Brinyte B158 mod thread
306 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 8 hours 11 min ago
Thats very sweet looking zipelgas. What did you blacken the tube with after smoothing it down?
evankouros
evankouros's picture
+1 Thumbs Up
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 19 hours ago
zipelgas wrote:
Just wanted to share me slim edition mod. I very happy how it turned out.. b158_slim.jpg
It is good but you have orange peel of over spraying… Multiple mist coats works better than few heavy coats imo.
zipelgas
zipelgas's picture
Last seen: 4 hours 16 min ago
Jumbo size heat shrink tubing + sugru and an o-ring for that extra rubbery cigar gripy feel.
Overkill is just about enough!
Jerommel
Jerommel's picture
Last seen: 1 week 2 days ago
Nice!
I think Brinyte maybe agrees:
Smile
MRsDNF
MRsDNF's picture
Thanks. Thumbs Up
evankouros
Where’s the sugru man? Question
I really can’t see it!
zipelgas
zipelgas's picture
I take that as a compliment Big Smile
As I heated the tube the ends got uneven and I had to trim them down and ended up 4mm short. So I filled the gap with black sugru, that I had left over. It’s the small gap between the rubber o-ring that is sitting in the lower groove and the shrink tube. Not much and it was not supposed to be there, but it all ended up surprisingly well.
Rufusbduck
Rufusbduck's picture
Last seen: 11 months 2 weeks ago
How did you remove the knobs, lathe? I’m curious as this is one I’m planning a woody mod for as soon as I decide on what wood type to use.
Scott
zipelgas
zipelgas's picture
Yep – it was done with a lathe. I found it to be too bulky for my pocket and now it’s really much more comfortable to hold.
Mike C
Mike C's picture
Last seen: 3 hours 10 min ago
Nice work. I might have a go at it myself. You didn’t paint anything, you used shrink tube and sugru? (have no idea what sugru is other than what google tells me).
zipelgas
zipelgas's picture
I think heat shrink tubing is a very nice finishing option. Just learn from my mistakes and leave it a bit longer than needed. Heat almost to size, trim ends and then heat some more to fix. Lot less messy than paint.
sac02
sac02's picture
Last seen: 17 hours 11 min ago
Excellent, zipelgas! I really dislike those stock knobs.
I need a lathe for many things…
vidramon
Or simply buy it HERE
zipelgas
zipelgas's picture
Where the hell is the fun in that Crazy
vidramon
Everything is done, just pay and wait to arrive Big Smile
sac02
sac02's picture
Any codes for that B158B? LOL
vidramon
For now there is no code. Code can be used for b158 U4 and b158 HI V3.
Dutcheee
Last seen: 2 days 13 hours ago
I modded mine today.
One pill I built with an AK 101-A1 driver (L-M-H mode order), a filed down bergquist star & oram oslon SFH4715AS IR led.
I first blew a SFH4725S led, but fortunately I ordered the 860nm variant as well. It’s for some to-be-built nightvision hunting gear.
Second pill I built with unmodded BLF A6 driver(Bistro), filed down Noctigon MCPCB & XPL V6 0D Led.
Thereafter I dedomed the led with a knife and built the second pill. I got a bit messy, but it works more than well in the end! Bypassed both springs and it pulls 5,2Amp. It has quite a nice white/yellowy tint to it after the dedome.
I tried to measure lux with my phone, but it went straight to >211Klux @100cm, wich is the max the sensor can measure.. There’s a first time for everything Silly
Crazy thrower, can’t wait to use it in the field. I can just pop in another pill for the task needed and only carry one light with me.
Test pic
Building 400mtr away over city light.
Best thrower I own to date!
mandala
Last seen: 2 days 5 hours ago
Thumbs Up
That’s crazy. They should make upgraded “super” pill though XPL-HI is good. I like this light. Does it dissipate heat good?
Dutcheee
Yes, it does. I didn’t run it too long. It doesn’t feel too hot in any particular place and didn’t desolder itself or anything. No complaints yet Thumbs Up
Rufusbduck
I’ve been wanting to do this since before I decided to actually get one and the other day I finally disassembled one and cut the lobes off with a hack saw. Then I chuckle it into my drill press/wannabe lathe. I continued further but stopped before getting to the bottom of the slots as that would reach the internal o-ring groves(very bad). I have a piece of Teak that might go well with a few fins. I’ll see which metal looks best to me.
Scott
MRsDNF
MRsDNF's picture
Wheres the popcorn. Thumbs Up
Lexel
Lexel's picture
Last seen: 7 hours 2 min ago
I got yesterday my B158 with XML U4
Dedomed the LED in gas and sealed it with clear laquer
The Nanjg 105C driver was hanging in the pill between a contact board and LED
Changed the driver to Biscotti and removed the contact board and soldered the driver to the ring that is pressed in pill again
Spring bypass on driver and tailcap
The star is DTP copper but a bit thin, mounted with Arctic Silver 5 again
LED centering ring and gasket painted black
Pill painted black mounted with thermal paste to the tube
sac02
sac02's picture
Lexel, did you remove the LED to confirm the MCPCB is DTP, or is there some other way to confirm it? You can have copper MCPCB without DTP.
I thought the way to test for DTP (instead of just a copper MCPCB with no DTP) was to test for electrical continuity from the bottom of the MCPCB to the LED heat pad.
Is it possible to confirm if an MCPCB is DTP with the LED still attached to it?
Rufusbduck
DTP confirmation, if there’s excess solder squeezed out from the center pad then check continuity to the bottom from there. It’s trueness that not all copper boards are DTP.
Scott
Rufusbduc,
I support what you did to your B158 Thumbs Up
Zommies should be as light as possible in their lenses caliber and unnecessary hunch design does not help with heat sinking anyway so this is the way to go…
enesrap
!{width:70%}http://www.metronixlaser.de/bilder/flashlight/IMG_2486.jpg!
Very good my friend, I have a restlessness, I paint the pill black and centering to eliminate the annoying rings of light? Eliminates them completely? Thank you
Lexel
Lexel's picture
It reduced em, but eliminate is not possible
Rufusbduck
luminarium iaculator wrote:
Rufusbduc,
I hope you’ll still like it when finished as some of the weight will be added back but with a significant increase in surface area(at least where the pill is located). To be honest though, it’s mostly cosmetic since any gain made by the copper could well be offset by the addition of the aluminum to copper thermal break. I could do wood only but fins just look neat.
Scott
