For sale: High efficiency 365nm 3535 UV LED,ZWB2 20x1.5mm filters
35 posts / 0 new
led4power
led4power's picture
Last seen: 2 hours 6 min ago
Update 15.12.2015.
Shipping price is now separated,no minimum orders for EU,25$ minimum for rest of the World(excluding shipping).
Specifications
Led type: SMD 3535
Led color : Ultraviolet
Chip(die): Semileds
Package size: 3.5×3.5×2.0 mm(XP footprint compatible)
Dominant wavelength: 365-370nm
LED Power rating: 1W
Forward current: 350mA
Peak pulsed current: 700mA
Typ. forward voltage: 3.5V
Typ. radiometric output: 410mW(+-7%)
(If=350mA,Tj=25C)
Viewing angle: 120deg
Operating temp. range: -20~+80C
Already tested by djozzTM Smile here : http://budgetlightforum.com/node/42424
Great review as usual,so I want to thank djozz once again,and I will copy/paste just his conclusion about this LED here:
"Conclusion: I think this led is a great one, the UV-output is at least close to 365nm and the amount is impressive, more than the Nichia NCSU276A U365, and it comes from a small XP-E size die, so it can throw as well if you like that. The only drawback is the large amount of visible light it puts out as well, like most 365nm leds btw. I solved that by using a UV-pass filter, but these filters cost some money, between 10 and 20 dollars.
Thanks for reading!"
So this LED has efficiency similar to high-end UV leds like nichia 276A,or about 3 times more than decent lower cost LEDs like mentioned RY3535UV,or 10-15 times more than cheap ebay UV leds!
Notes:
*Power rating of this LED is 1W (350mA),so overdriving affects led characteristics like lifetime and wavelength,just like in case of white leds.According to djozz's tests,it seems that max./optimal driving current for this LED on Noctigon should be around 700mA.
*This is budget/low cost LED,so there may be tiny imperfections like little off-centered die and dust on lens that doesn't affect output of this LED.
Price:
5.9$/piece
_______________________________________________________________________________________________
ZWB2 20x1.5mm filter lens
Price:
1.9$/piece
Shipping: Priority airmail shipping(pretty fast):  +2$
               Tracking number option:  +5$
Estimated shipping times:
EU  3-5 days
World 5-20 days
Paypal fees-included
Paypal and contact/info: led4power@hotmail(dot)com  (replace (dot) with .)
Note:for Italy only tracked shipping is available
Thanks
Edited by: led4power on 12/15/2015 - 15:31
Jubeldum
Jubeldum's picture
Last seen: 1 year 11 months ago
Why don’t you post the datasheet for this LED?
led4power
led4power's picture
Upper mentioned specifications is only what I got,but that’s why I sent few LEDs to djozz,his tests show much more than any datasheet could do Wink
Bribo
Bribo's picture
Last seen: 2 min 24 sec ago
Payment sent for 2 of these bad boys.
Thanks,
led4power
led4power's picture
ZWB2 20x1.5mm filter lens added.
LVLII_James_B
LVLII_James_B's picture
My question is, Would one use both the UV LED AND the Filters?
Or does the LED emit enough light?
I really don’t want to sound repetitive in my questions..but I am trying to garner enough information to justify to my company to invest in me purchasing medium sized quantities of parts to create inspection lights.
I “purchased” one UV light already, but it emits to little UV be used in our inspection. The requirements for Black Light inspection is 1000 u/cm² at the work surface (about 15 inches). The one I have is about 200 u/cm²…
I have located this LED, already on a board..
LED Engin LZ1-10UV00-0000 – Single Color Ultraviolet 365nm Emitter w/starboard
http://www.mouser.com/Search/Refine.aspx?Keyword=897-LZ110UV000000
1: $35.48
10: $31.35
25: $28.14
100: $23.93
I do not know if this is a decent price per 25.
James B. LVL II -UTSW,VT, MT, PT
Guided Wave Data Analyst
Never argue with Idiots, They will drag you down to their level and beat you with experience.
keltex78
keltex78's picture
Last seen: 1 hour 24 min ago
Yes, you would use the UV filter with the UV LED to filter out the excess visible light that is emitted along with the UV. I installed one on my 365nm UV light and it really makes fluorescence punch. Enjoy a nice walk through your bathroom for a fun time… Even walking through the house… Every particle of dust glows.
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
LVLII_James_B
hah..I would rather not…I am not OCD and would prefer not to become one!
vex_zg
Got my UV LEDs, very fast shipping. Great LEDs!
I fascinated by the amount of UV light/fluorescence it creates. My kitchen and bathroom look absolutely hideous.
PH_Oton
PH_Oton's picture
Last seen: 17 min 33 sec ago
PM sent.
Henk4U2
Henk4U2's picture
Last seen: 17 hours 55 min ago
Working with these tiny objects for me is like trying to push a camel through the eye of a needle.
Is it possible for you to send me a led on a (16mm) Noctigon? And if possible, what would be the price for a led+board?
I always think long and hard before I say something really stupid.
djozz
djozz's picture
Last seen: 26 sec ago
It is easiest if led4power does this for you, but if not, I can reflow the led for you also.
led4power
led4power's picture
If you asked me,yes just tell me which noctigon,16mm or 20mm(+2$).
Henk4U2
Henk4U2's picture
led4power wrote:
Henk4U2 wrote:
Working with these tiny objects for me is like trying to push a camel through the eye of a needle. Is it possible for you to send me a led on a (16mm) Noctigon? And if possible, what would be the price for a led+board?
PM and PP sent.
Best regards,
Wim
Henk4U2
Henk4U2's picture
Earlier this afternoon the mail(wo)man delivered:
- a tiny UV-led, spotless flowed onto a 16mm Noctigon
- covered with a minuscule “jock-strap” to prevent it from damage
- packed in a small anti-static bag, sealed,
- packed in a small bubble bag, sealed,
- packed in a bubble-lined envelope.
A quick test with my DMM led to the conclusion that everything was OK.
So if this build leads to something less than expected, I only can blame it on myself Wink
Thank you.
-X3-
-X3-'s picture
Last seen: 5 hours 14 min ago
Sooo I bought one of this emitter, along with a ZWB2 glass and put it together in an S2 with a 2*7135 Nanjg driver.
Here are some crappy pics of it :
Random emitters :
Glow paint :
Plastic tool handle (sorry…) :
Tail light of my bike :
Garage sink (ugh) :
Highlighter ;
Snowboard :
Phosphor is reallty glowing with that UV :
Thank you led4power !
If you could source some 10mm ZWB2 glass I would make a nice pocket 348 with this LED !
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire : 30+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
-X3-
-X3-'s picture
So… Gearbest seems to be worse than I imagined, they used one of my pics above to make a false review of the ZWB2 lens they sell :
Bluecvbc
Last seen: 10 months 3 weeks ago
Paypal sent for 4 leds and two lenses
THANK YOU
Zelda
Last seen: 7 hours 11 min ago
Paypal sent for one led and one lens.
Thank you Smile
Zelda
I already got it Thumbs Up
The dot on the top side is which polarity?
led4power
led4power's picture
Side where are thin gold wires (you can see them through lens) is cathode (-).
Jerommel
Jerommel's picture
Last seen: 2 days 1 hour ago
These still available?
I want one LED and a filter.
(i’ll PM you)
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
led4power
led4power's picture
PM sent.
-X3-
-X3-'s picture
Still available ? I might buy one LED + filter for a BLF 348 conversion…
led4power
led4power's picture
Yes.
Nicolicous
Nicolicous's picture
Last seen: 9 min 11 sec ago
So how much for the uv led with shipping to Australia?
led4power
led4power's picture
5.9$ +shipping (see OP).
Jerommel
Jerommel's picture
I got the LED on Noctigon and a filter in today. Smile
LED tested and works, now to find a host for it..
LuxLumen R.G
LuxLumen R.G's picture
Last seen: 6 days 31 min ago
How much for 3 leds shipped to USA? Thinking of building a triple S2+. Is the lens a 20mm?
LuxLumen R.G
Sorry I just seen the lens size. So I would like 3 led and one lens if still available and the price is right.
led4power
led4power's picture
Don't have these LEDs anymore. Optics made from "plastic" materials (like PMMA,polycarbonate) block almost all <400nm light - it won't work with standard carclo/ledil optics for triples.
