Test/Review of Keeppower 18650 3500mAh (Black) 2015
20 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 39 min ago
DSC_1147
Official specifications:
  • Capacity min.: 3400mAh
  • Capacity typ.: 3500mAh
  • Nominal voltage: 3.70V
  • Charge voltage: 4.20+/-0.05V
  • Standard discharge cut-off voltage: 2.50V
  • Standard charge current: 1000mA
  • Charge termination current: 50mA
  • Standard discharge current: 3400mA
  • Max. continuous discharge current: 8A
Keeppower%2018650%203500mAh%20(Black)%202015-info
This is a protected high capacity cell.
DSC_1145 DSC_1146
DSC_1148 DSC_1149
DSC_1150
DSC_1151
Keeppower%2018650%203500mAh%20(Black)%202015-Capacity
Very nice curves with good tracking. On one of the cells the overload protection trips during a 7A discharge.
My result is below rated capacity, some of the reason is probably because I terminate charge a bit early (100mA instead of 50mA) and do not discharge to 2.5 volt, only to 2.8 volt.
Keeppower%2018650%203500mAh%20(Black)%202015-CapacityTimeHours
Keeppower%2018650%203500mAh%20(Black)%202015-Energy
Keeppower%2018650%203500mAh%20(Black)%202015-PowerLoadTime
Keeppower%2018650%203500mAh%20(Black)%202015-TripCurrent
Keeppower%2018650%203500mAh%20(Black)%202015-Charge
Conclusion
This cell has about the same capacity as a 3400mAh cell, but handles load a bit better.
I will rate this cell very good.
Notes and links
The batteries was supplied by Keeppower for review.
Compare to 18650 and other batteries
Edited by: HKJ on 10/06/2015 - 04:33
akhyar
akhyar's picture
Last seen: 10 months 1 week ago
Thanks for your review HKJ.
Excellent, as always
I’ve this battery incoming from Banggood, so can’t wait to give it a go.
mongoose
Last seen: 1 day 22 hours ago
Thanks for the review hkj. Why would the batteries protection trip near the end of the discharge, and not straight away, any reasonable reason?
homer
HKJ
HKJ's picture
Heat. The trip level will change with temperature.
BigLEO
BigLEO's picture
Last seen: 4 years 1 month ago
thanks for the nice review HKJ
i came across this tool….
http://lygte-info.dk/review/batteries2012/Common18650comparator.php
if you do comparisons:
KP 3500mah VS 3600mah
KP 3400mah VS 3500mah
very bit of capacity improvement but there is improvement Smile
malkoffdevices
malkoffdevices's picture
Last seen: 5 hours 54 min ago
Thanks to HKJ.
I am in the UK , but where can these be purchased from I did try a illumn but it seems they’ve been broken into a while ago so I think that’s quite slow at the moment right?.
It’s costing me USD$41.00 shipped to london.
Any place better?.
by the way these will be used in a HDS Clicky.
Thanks.
London !
superjing
superjing's picture
you may get some helps at https://www.akkuteile.de/
bwl123
bwl123's picture
Last seen: 2 months 20 hours ago
elzetta_dy wrote:
Thanks to HKJ.
Any place better?.
Thanks.
The Keeppower is a rewrap of this:
https://www.fasttech.com/product/2399300
superjing
superjing's picture
hi, as you use this battery in flashlight, a protected Li-ion battery is always recommended.
i donnot recommend you use unprotected Sanyo ncr18650ga Smile
fyi:
http://lygte-info.dk/info/isMyBatteryProtected%20UK.html
garrybunk
garrybunk's picture
Last seen: 4 days 4 hours ago
bwl123 wrote:
The Keeppower is a rewrap of this: https://www.fasttech.com/product/2399300[/quote]
Is this true?  The button top looks different. If not, which cell is used in this KeepPower?
EDIT - It looks to be the LG 18650MJ1, is this correct?
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
akhyar
akhyar's picture
EDIT – It looks to be the LG 18650MJ1, is this correct?
-Garry
The button-top on the Keeppower definitely looks different as the stock Sanyo GA and LG MJ1 are flat-top batteries straight from the factories.
As the spec sheet of this battery at Keeppower website listed this cell is Made in Japan, we can assumed it is the Sanyo GA
Keeppower 3500
Normally Keeppower will list the cell’s country of manufacturer for their batteries, for eg. they have 2 types of protected 3200 batteries, one is listed as cell Made in Japan (Panasonic BE) while another listed as cell Made in Korea (LG E1 4.35v).
Their IMR 3200, which is listed as cell Made in Japan is most probably Panasonic BD since it has continous discharge current of 10A
garrybunk
garrybunk's picture
Thanks for the info!
-Garry
SubLGT
Last seen: 1 hour 28 min ago
The protected EVVA 18650 3500mAh battery (with the GA cell) has very similar discharge curves (on the HKJ Comparator) to this Keeppower, at loads of 3A and under. But at loads above that, the EVVA has noticeably less voltage sag, presumably because of a higher current protection circuit.
vestureofblood
vestureofblood's picture
Last seen: 18 hours 52 min ago
HKJ, I bout a west mountain Radio CBA IV to test cells with. When I do I keep getting these little “squiggles” at the very end of each line of the the chart. Its like the machine lets up off the test and then starts again leaving that little ripple at the end. Do you know how I can eliminate that?.
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
HKJ
HKJ's picture
I did use a CBA for my first battery tests (2010 & 2011), but do not remember any squiggles. If the CBA continues to record after the current is stopped you will get a raising voltage, is that it?
vestureofblood
Here is what it looks like. These were nimh 1.2v cells
fluke
Last seen: 23 hours 36 min ago
I am very far from knowing much on testing, is that not the battery voltage rising as HKJ said?
vestureofblood
Yes. What I need to know is if its possible to squash that. There is a setting I found that says something to the effect of “rebound voltage” (don’t have it in front of me at the moment) but regardless of what I set that to this still happens.
HKJ
HKJ's picture
It looks like you may be out of range. 0.6V is rather low and the load may do strange things at that voltage (That is said without checking the specifications).
When testing significantly below 1V you have to know what you are doing, a lot of test equipment may fail or give wrong results. There are a couple of reasons for that.
vestureofblood
HKJ wrote:
It looks like you may be out of range. 0.6V is rather low and the load may do strange things at that voltage (That is said without checking the specifications). When testing significantly below 1V you have to know what you are doing, a lot of test equipment may fail or give wrong results. There are a couple of reasons for that.
I will try running the test at 0.7-0.8 and see if that helps Smile
