ENEDED
436 posts / 0 new
johny723
Last seen: 4 days 15 hours ago
could someone post a photo comparing hotspots of both xp-g2 and xm-l2 in the same reflector?
scotlarock
Last seen: 17 hours 31 min ago
Tom, based on Mitko’s results I went ahead and ordered 8 S2-B2’s from FT. Also ordered 4 from Mtn. After I received them I hot de-domed 1 from each supplier. I, like you, was only able to achieve around 4.2-4.3a. Not sure what to make of all of this, but would like to figure it out.
Tom E
Tom E's picture
Last seen: 2 hours 40 min ago
Oh boy, think you mentioned this before - totally forgot. I trust Mitko but I would certainly like to understand what's goin in.
DB Custom
DB Custom's picture
Last seen: 1 month 1 day ago
Fenix TK 61, with XP-G2 de-domed vs. XP-L de-domed
XP-G2
XP-L
I worked hard on this particular light, had issues with current spikes frying emitters, tossed 8 XM-L2’s in the trash. Traded it off to Richard with a 32mm Noctigon sporting the de-domed XP-L emitter doing up close to 600Kcd. Hate plastic reflectors.
pilotdog68
pilotdog68's picture
Last seen: 11 months 1 week ago
Yeah I never had any crazy results from those S2-2B’s either. I’ve never had any XP-G2 go over 5amps. Recently I started ordering their S2-1D’s because I like the tint better.
johny723
is there a driver that will drive them ( the xp-g2s) over 5 amps AND is small enough to be used in the boss1?
Tom E
Tom E's picture
Well, think I posted earlier - there is some vertical room, so it's not all that bad. Problem is you need a high amp boost, or high amp buck driver and somehow manage cells in series, like a big battery mod done by CWK above, or using 4-5 pair of 18350's (might fit 5 pair, but 4 definite).
I think if we used a zener mod FET driver with a 2S setup, there would be too much voltage to burn off - not sure, others may know better.
pilotdog68
Yeah you can’t use a zener FET 2S on a 3v emitter, it would fry instantly. The emitter would get the full 8.4v.
Tom E
Tom E's picture
If somehow this driver: http://budgetlightforum.com/node/43955 could be cranked up to 5A or so to the LED and output voltage reduced, it would be a great match for this light. You could make the driver diameter much much bigger for the BOSS1 - width is no problem at all Smile.
Dale - that's a great example. I don't have two de-domed matching lights, least I know of off hand. I thought though there would be examples around, maybe going way back: rdrfronty, relic38, ILIKEFLASHLIGHTS, RaceR86 etc., plus a few others that posted some real classic stuff. One guy who did mostly de-domed throwers had some great beamshot posts, think from Eastern Europe -- he was pioneering de-domed LED's at the time I thought, and had some great comparison shots.
Edit: Found it!! It's viffer750, shots here: http://budgetlightforum.com/node/14327.
But this is one of rdrfronty's classic, lists a XP-G2 and XM-L2 TM31, both dedomed: http://budgetlightforum.com/node/29808 (I did the XM-L2 dedome Smile).
FmC
FmC's picture
Mitko wrote:
Well, you wont get any bonus using XPG2 in that case even using a nice scope , just less lumens, its like TK61 - when modded with V6 1D it gave arround 600k mcds, using XPG2 it gave 820 but it was a downgrade from my point of veiw:i could see jackal eyes at 2.5 kilometers with both setups yet the XPL hotspot covered a larger area
Yes, XM / XP-L is much more practical, as Dale's photos above illustrate.
pilotdog68 wrote:
Yeah I never had any crazy results from those S2-2B's either. I've never had _any_ XP-G2 go over 5amps. Recently I started ordering their S2-1D's because I like the tint better.
The XP-G2 S4's seem to do well. With the testing I've been doing recently on the KD86mm reflector, I have one running at a solid 5.4A (slightly higher on start-up), & that's measured through the DMM, so likely to be higher (roll out the clamp meters...).
I tried a little over 6A, but popped one straight away. I'm betting it's the spike at turn-on which pushes it over the edge.
Got some replacements coming in from IOS Smile
Mitko
Mitko's picture
Last seen: 6 months 1 week ago
Yeah, great photoes Dale, actualy TK61 is my main hunting searchlight atm- it has ultimate range and aint that heavy to carry: you can clearly see everything in a 2km range with a 20x scope
Yet, for C8 XPG2 is the better option, it like you have M2x but smaller, lighter ad way more pocketable- they gone crazy here about XPG2 C8s you know, to a level at whitch i dont have more place to store the hosts:
And here comes S2 2b- i dont know what are you guys doing but i got above 5amps every time, measured with the same DMM i have never measured above 5amps using U4 1C: and i dont do a spring bypass anymore, above 5.5amps is “scary” on a long term base – yet this sucker is tought, i dont have a dead one so far( from many builded)
Curretnly using in mass He2 as 25r price rose alot here, yet He2 one is under 3 euros whitch is strange as long as its the same or even better option
Hehe, the story of my life, i killed 4 XPLs too but thats the sweet part of being a BLFer , right Dale? Smile
That actualy was one of the hardest mode i ever done, i took like 20 hours or more to complete it like it should look but at the end i have line 8 ppl constantly tormenting me to make something like this
Tom E
Tom E's picture
What exactly is the setup for the 5.4A you are getting? Is it a FET DD driver? big wires? Parallel cells providing voltage input?
I have no clue how to get or see over 5A on any XP-G2 so far without going to a buck driver, that's why I'm trying to figure this out. I'm not alone on this. Maybe it's how the reflow is being done?
Typical max amps I get on DD FET setups:
XP-G2: 3.8A - 4.2A
XM-L2 new gen: 5.2A-5.35A
XP-L: maybe little higher than XM-L2 new gen, 6.35A in this BOSS1 is the highest, but no driver
XM-L2 old gen: ~6.5A (XM-L2 T6 4C's seem to get this - could be an old batch)
Mitko
Mitko's picture
The best i did with a IOS S4 2b and a FED DD driver was 4.8 amps:a fresh Efest 4200, 18 awg wires and a spring bypass ofc: yet i dont have much exp with this emitter, used only like half a dozen, still got 3-4 pcs in the cache though
Tom, it seems that IOS V6 1A is good too, unfortunately its price isnt, i still dont have KD V6 1A to compare with but the IOS tint is better than U2 1A and 6amps are reachable
Ios V6 1D were great indeed, wonder when shall we have them again
pilotdog68
Tom, those numbers are close to what I usually see. Actually yours are a little higher than what I get with the XM-sized dies. I’m really hoping I’ll get this clamp meter and suddenly all my readings will be way higher than I thought this whole time.
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 37 min ago
I can’t get anything over 4.2amp (3.8-4.0 avg.) either on the S2 2B (5) of them from FT, and (6) that I had laying around and can’t remember what they are any more, running 2’‘ 18awg directly to any battery… Imren 26700’s P-Efest 3500 P-Efest 4200 VTC5’s 30Q’s 25R’s Using a Fluke 36 clamp on, Klein clamp on, Klein DMM 10awg Leads? Highest reads are all way’s from the Fluke 36, but Big deal .2? I’m just happy as HELL it’s not only ME!!! :bigsmile:
KB1428 “Live Life WOT
johny723
I have found this vid by Djozz https://www.youtube.com/watch?v=I3oMm-jFSy8 . It shows how the Vf increases with the current. Could it be that xp-g2s at higher amps have too high Vf, thus making it almost impossible to drive them at 5a from 1s? It needs around 4V to run on 5A, which is quite high voltage even for 4p cells (maybe my stupid suggestion again, but what difference would 5p 18650 4,35v cells make???)
could someone measure not only the current, but also the voltage when testing an xp-g2? That should give us some answers
Tom E
Tom E's picture
We all know about the higher Vf of XP-G2's, and the 4.35v cells don't do any better - I don't fully understand why, and can't explain it, but in real world tests, they perform relatively miserably compared to high performance 4.20v cells like the 25R, HE2, 30Q, etc., but this is all in one cell applications, never tried in multiple cell parallel setups. I don't think I have that many 4.35v cells to test - maybe I could test with what I have?
Mitko, and maybe couple others, see over 5A on a XP-G2, so the question is what am I doing wrong, or Mitko doing right? From 4.0A to 5.25A or 5.5A is a hugh difference probably due to a big difference in Vf. I'm not set up to measure volts while I measure amps, least not at this time.
pilotdog68
Can we solder a simple voltmeter to the emitter wires at mcpcb while measuring current at the tail? Would that voltmeter affect the readings at all?
KawiBoy1428
I was seeing this when I started measuring other peoples builds using the XP-G2’s. Case in point was member D36ME’s TK61 XP-G2 build and quite a few Courui’s built with the XP-G2’s, ( a few Direct drive) I was testing them for LUX on my light meter. Then I started measuring amps, trying to figure out why they were not smoking de-domed XM-L2’s and XP-L’s? So it’s not just my builds but other peoples builds too? :~
Tom E
Tom E's picture
That's been my experiences with XP-G2's - disappointments based on relatively low amps, which is why I'm so interested in Mitko's results - he's got high amps and very good throw #'s, consistently no less. What are the possible differences?
  • reflow method: temp and time
  • MCPCB and solder paste used (I've used a variety of MCPCB's with same results, and use a quality Kester solder paste from MtnE - maybe too little, too much?)
  • sourcing: I think the same source, FT, but may be different batch's
  • batteries: think we are effectively the same, hoping same charge level (I'm anywhere between 4.20v and 4.23v
  • driver: I've even eliminated the driver, so unless it boosts voltage, mine should be the same or better
  • meters: think mine does well on high amps, and think my light meter does well (I don't calibrate my meter for throw)
KawiBoy1428
I don’t know, but I remember Vinh went thru way too many (i think over a hundred) XM-L2’s during the TK61vnV4 740kcd ……Nightmare/Adventure!! :bigsmile: I don’t have that kind of intestinal fortitude :bigsmile:
scotlarock
Tom, I’m seeing all of the same numbers (amp reading) that you are, with the exception of my A6. I ordered 2, one had the 1A tint and pulled 6.7A. All of my readings are done with my Fluke clamp meter.
DB Custom
DB Custom's picture
I’ve gotta find one of my XP-G2 mods to double check, I know I build manxbuggy1 an X6 that did 103Kcd from one, but I don’t remember the amperage on it. Seems it was just over 5A.
A member here sent me 2 A6’s to do spring bypasses on not long ago. 2 different tints, both ran 6.18A when I finished. Suprised the heck outta me!
Edit: The only XP-G2 I have left here are all domed and under 4A. Small lights, 14500 and AA.
FmC
FmC's picture
XP-G2: 3.8A - 4.2A
Hi Tom,
 Yes, I'm using a buck driver (FL-2) to get those currents with XP-G2. The driver needs some attention with cooling to sustain operation at that level, though.
 I just now hooked up the same XP-G2 S4 used above to an early revision Vishay 70N02 Fet driver with 2 fully charged 25R's in parallel, & measured 4.5Amps, but of course there is some resistance there as I'm using alligator clips to hold the ~10" 18awg jumper wires in place.
Again, the clamp meter should improve accuracy across the board, with everyone's readings, when they are in hand.
In relation to your other thoughts;
 Sourcing; I'm not confident that FT has accurate information from their suppliers in regards to high bin numbers, particularly after them advertising "XPL HI V5/V6", & not changing the listing after being pulled up about it here.
 Reflow; I'm using a small 'jet' lighter to heat the star (in this case Noctigon) whilst held in the helping hands. I don't use paste - I just dab my solder wire onto the pads & let it pool, then place the led on the molten solder briefly, lift & check that the pads are wet, then place back on & hold down to release any excess solder. I then lower the whole star onto a CPU heat sink to aid in cooling it faster.
Meter; Amp readings - probably the largest variable between everyone at the moment.
 I'm reasonably confident in my Luxmeter, as I have been able to compare to a few known factory lights, as well as lights that other members have measured, & been in the same ballpark for throw & lumen readings.
 Sorry for getting a little off-topic - I don't even have one of these Boss' yet, lol.
Tom E
Tom E's picture
FmC - k, that makes a lot more sense now. LCK-LED has those listed here as FL-215? Think it's the old IOS driver I used in Shockers.
Last night went back and checked my notes - I do have a dedomed XP-G2 S2 2B that hit 5A! I'm like Dale - forgetting more than I can remember. Last night re-measured at 4.95A or so, and it's in a Convoy C8 - I measured 159 kcd taken at 10m with a FET driver, believe copper pill.
Dunno what magic happened with that one though - wish I could reproduce it. Pretty sure it's gas dedomed. Really want to put these under a microscope - want to closely inspect the bond wires... Been hearing that a bond wire can be detached, and just sitting at/near the contact pad - only visible under a microscope.
DavidEF
DavidEF's picture
Last seen: 6 hours 19 min ago
When’s the group buy gonna start?
- The YKK Philosophy
DB Custom
DB Custom's picture
In my experience, (making note that I know not what I say) when the meter shows that “-” in front of the amperage number the current is being read in the wrong direction. Changing the position of the wires fixes that and almost always shows a different number, usually lower.
Tom E
Tom E's picture
Hhmm, I always set up to read positive amps - thought negative readings were worse. Ohhh!! Also forgot (Smile) -- got my UNI-T clamp meter coming in today - in the local Post Office this morn - ordered out of US warehouse from TomTop.com, pretty good price - $33.85 shipped w/tracking, ordered Jan 6th.
TomTop is one of those familiar look'n sites - seems to have a lot in common with BangGood, both started biz in 2004, but seem quite different in policies. Could just be sharing the same storefront web tools or web services.
Also, lumens/throw measurements seem to track well with my tail amp readings, so I think I'm in the ballpark - for high amps, I've seen gains of 0.1A - 0.2A by cleaning up contacts with the DMM leads and cells (using a little bit of NO-OX-ID helps at times).
DB Custom
DB Custom's picture
I read from the negative when testing at the emitter to prevent a short if something slips or otherwise accidentally makes contact, but that’s not what I was referring to.
Reading the current backwards shows a negative reading on the meter, reversing the position of the probes removes that minus sign and gives a different reading. I don’t know electronics, so I don’t know what it means EXACTLY, but it’s about direction of flow I think. The clamp meter reads from positive on the face of the meter to negative away from the meter or the back side. Since it’s designated on the meter, I assume it matters.
Edit: That’s why I said anything, hoping someone could explain it. When I see a reading like that -5.41A above, in my own experience if I switch positions of the leads to get rid of the negative symbol the amperage will be lower. I don’t wish to report a higher reading in error, I fall under enough scrutiny as it is.
EditII: Testing a Courui L2 with XM-L2 emitter and Efest 3500mAh 26650 I get 4.84A if the facing wire is on the rim of the light and the backside wire is on the neg end of the cell. Reversing positions and getting the negative symbol, I only get 3.95A. So, it matters. Why, I do not know.
Tom E
Tom E's picture
Hhmm, assume you mean Convoy L2, not COURUI L2 - I don't think I ever saw a difference that large, but not sure - I never look for it because as soon as I see the negative sign, I reverse the leads, so I only read and record positive amp #'s. I'm talking about using a regular UNI-T DMM, not a clamp meter.
Also wait'n on freeme for the group buy - see here: http://budgetlightforum.com/node/42364. Nothing new posted, but freeme posted he's getting a bit burnt out on these, I'm sure some frustrations...
