of the tailcap.
This is one of the things I don’t understand in the construction of the A6 host, the other is the placement of the seal in the head (behind the glass lens).
ohaya
Lilien wrote:
As far as I see it, the A6 tube is not in contact with the tailcap retaining ring (too small in diameter), it only gets in electric contact with the bare (not anodized) part (ring) of the tailcap. This is one of the things I don’t understand in the construction of the A6 host, the other is the placement of the seal in the head (behind the glass lens).
Sorry – you’re correct. There’s an unanodized kind of “shelf” inside the tailcap that is the contact point, correct?
Lilien
Yes, “shelf” seems to be a good description for this part of the tailcap.
(English is not my mother language, so it’s sometimes difficult to find the right technical terms. Smile )
DB Custom
DB Custom's picture
Sometimes we get carried away when obvious solutions are right in front of us.
3 solder blobs on the ground ring of the driver, about 10 seconds, and the problem of a short tube is fixed.
I have yet to see one with the contact at the tail cap having issues. Again though, pull the retaining ring on the switch, put 3 blobs of solder on the ground ring around the outer edge, replace the retaining ring, and there should be no problem. A matter of seconds if indeed a short battery tube thread is the issue. Not sure what the answer will be for non modders, but a paperclip bent into a circle and placed under the retaining ring will do the same thing as a few solder blobs and take little more time as far as the tube length issue goes. Anyone should be able to accomplish that one.
I have been finding that this driver they built is sensitive to the 7135 regulation chip. So it could be that chip causing issues. TK is doing a lot of testing on that line, so she’ll probably have it figured out directly.
vulpes
vulpes's picture
Last seen: 38 min 22 sec ago
Is the resistance of a paper clip going to be a problem? I’ve found that I have to tigten the tail cap way to often.
Every time I need a light, tube is not making contact.
DB Custom
DB Custom's picture
You can always find a short piece of solid copper wire, like that in House Romex. The center wire from a bit of cable wire (Television cable, that solid center piece) works fine.
djozz
djozz's picture
vulpes wrote:
Is the resistance of a paper clip going to be a problem? I've found that I have to tigten the tail cap way to often. Every time I need a light, tube is not making contact.
The conductance of iron is lower than brass or aluminium but the path is so short (1mm) that you will not notice (compare to a steel spring: a path length of several cm)
realista
realista's picture
i received my unit but unfortunately i see that the base where is the led, it’s not with thermal paste, or at leats there is thermal paste but it is NOT attached to the aluminum pill of the head, so heat is not dissipate Sad
DB Custom
DB Custom's picture
realista, are you able to de-solder the leads on the emitter star and remove it? You can file off or sand off the edges so the star will fit better and then it will seat properly.
I have no idea why they made the emitter shelf area that tiny bit too small instead of the other way around.
Sorry to hear about the issues.
I gotta say folks, having just recently started working with a lathe (the BLF Lathe of all Lathes) I am learning that every tiny detail MUST be right or the other bits and pieces dont’ fit cleanly. It’s much more difficult than one might think.
realista
realista's picture
sincerely speaking….. i’m not convinced about the power of this flashlight. i compared it with my thrunite tn12 2014 and brightness is EQUAL …. but A6 white temp is something cooler than the “cool” tn 12 2014. The tint is too much cool…
and however i expected to see about 1350 / 1400 lumens as advertised ( and 1600 with mod spring) but i can tell you there is no real difference with 1000 real lumens from the thrunite.
sorry but as “not advanced “ user i only see a flashlightsold at good price 25 usd and about 1000 lumens….maybe i should had ordered the IMALENT DM21 …. at similar price ( after coupon) but at least microusb port and infinite output….
burnsd
Thanks for all the responses. I’ll try to cover all the points raised.
1. The paperclip spacer (hat tip to ToyKeeper) was a temporary solution to test the hypothesis that one tailpiece was shorter than the other two. In that role, it succeeded. I’m way too perfectionistic to treat that as a long-term solution. But I do appreciate the links to spacers providing a better compromise.
2. The two “shorter” battery tubes are both shorter in an absolute sense. They are specifically shorter in the section from the end of the battery tube knurling to the tail tip. As well, the length of the threaded section of the battery tube at the tail end is shorter.
3. Yes, I am certain the battery tube is oriented correctly. Still, it’s always good to check the easy solution.
4. I was able to combine sections of the three lights I purchased to form three functioning lights. My issues are: a) the concept of interchangeable parts, dating back to the third century, b.c. was violated, and (on a more personal level), b) if part of one of my lights fails in the field, I cannot replace it with the equivalent part of another.
I do appreciate the opportunity of this group buy, and in no way seek to appear ungrateful, or denigrate the good work done by the BLF members behind it. Honestly, thank you all. My issues are with the execution by the factory—??—in manufacturing tolerances, with the manufacturer—Manker—in assuring a wothy output is produced, and good faith of the vendor—Banggood—regarding the responsibility they assume in making these flashlights available to the end-user. I am optimistic about the resolution of all issues we experience. And I genuinely hope they address these concerns; both for selfish reasons and for the good it will do the community and Manker and Banggood.
5. By way of an update, I contacted heyanquing1@banggood.com and am attempting to have appropriately sized replacement parts delivered.
Pending resolution of these matters, I have friends who want to order some of these flashlights for themselves (because they are not getting mine!)
ToyKeeper
ToyKeeper's picture
I hadn’t heard of the TN12 before, but I looked it up and I think I might see what’s going on. The TN12 2014 seems to get about 12 kcd worth of throw, while the BLF A6 gets about 8 kcd of throw. So, the TN12 hotspot should be more intense than the A6 hotspot, even with fewer lumens.
Human eyes (and light sensors) can’t easily see a difference in lumens, only a difference in lux. To measure lumens you need an integrating sphere to spread the light around evenly.
Gunga
Gunga's picture
Ok
realista
realista's picture
i think my problem is just that the thermal paste was added and pressed, but the 2 wires are SLIGLHLY FORCING8 pressing) up… and then separate the star from the paste.
Maybe in production phase they won’t wait the right time the thermal paste becomes HARD…… so this problem occurs.
i need to desolder wires and then use some thermal paste, WAIT……….. then resolder wires trying to do a GENTLE CURVE which does “not push up” the led star base. is it right?
DB Custom
DB Custom's picture
When assembled, the reflector pushes the mcpcb down onto the shelf. The only way this doesn’t happen is if the mcpcb has rough edges/corners preventing it from seating.
So, yes, you might see it standing up off the shelf when you take it apart but when it’s put back together the parts are in the right placement.
And it’s not typical for thermal compound to harden, depending on whether an actual compound or adhesive is used.
I always cut the wires off so that they just reach the pads. No slack. Shortest wire possible for maximum current possible. If I need to disassemble it, I have to de-solder the leads.
KeepingItLight
KeepingItLight's picture
Last seen: 4 weeks 19 hours ago
Question 1
I bought two BLF A6s with tint 3D. One works perfectly, and the tint appears to be very close to white in white-wall tests. The other one is broken. Its moonlight mode does not work. In addition, in side-by-side white wall tests with the working flashlight, the tint is distinctly yellow on the broken one. In this test, both flashlights were set to one of the lower modes.
Is it possible that the broken moonlight mode has caused a tint shift?
(I checked carefully, and the emitter on the flashlight that has yellow tint has not been inadvertently dedomed.)
Question 2
Banggood offered 300 points if I am willing to keep the broken flashlight without repair. If I would rather have it repaired, Banggood has offered to send a new driver free of charge. Installation would be my responsibility.
Am I right in assuming that a replacement driver would not include a replacement emitter? What soldering is necessary to install a replacement driver, just the two leads that connect the driver to the emitter board?
Thanks in advance for any help you can offer.
