UV led test: '3rd gen.' LG 385nm 3535-size led
13 posts / 0 new
djozz
djozz's picture
Last seen: 4 hours 3 min ago
I bought 10 of these 385nm leds mounted on 20mm aluminium stars from Aliexpress, 2 dollars a piece (no idea how long the listing will last, but it is still listed at the moment of this write-up). I never had a 385nm led before, I was curious if it had the same visible light 'pollution' as most 365nm leds. It is a XP-footprint 385nm led, and there's hardly anything to be found on it, it is not on LG Innotek's website (anymore?). Some googling just retrieved a concept datasheet, the website that contained the datasheet referred to this led as '3rd generation LG UV-led'.
So I should get 780 mW out of it, decent enough! First notion was is that these leds were horribly reflowed, solder all over the place and I suspect the temperature was way too high, it seems that in many of the 10 leds, the die had been detached during reflow, there's solder blobs around the die!
There's no way for me to measure absolute output power of UV-leds (I have no optical power meter, like some of the laser-guys). Instead I measure the power indirectly by illuminating a piece of photocopier paper and measure the blue fluorescence with a luxmeter. I used a set-up for this before, but for this test I designed a simpler set-up that sits on top of my integrating sphere, a piece of paper covers the entrance hole of the sphere and on top of that a holder that fits the standard copper ledmount that I use for emitter tests. The inside of the holder is covered with aluminium tape to get an as wide as possible cone from the led illuminating the paper:
For 365nm leds I will add a ZWB2 filter to this set-up.
Measurements like these are relative, for absolute output numbers in mW, it needs to get a calibration that I do not have. And then a separate calibration for every wavelength because: does 'x' mW of 365nm light cause the same amount of paper fluorescence as 'x' mW of 385nm or 400nm light? And does het paper die bleach upon illumination? (I did not notice obvious bleaching sofar). And is the fluorescence lineair with illumination or does the paper whitener's excitation shows saturation at higher illumination levels? Again it does not seem so but I did no rigorous testing on these things.
So here's the output and voltage of this LG led (on a 16mm XP-Noctigon) as a function of current, as explained above the output is not absolute, it is represented by the reading of the paper fluorescence by the integrating sphere's luxmeter, so is given in lux.
*I'd say with the led on a DTP copper board, the current sweetspot is about 1.5A, but on a single li-ion battery you wil not get there, the voltage is so high that even direct drive you hardly get over 1A, which will still give a very good output Smile
*the absolute output compared to other UV-leds can not be derived from this graph yet, because I have not measured other UV-leds with this exact set-up. And this is the first 385nm led sofar. If the spec-sheet is correct, and the output at 500mA is indeed ~700mW, at 1.5A we're at 1700mW radiant power Smile
I have build a 16340 tube-style flashlight with this led, direct drive, no modes and was struck by the good output, but also by the similarity of this light compared to the light of a 400nm flashlight, same purple glow, bank notes show similar fluorescence, and absence of the typical broadband white background of 365nm leds. So much that I doubted the led being 385nm at all.
So to complete the test I was forced to check the output spectrum. The antique Zeiss monochromator was dusted off, and a spectrum was measured. I calibrated the monochromator with a 405nm laser (it is still 5nm off), mounted the led in front of the entrance hole, taped a piece of copier paper over the exit hole and measured the fluorescence with my most sensitive luxmeter (consistent reading down to 0.01lux). The slit (determining the exit wavelength band width) was set at 0.2mm, like in my other measured spectra.
This is what I measured with the maximum reading set at 100, mind that again because of the use of paper fluorescence, and because of unknown wavelength dependance of the transmittance of the monochromator, this is not an exact output spectrum, even though I suspect it is close enough to one, and the peak will be fairly exact.
So my suspicion was not confirmed, this led indeed peaks at 385nm, and at 400nm the output is down to less than 10% of max.
Conclusion. Despite the maltreatment of the manufacturer reflowing them way too hot, this led performs very well, although the Vf is a bit high for maximum performance with single li-ion use. It was nice to see what a 385nm led is like, but it does not have the unique performance of 365nm leds.
Thanks for reading!
Edited by: djozz on 12/07/2015 - 11:34
Jubeldum
Jubeldum's picture
Last seen: 3 years 5 months ago
Nice review. I can’t wait to see your 4th gen reviews. The 4th gen emitters I ordered should be here Wednesday. Smile
MRsDNF
MRsDNF's picture
Last seen: 15 hours 22 min ago
Thanks djozz for a mammoth effort. As usual my grey matter was given a workout understanding.
vēer
vēer's picture
Last seen: 3 days 23 hours ago
Thanks for review, djozz!
Do you still have that amber to compare it to other UV lights to see how well this LED illuminates amber :D?
scintillator
Last seen: 1 hour 17 min ago
I appreaciate the review and the work that went into it.
I keep reading and learning….
Hestbech
Hestbech's picture
Last seen: 7 months 2 weeks ago
Thanks for the review!
Jubeldum wrote:
... The 4th gen emitters I ordered  ...
Link?
vēer wrote:
... Do you still have that amber to compare it to other UV lights to see how well this LED illuminates amber :D?
+100!!! Smile
I'm still waiting for some of the parts for my own uv-build - so it's still possible to build it with 385nm in stead of the 395-405nm i already got
It would be dandy if birds pooped candy ::
djozz
djozz's picture
Link?
+100!!! Smile
Thinking that I was done testing with the amber I gave the small collection to my mother-in-law who was very interested in the raw amber. I guess I will have borrow it back then for some more tests Smile I see her next weekend, I hope that I will not forget asking her.
Hestbech
Hestbech's picture
No problem. I just "accidentally" ordered some 385nm myself Blushing
How do you guys see if a led is 3rd or 4th gen?
Jubeldum
Jubeldum's picture
Hestbech wrote:
No problem. I just “accidentally” ordered some 385nm myself Blushing
Look at the die.
3rd Gen
4th Gen
Hestbech
Hestbech's picture
Thanks! Smile
1dash1
1dash1's picture
djozz wrote:
… For 365nm leds I will add a ZWB2 filter to this set-up. …
Looking forward to seeing your review of the 365nm with ZWB2 filter. Glasses
Rule 1-1 as it applies to life, take it as it comes.
Hestbech
Hestbech's picture
Oh - the 3rd gen 380-385nm is now $14,25 for 10pcs. Maybe they are clearing the stock to make room for the 4th gen Silly
Haven't been able to find the 4th gen yet.
fedcas
fedcas's picture
Last seen: 1 month 1 week ago
thanks for all your tests Wink
what do you mean? Isn’t that in contracction to your image in the reference post?
Also, I may buy a few of these LG 385nm leds instead of 365nm because they are very cheap… on here for example (I just noticed it’s the same shop where you bought them 3 years ago)
https://www.aliexpress.com/store/815938/search?spm=2114.12010615.0.0.2d4...
are they acceptable as exciting radiation for fluorescent pigments? Do they emit much more visible light than other slightly more expensive leds?
