Improving the UF-H3B
33 posts / 0 new
Tido
Some time ago I treated myself to the UF-H3B. When it arrived, I was really excited because I had been lusting after this for quite some time, but could never justify to myself the slightly non-budget price tag. Well, I finally held it in my hands, but when I turned it on, I was instantly disappointed by the ugly blueish tint. The annoying ramping UI didn't do anything to improve the impression, but the killer was the ridiculously low PWM frequency.
Something had to be done:
Disassembled
Next up was porting the BLF-VLD to the new hardware. This turned out to be a quite complex task, not only because of the new type of MCU, but also because of the different types of operation.
Anyway, the new driver has four modes in the main group, fully programmable from 18 modes available in the extended mode group. Ten of those are constant light levels, ranging from 1,4mA to 700mA. The rest are mostly useless disco modes and beacon or distress signals. I had to fill up the program flash with stuff Wink
Reworked PCB
To make future re-programming easier (or even possible), I connected all pins needed to a five pin, 1.27mm pitch connector.
I also wanted to replace the XR-E with a neutral white  XP-G R4. Unfortunately, the original LED was just wedged into place without any support PCB. This just wouldn't have worked with the smaller footprint of the XP-G, so I had to sand down a PCB until it fit into the light.
Next I had to glue everything into place. This is where things got messy:
Messy Epoxy
The plastic lens is glued to the body with Fujik silicone glue to make things waterproof. The LED's PCB is glued to the flashlight body with Arctic Silver thermal epoxy for improved heat transfer. On the right hand side, just below the screw hole, you might be able to make out the programming connector, fixed to the body with a standard epoxy glue. It's all pretty ugly, but it works.
So, here we are with a finally usable UF-H3B. It was a lot of work, but well worth it.
Finished
JohnnyMac
JohnnyMac's picture
Last seen: 1 year 4 months ago
Nice work! I really need to start playing with my programming module and cables. Cool
SPAMBOT
SPAMBOT's picture
Last seen: 1 year 3 months ago
A caution on the Fujik glue, it can turn certain plastics "hazy" after a while.
Now with 100% all natural asbestos!
okwchin
okwchin's picture
Yours has 3 screws, mine from the group buy has 2 screws and a different internal structure... Hmmm... Great job!! This is something that should have been from the start.
"like everyone else - I’m looking for my next “last” flashlight" -  ohnonothimagain
JohnnyMac
JohnnyMac's picture
You got the UF-H2 from the group buy. This one is the UF-H3 and runs on an 18650 cell.
Tido
Yes, this is the 18650 version. I also got a UF-H2B from the group buy, which currently lies around disassembled because it is equally annoying for the same reasons. The UF-H3B was the first to get fixed because it is bigger and therefore easier to work with.
As for the Fujik clouding the plastic lens, I sure hope this won't happen, as this is really the only part not easily replaceable. OTOH, the inside of the light was filled with thermal silicone compound, some of it touching the lens. If the plastic was susceptible to this stuff, we probably would have heard of clouded lenses by now.
SPAMBOT
SPAMBOT's picture
I've used Fujik on two lights with plastic lenses and one turned hazy after six months the other one took approximately nine months, so it was a really slow process. I potted the regulator in both cases, no fujik ever touched the plastic. Might have been some issue with that particular batch of compound though.
fibra
fibra's picture
Last seen: 7 years 3 weeks ago
I have ordered UF-H3B yesterday from DX after drooling on it for quite some time. I also dont like how visible PWM is.
I already have USBtinyISP and looking forward to modify it, so I have a question about driver used in this modification:
Is it original driver from UF-H3B flashed with BLF-VLD?
As I understand, drives should have separate pins for connecting the pushbutton, but I didn`t noticed those drivers around.
PS. I like 45 deg. rotation of the new emitter. Smile Nice touch!
borstar_micke
Last seen: 1 year 6 months ago
I wish I had your skills cause I also really hate the blueish tint, yuck....
Like it otherwise, but is now used as a wardrobelight as the lightfixture in there is broken.
Is replaced with with a ZL H600 that´s really great! Not very budget though... Wink
fibra
fibra's picture
Can somebody shed some light on this driver, please? Somebody else opened H3?
That pushbutton instead of switch is confusing. Either original driver can be reprogrammed, or some other driver have pushbutton input.
DrJones
DrJones's picture
Last seen: 2 years 11 months ago
I think the momentary button requires a major rewrite of the code - at least my TheKlone35 project needed a major rewrite of my luxdrv firmware.
Furthermore I guess this driver uses a PIC instead of an ATMEL/AVR which requires a different programmer and tool chain.
Don
Don's picture
Last seen: 1 year 11 months ago
If you ever feel like taking payment, I've an H3 that could use those mods.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
NightCrawl
Last seen: 3 years 3 weeks ago
I like that mod partially. I havent received my H3B yet, but I think I'd want to keep the ramping mode.. any chance on a better driver with the same ramping functions of the original?
fibra
fibra's picture
So you think it is original driver from the H3? It would be really cool if Tido could publish the code so others can upgrade their flashlights.
If just hex is published then is not big a problem. Programmers are really cheap to make or buy. I made myself Brenner 8P (http://sprut.de/) and USBtinyISP (http://www.ladyada.net/make/usbtinyisp/) Both are working fine.
DrJones
DrJones's picture
It looks like the original driver.
@Tido: Is it an unlabeled PIC? Which?
What compiler do you use btw?
I wonder if I should get into PICs, too. Whenever I read about the details, I think I prefer AVR though.
Tido
The driver PCB uses some kind of MCU with a PIC footprint. I couldn't get the original chip into programming mode, so I replaced it with a 12F683. The PCB used a transistor controlled by an AMC7136 for current regulation. I replaced those with two 7135, one controlled by PWM, the other by digital I/O. The software is a PIC port of the BLF-VLD, with some modifications to work with the push button and an added low power sleep mode.
Since there is no free tool chain for the PIC14 architecture, I had to use htsoft's hi-tech C compiler. Which is a royal pain to use in the free "Lite" version.
fibra
fibra's picture
So would you be so kind to share the hex code?
I would do required modifications once I get the flashlight.
DrJones
DrJones's picture
There are alternatives to the HiTech Lite, with restrictions, too: I'll try microC, SourceBoost and/or CC5X if/when I get myself a PicKIT.
I'd need to check some tutorials to get used to the different registers etc.
Tido
fibra:
I'll have to check whether I compiled the driver using the "Lite" or the "Demo" version of the compiler. If it was done with the Demo version, I think I'm not allowed to distribute the binaries. I've been planning to do a final release of the the BLF-VLD, including the port for PICs and some special drivers, but so far I just couldn't find the time and motivation to put it together.
DrJones:
There may be other compilers, but SDCC just didn't work when I started with the PIC port and none of the others are free (as in speech) or even run natively under Linux. Since all the choices where bad, I chose the one which promised best support for the MCU.
Microa
Last seen: 1 day 2 hours ago
Tido:
You have done an excellent work and I enjoy reading your posts. Glad to hear that you will have a final release of your wonderful BLF-VLD. I hope the final release will include the memontary switch for remote mode switching.
WELL DONE
fibra
fibra's picture
Tido, thank you for your answer. Looking forward for final release of BLF-VLD, hopefully with button option. Smile
NightCrawl
Thanks to Tido's inspiration, DrJones' driver and the fact that I just ordered the UF H6, I decided to finally mod my H3.
Driver: Nanjg AK47 1A with DrJones' lumodrv (http://budgetlightforum.com/node/8368#comment-148503)
LED: XML T6 NW on copper PCB from LED-tech.de
and some dremel skills.. most useful tool was the grinding tool OL recommended me some time back.
Tido's pics helped a lot, the brass ring can be hammered out from above. I had to open it up with the dremel grinding tool because it was only 15mm in diameter and I couldnt get the Nanjg any smaller than 16mm. But it worked out pretty well and I started soldering the stuff together. Next was to trim the LED PCB down. Was a lot of work and took some time, but hey, thats the fun part. Wink
I wont say much about the driver because I guess you all can read, but I love it! Smile
Basically, this assembly went into the light after some hours:
I glued the LED in place just like Tido and filled most of the empty part in the head with Fujik. Works pretty well actually.
Front view:
As you can see, lens is scratched (but the big white spot is just reflection, so its not that bad) and I made 2 silver rings to cover up the worst scratches. Next time, I would to a few things differently, but thats why we mod: to learn. This was definitely my hardest and most complicated mod so far, but:
-no PWM
-nice tint
-brighter
is really worth it. Also, some scratches dont matter because its gonna be used to work anyways. Wink
electricjelly
electricjelly's picture
Last seen: 2 hours 56 min ago
I have an old h3 that I think would be a good host for a 18650 powered nichia 219 headlight. I still need to figure out what driver to use. Im glad I found this post with all the helpful tips and pics. If I’m successful I’ll pay it forward with contributions of my own.
NightCrawl
@electricjelly: DrJones and some others can program their own drivers, maybe you could do that too.
Take a look here:
http://budgetlightforum.com/node/10581
I have a few of DrJones' drivers in my flashlights and I love them. Smile
electricjelly
Thanks nightcrawl. I think I’ll be getting in touch with Dr Jones soon. It looks like he’ll be able to set me up with just what I need. I was checking out the Aqualab driver database. Even with all the info over there I was still having a hard time. How has your custom h3 build been holding up?
NightCrawl
Problem with all these drivers is that none are designed for soft-button switches like the H3 has one. Drivers like that are pretty rare..
My custom build still gets a lot of use. Its a great, flood-only headlight and I use it to walk the dog, work or carry wood from our storage place to the firing. Dropped many times and still works perfectly, thanks to the head being filled up with Fujik. Wink
Only downside of this is that you shouldnt look at people when they look at you while wearing the headlight. Bright as hell. I got an XML and a 1A driver in it.
electricjelly
I’m glad to hear your u3 worked out so well. I used a u3 for a couple years as my daily work light. I love the form factor. I can shove it in a pocket in my tool bag, the 18650 lasts a few days, and the full flood is perfect for up close work. I’ve since upgraded to a Zebralight h600fw, which I love, but with a nichia 219, and a nice driver, I might be able to build one that’s even better.
NightCrawl
electricjelly wrote:
I'm glad to hear your u3 worked out so well. I used a u3 for a couple years as my daily work light. I love the form factor. I can shove it in a pocket in my tool bag, the 18650 lasts a few days, and the full flood is perfect for up close work. I've since upgraded to a Zebralight h600fw, which I love, but with a nichia 219, and a nice driver, I might be able to build one that's even better.
And what are you waiting for? Smile
electricjelly
I had posted my build here in this thread, but it got so big I decided to make a new thread. I didn’t want to hijack this one. Here’s a link to my modded UF-H3 build.
http://budgetlightforum.com/node/14892
IRONMAN
IRONMAN's picture
Hi there, old Thread new questions Smile
How did you manage to get the driver out? It seems to be pres fitted?
electricjelly
It’s been a while. the driver is soldered into a retaining ring that is press fit into the body of the flashlight. I remember I pressed it out. I’m pretty sure I pressed it out from the head side and it came out through the battery tube. in my case I wasn’t worried about saving the driver so I just pressed directly on the board. even though I was being rough with it I think the board survived it just fine. good luck with the project. I still use mine to this day. It’s a great host for a custom headlight.
