Easy Mini MAGLITE 2-Cell AA Mod *now includes pictures and build details*
I have been itching to do a simple mod of the venerable Mini Maglite 2-Cell AA flashlight and think I have come up with one of the simplest and cheapest true mod, not just an off-the shelf LED module replacement.
Here are some features:
  1. aluminum pill that can fit 16mm round MCPCB
  2. boost driver to use 2 AA cells with current limiting to boost battery life
  3. frosted TIR with nice flood
  4. same twist operation
Estimated cost is $6.
Details of build with pictures will appear soon. I’m posting this as a teaser for now.
11/3/2015
This is my first build post on BLF. I’ve learned a lot from reading many other fantastic builds so this is a way to give back.
First the final product:
Beam shots:
Here are the build steps illustrated using a new mini maglite.
The pill and driver were taken from a cheap AA zoomie that can be had for $1.99.
So much for DO NOT REMOVE.
The mini maglite looks like this disassembled.
The top of the battery tube original and after 1 minute of sanding.
Here is the bezel with a gasket I cut from an old 35mm film canister holder.
The pill was a perfect fit! I added a spring to the driver.
The lens is also a close fit. This second mini maglite might end up as an non-zoom aspheric.
Here is a 21mm frosted TIR I got from led-dna on ebay. It is shown next to original reflector and XP-G2 7A LED replacement. This particular TIR is perfect for this build because it is shorter than the other TIRs I have. This is critical because of the little clearance in the mini maglite head.
Here is a closeup of the driver, which originally had three modes. I removed the mode controller chip and replaced it with a 7135 linear constant current regulator. This light is intended as a gift so I want it to last longer on 2 AAs. Even with 350mA to the LED, it will be brighter than the stock light.
This pill is hollow so I added some Artic Silver Ceramique 2 to help a little. But it should not have heat problems with 350mA. I had to widen the plastic spacer with a 5/16” drill bit to better fit the TIR. I made a poor attempt to make room for the soldered connections.
That’s it for the pictures. Here are some final notes.
I bought two cheap zoomies: one black and one golden. One of them, I forgot which, came with three modes and what looks like a genuine Cree XP-E. The other came with a one-mode driver with a genuine LB POS.
I used the XP-G2 7A because I have several and thought this is a good project for it to maintain the incandescent look of the original Maglite.
For the cheapest build, just use the pill as-is and the cost is $1.99. Add $0.40 for the frosted TIR.
The pill qualifies as a drop-in so you can build several pills with modes, different tints, different LEDs, etc.
got me
Oh, I want to see. Subscribed
subscribed!
Subscribed. Thanks, always interested in a budget 2AA mod.
same here, need to see. :slight_smile: i have several 2-AA mini mags that i need to mod.
It’s not April Fools you know, it’s November!
I have a 2 AA mini mag light. And I want it brighter. Subscribed.
Subbed… Looking forward to this…
subscribed.
Well count me in too. There’s like half a dozen of those things around here and they could use some attention.
Wow. $6? Cool.
subscribed.
The full build post is now up.
Very cool mod! :slight_smile:
Hey, I have a few of those cheap zoomies around. I wonder if this will work with the Harbor Freight cheapie Mag clone. I may have to find out. I don’t know if I’d want to buy a real 2AA Mag just to do this with. Maglite is real proud of their flashlights. :money_mouth_face:
You should post a link in the Modding links thread so it doesn’t get lost in the annals of BLF.
Golf clap!
Well done, well done…
I just looked around, and it’s basically $15 just for a new 2xAA Mag Mini. Anybody know where it can be bought for (significantly) less than that?
When I first started modding them they were $8 but still only $10 at Freidmans. A small flat rate box will hold several(more if out of the blister pack) so it should be possible to get 6 or more for $11 each. A while ago I sent a package to EU with blue and red 2D and 2AA lights. 6D’s are about $30.
