ENEDED
436 posts / 0 new
Tom E
Tom E's picture
Last seen: 4 hours 42 min ago
Me too, I'd like to see all 3 compared side by side as well Smile.
finges
Last seen: 15 hours 57 min ago
Sirius9 wrote:
Kinda missed the part that XHP35 is 12V only, doh, thought it was a 6V like rest of the XHP family.
Also, can’t find that thread atm, but new single cell boost XHP driver is on the way, for 6V leds of course.
Idea behind the XHP35HI was to get more lumens than you would get with XML2, a bit wider beam, but not to lose on throw.
Can you please pm me the link to the thread about the boost driver if you found it?
pilotdog68
pilotdog68's picture
http://www.budgetlightforum.com/node/43955
pilotdog68
I recently found the Solarstorm R60T. It seems to be pretty close in size to the BOSS, but I couldn’t find any reviews on it
http://www.banggood.com/Solarstorm-R60T-6x-CREE-XM-L2-U2-4500LM-5Modes-Handy-LED-Flashlight-p-967846.html
wkhchin81
Last seen: 2 years 3 months ago
My second BOSS1 from Tao Bao modified with XP-L HI “V5” 3B from fasttech, unluckily not a V5; which only produces approx. 950 lumens under one fully charged LG HE2. (under the same DD, KD’s XP-L V3 1C I had before produces >1100 lm)
BOSS1 (left ~900 lm) compared with TM36 Lite (right ~1200 lm), same distance; BOSS1 beam measured with slightly higher intensity (~3 %) at ~ 3 meters distance.
My TM36 Lite only produce approx. ~1200 lumens (although LCD shows 1800 lm, my 18650 parallel not able to push upto 1800)
CWK
will34
will34's picture
Last seen: 1 hour 19 min ago
Thanks, pretty amazing results. I’m sure it will beat an stock tm36 lite with a more extended build and using 4 batteries.
wkhchin81
BOSS1’s reflector may be not as deep as TM36 or even TK61, but what I discovered is the beam angle is nearly 0 (zero). At shot distance (3 m) the beam spot is similar to TM36, but when shooting far at ~200 m the spot is smaller than TM36.
The wall is approx.110m away. Both photos taken by iPhone.
CWK
eebowler
eebowler's picture
Last seen: 3 months 4 weeks ago
Dude! That pic is BADDDD for my pocket! ;(
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
Tom E
Tom E's picture
Well, here it is for $55: http://www.gearbest.com/led-flashlights/pp_294539.html, seems like it was added yesterday.
johny723
Last seen: 7 hours 56 min ago
according to gearbest specs it can be used with 5 × 26650 cells. Is that true?
edit- no it cant, I just found this picture by W K CHIN https://www.flickr.com/photos/wkhchin81/24192819625/in/photostream/
Tom E
Tom E's picture
johny723 wrote:
according to gearbest specs it can be used with 5 x 26650 cells. Is that true?
That's funny -typical of them. Guess they saw the pic of 5 contact points and assumed it could take 5 26650's. Only GearBest... Smile
No - 4 at a time max. If you got 4 26650's in there, the center contact area can't fit a 26650 or a 18650 or a 17650. You can use the center slot though for one cell, which is kind of cool. You might fot 5 18650's if you could mod 4 26650->18650 adapters, didn't try it, but might work.
The 90 mm UCLp should be here in two hours, so this eve I'l be re-testing at 12.5 meters.
Hobo
Last seen: 16 hours 13 min ago
This Monster is more like a laser pointer…
8) Lube Threads Everyday 8)
johny723
are you still testing the xp-l led?
Tom E
Tom E's picture
Hobo wrote:
This Monster is more like a laser pointer...
Well, bigger the reflector, tighter the beam, longer the throw. I kind of like it with the XP-L dedomed, should be same beam width as dedomed XM-L2, but I smoked the dedomed XM-L2 U4 1A. Apparently the XP-L's can take more amps, or maybe just lucky with the XP-L?
Yes - still XP-L dedomed.
Guess this puts the pressure on BangGood. I can get the BOSS1 for $47.89 w/347 points deduction with free shipping via America Direct Express. I rarely order anything from GearBest without a discount code, so I've accumulated a bunch of points.
The GearBest code of MAXY works but raises the price. the regular price for the BOSS1 will be $61.55, dunno how long it will be available for $55
freeme
freeme's picture
Last seen: 11 hours 53 sec ago
Smart move Cool. I will ask for ask their price too.
will34
will34's picture
That beamshot brings hope to achieve near-DEFT level performance under 100 bucks, and getting higher OTF output at the same time. With a taskled H6Flex driver I smoked a domed U4 1A at just 5A, but the XP-L HI V2 1A managed to survive up to 6.5A (with performance loss after).
Looking to see your results Tom
johny723
seeing such results with xm-l2 and xp-l emitters makes me wonder what could be achieved with a properly focused xp-g2…
Tom E
Tom E's picture
johny723 wrote:
seeing such results with xm-l2 and xp-l emitters makes me wonder what could be achieved with a properly focused xp-g2...
Not just focusing, but power. If I could come close to what Mitko gets from FT XP-G2 S2 2B's (5.5A, even higher he mentioned), I'd be happy. But at 4.0A or 4.2A, the XP-L would probably still beat it.
The UCLp did just come, along with parts desperately needed from Richard Smile.
johny723
I dont give up on xp-g2s yet, these leds have outperformed both xml and xpl emitters in terms of throw in virtually all other flashlights, it is very unlikely they do not work in this particular case.
Tom E
Tom E's picture
696 kcd max, maybe a steady 685 kcd with the UCLp lens, measured at 10m. 685 kcd is 1655 meters, 5430 feet, 1.03 miles.
One sort of problem - I measured the stock lens at 89.6mm x 2.04 mm and it's a tight fit. the UCLp I requested was 90.0 mm, and measured precisely with my digital caliper at 90.0. All UCLp's are shipped with this blue plastic protective stick-on coating, so with the coating on, I used my rotary tool and brought it down to about 89.80 mm, then it fit fine.
I was hoping the 2.25 mm thickness of the UCLp would tighten things up (0.21 mm thicker than stock), maybe get a better focus, but it had the opposite effect - initially with it all tight, I could not break 600 kcd. Loosening up the bezel bumped it up big time, so it seems like the best focus point is a little further out of the reflector, not further in, if I understand the dynamics. I may need to bump up the height a little now - could use a stick-on type of ring - the 3M type, that the centering piece can sit on.
Hoping I got time for this but my plans would be:
  • put copper extensions on the MCPCB pads to clear the reflector base
  • add in a driver and use 18 AWG LED wires
  • I got 2 brass screws holding the shelf down now - add 2 more, total of 4
It's not an ideal heat sink setup, but it seems to be working pretty well. There isn't much output droppage in short runs.
Mitko
Mitko's picture
Well, a regular well focused FT S2 1A( the cheaper one , they have too s2 1a in their store, the cheaper is the better) driven at 4.4 amps gives like 10% more cds of the XMP/XPL champion at 6 amps – V6 1D( still havent tested V6 1A/V6 2D) -a hard driven s2 2b is maybe >25% better, you can see the difference even with a naked eye – and its an observation of literaly dozents builded C8s
That “thing” has been ordered ofc Smile Cant miss it, it could be made a great search light, great indeed…too bad onone of the GB codes that i have worked :/
Tom E
Tom E's picture
Yea, I'm taking a big chance with the FT XP-L V6 0D, but seems to be performing well.
Measured amps again and I'm getting 6.08A - this is after I cleaned up contacts of the DMM wires and banana plug connectors though (before I got 5.95A), but cells are as-is, not freshened, when I did my throw measurements this evening.
Mitko - cool you ordered one! Love to see your thoughts and results. Certainly should hit over 700 kcd, and running a dedomed XP-G2 at over 5A I would think could hit over 800 kcd.
Tom E
Tom E's picture
pilotdog68 wrote:
I recently found the Solarstorm R60T. It seems to be pretty close in size to the BOSS, but I couldn't find any reviews on it http://www.banggood.com/Solarstorm-R60T-6x-CREE-XM-L2-U2-4500LM-5Modes-Handy-LED-Flashlight-p-967846.html
Looked at it - interesting, more like a classic SRK setup. Hope those are screws holding down the driver contact board, and hope it's not glued - I don't see a driver retaining ring. Kind of pricey, but of course it's a SolarStorm so maybe decent quality, plus all those emitters, side switch is great of course. Head diameter is slightly smaller, maybe about a Shocker size. Should be throwy, because with 6 LED's, the reflectors have a decent size. The Shocker is bout equal to 3 C8 reflectors, and I measured close to 600 kcd on one of them, in 500's on most, all with dedomed XM-L2 U2 1A's getting over 5A to each LED.
The 6-9 days for shipping usually means they don't have them. With BG, that time scares me because it can slip way longer.
pilotdog68
I imagine the driver is press-fit/glued like the Solarstorm SP03. The R60T looks like the perfect companion for the SP03. If I win the powerball, that’s the first light I’ll get
Pok
Pok's picture
Last seen: 10 months 10 hours ago
$78.19 ????
http://www.gearbest.com/led-flashlights/pp_294540.html
Sirius9
Sirius9's picture
Last seen: 6 hours 58 min ago
Pok wrote:
$78.19 ????
$55 without the charger and cells…
$78 full pack
Pok
Pok's picture
Sirius9 wrote:
Pok wrote:
$78.19 ????
$78 full pack
I got it, Thanks Wink
FmC
FmC's picture
Last seen: 1 month 17 hours ago
If you are getting close to 700Kcd with an XP-L, I'm betting an XP-G2 will be pushing 900Kcd.
Mitko
Mitko's picture
FmC wrote:
Tom E wrote:
Yea, I’m taking a big chance with the FT XP-L V6 0D, but seems to be performing well.
Measured amps again and I’m getting 6.08A – this is after I cleaned up contacts of the DMM wires and banana plug connectors though (before I got 5.95A), but cells are as-is, not freshened, when I did my throw measurements this evening.
Mitko – cool you ordered one! Love to see your thoughts and results. Certainly should hit over 700 kcd, and running a dedomed XP-G2 at over 5A I would think could hit over 800 kcd.
If you are getting close to 700Kcd with an XP-L, I’m betting an XP-G2 will be pushing 900Kcd.
Well, you wont get any bonus using XPG2 in that case even using a nice scope , just less lumens, its like TK61 – when modded with V6 1D it gave arround 600k mcds, using XPG2 it gave 820 but it was a downgrade from my point of veiw:i could see jackal eyes at 2.5 kilometers with both setups yet the XPL hotspot covered a larger area
Tom E
Tom E's picture
Mitko - I tried two more XP-G2 S2 2B's from FastTech on copper MCPCB's last night, and again, can only get about 4.2A max on a direct wired, no driver, soldered up bench setup using a LG HE2 @4.22v. Did not even dedome them yet. Now I looked up when I ordered these, and it was back in Aug and Sep 2014 - 1 1/2 years ago. Wonder if the newer batch's performed better? I got slightly lower amps on a Samsung 30Q @4.22v, so figure the HE2 cells do good. My old SONY VTC5's always do worse than the HE2's and 30Q's, think I spot checked one and performed lower.
I ordered qty 3 more of the FT XP-G2 S2 2B's over the weekend, just to see if latest batch FT has is any better. How are you reflowing yours? I've been using a butane torch as of late - quick method. I used to use a frying pan and bring up the heat slowly, similar to what CREE recommends. No idea if one method is really any better than the other...
I hear you bout the small XP-G2 hot spot. I recall guys complaining about the tight hot spot of the early OSTS version of the TN31 using a XP-G2. I kind of like the results I got with the XP-L, and now that's it's solid over a mile, I'm pretty happy with the results.
