I thought it was time to share some machining images... building 7 of these and talked sweet thing into pushing the button on the camera a few times. These are just various stages of the process on the first couple. I'll try to add some more as I can. Enjoy!
Some just cut off at the saw... other chunks well on the way.
Ready For Threads...
like magic!
Looks about right.
Facing off the other end...
Making room for the boring bar....
I managed to grab another image... This was taken last week. I had to install a new hot water heater...and go see a customer... back at it this week.
Electronics installed on one. One more to go. Then it is time for heads and tails!! These are just three mode... lo-med-high. The pill is partially screwed in here so you can see. Five more screaming to get started.
10 /17 update!
I am behind on the postings... hang in there with me.
Worked on the heads for the lights last week...
Bored the inside to the proper minor diameter for threading. 1.216" was the target... got close!
I have to take out a little in the front for o-ring clearance. about .022". EDIT.... .032" deep. This keeps the o-ring from rolling around when the head is screwed on.
There always seems to be a lot of interest and questions about threading. Here are the two internal threading tools I use the most. Notice the inserts face opposite directions.
Using the tool on the right in the image above, the stock rotates toward you standing at the lathe as the purple arrow shows. The tool starts from the outside of the stock and cuts the threads as it moves inward as the yellow arrow shows. This is the "Standard" way to cut threads. Good...but can be a little daunting sometimes if you are cutting to an internal shoulder...or as called "Blind Hole". Easy to crash a machine doing this.
The tool on the right two images up cuts just the opposite of the one above. The spindle is reversed, and the stock rotates away from the lathe operator as shown by the purple arrow. The tool cuts the threads from the inside out as the yellow arrow shows. This can save a tool and part when threading to that internal shoulder or blind hole. As well... there is no hurry in dis-engaging the threading lever. Much easier!
Another benefit is that most of the time uhhh.. sometimes...ummm...now and then when it wants to, the tool pulls out the swarf when it comes out. This is nice when it happens!!
So... you end up with this...
They really need to screw together!! Where is that pipe wrench??
Need a hammer over here!!!! Big One!!!
OK... here are the ending images for this line of flashlight / machining porn. I shot these images a week or so ago but have been covered up in the shop. This is the original light and two new ones. I hope you have enjoyed the little journey as much as I have taking you along. Thanks to each of you for putting up with me!
Looking down the barrel!
I dislike the green tail covers but the buyer is the boss.
They make light! Who would have thought!
They even work in the dark!
They work after hours too!
They stand up...
And... stack up to some point. ...
more of these to build... I can almost do it in my sleep.
Thanks For Looking.
Ending here for now. TL
