Convoy L6... XHP70 Beast!
4823 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 1 hour 3 min ago
Ag76 wrote:
Thanks for the info Jason and emarkd…..those are nice stations, but you guys are doing stuff way above my pay grade!
You haven’t seen anything, yet. You should check out the price on some of the JBC soldering equipment. That’s what the pros use. Hakko is a nice alternative that is much cheaper.
If you want to see some informative videos on soldering irons as well as how to use them, you might want to check out some of Louis Rossmanns videos. They can be long, but he has a nice microscope camera so you can see exactly what he’s doing.
https://youtu.be/le3MKFfKaII
https://youtu.be/WgoGhnlJHas
https://youtu.be/ChujyTV-HME
Click this to go to signature links.
solRNY
Last seen: 22 hours 27 min ago
ledalex wrote:
I have those Liitokalas and I just put a small flathead under the flat top and bent the metal upwards enough that the batteries now work in series without the nuisance of a button magnet. No soldering necessary. FYI, I’m not sure if I have genuine Liitokalas but it should work either way.
i did the same with my batteries using a small flathead to bend the positive terminal upward, it works great. today i decided to take some measurements:
bent pos term measured ~14.85A
to my surprise, solder blob measured ~16A
topped of the batteries to measure the new max ~18.1A!
DB Custom
DB Custom's picture
Last seen: 6 hours 33 min ago
Probably because the solder blob is making more contact, allowing the current to flow easier.
Ag76
Ag76's picture
Last seen: 2 hours 34 min ago
Jason, thanks for the links….you’re right, it will take some time to get through them, but they are interesting and informative.
TBone
Last seen: 3 days 3 hours ago
The budget soldering station of choice is Hobbyking’s Hakko 936 clone. $23 is hard to beat and it works great if you are not a professional.
morelightnow
The shipping on these lights is actually pretty fast from Simon. Mine arrived several days ago much faster than I expected. Even on just two batteries it is pretty bright. However, I ordered a short tube also thinking it would add length to the tube, but I obviously didn’t see that both ends were threaded in the picture. I saw a picture of one that was longer than normal somewhere, but there is no extension tube listed on ali. Does anyone know where to get one?
DB Custom
DB Custom's picture
I can send you an extension tube, just cover shipping. Should be able to put it in a small bubble pack for a few bucks. BUT, not sure the original driver can handle 3 cells if you’re planning on adding an extension to the 2-cell tube, of course, there are other mods you could be doing as well, like Kawi using 4 26500’s and an XHP-35….
morelightnow
I’ll take you up on that deal via pm.
Yes, I will be making major changes at some point in time. I had the idea to replace the driver with a h6flex, but I will have to be super creative to make it work. It will also take some removing of metal. At this point, I am just gathering ideas and options.
PhatPhil
Last seen: 12 months 4 days ago
Still to jump onboard and buy a Convoy L6 (I must be one of the few on here lol)
Any idea if this will be updated to come with the XHP70.2 soon (direct from Convoy)
Also is the SMO reflector a worthy upgrade for outdoor use? Is that much spill lost?
JasonWW
JasonWW's picture
I haven’t heard anything about it being offered with a 70.2.
The reflector surface has no effect on the spill lighting since all that light does not even touch the reflector. The Smo basically tightens up the corona.
Whether it’s worth buying will be up to you. I always felt the beam was a little too wide for my tastes and would like to shrink it a little and gain some extra throw.
It’s currently the right size hot spot for me. If I were to slice the dome and get a smaller hotspot, it’d be too small and throwy. So it’s all personsal preference. The SMO is cheap enough that I would get it just to try it out.
TWN
Last seen: 1 week 6 days ago
Wow, that’s a great idea for me.
Where I can bought those kind of extension tube so the flashlight can handle 4 battery in series?
JasonWW
JasonWW's picture
DBCUSTOM has a few extra.
DB Custom
DB Custom's picture
It would probably be much cheaper to order extension tubes from Simon (Convoy) on AlliExpress to ship to Indonesia, shipping would be quite high from here as the USPS get’s really pricey exporting anything.
Daneel
Last seen: 9 months 2 weeks ago
Hi guys.
My L6 seems to have died, and I can’t work out why. It’s been sat in its box for a couple of months since I last used it. I put in batteries, tried to turn it on, and nothing.
I’m not great at trouble shooting, any suggestions where to start? I’ve had the light for less than a year, and it’s probably only seen 30 minutes of actual use!
I charged the batteries before I tried to use them so no issues there. I’m using a disc with springs device I got to allow the flattop batteries to work in series.
Thanks!
Edit – I took off the tail cap and tried connecting the edge of the body to the bottom of the battery. It works! It seems the tail cap is the issue. The click is a bit spongy, but seems to be working. Can I test if the switch has failed?
Edit 2 – Broke out the continuity tester, and the tail cap switch is working
Edit 3 – I just needed to tighten the tail cap hard, and the connection is made and working. I don’t remember having the problem before. All’s well that ends well I suppose Smile
JasonWW
JasonWW's picture
Make sure the spacer ring that fills the gap for the lanyard ring on the battery tube is tight. If it gets loose, the tail cap won’t tighten all the way.
DB Custom
DB Custom's picture
Right, what Jason said… that spacer ring is threaded on and can be replaced by the tactical ring, the spacer is so well made that it’s easy to forget it’s actually a threaded removable part. Wink
TWN
I don’t see any extension tube for L6 on Simon’s store.
Could you please give the link for it?
Or I need to contact Simon directly?
JasonWW
JasonWW's picture
You’ll need to ask directly.
TWN
I see. No wonder can’t find it anywhere in his store.
Thanks for the inforrmation, Jason.
Anyhow, where’s I can find 26350 battery?
Seems this hard to find. Only seen on BG or GB, but they can’t send to me.
JasonWW
JasonWW's picture
You can also ask him for a clear switch cover if you need it.
You might try Fasttech for 26350. In the US, Mountain Electronics has them, but I don’t know if he ships to you.
ZozzV6
ZozzV6's picture
Last seen: 2 days 22 hours ago
Daneel: Or if you putted on the tactical lanyard ring reverse it can touch the tailcap and you need to screw on the tailcap hard.
Flying Luminosity
Flying Luminosity's picture
Last seen: 3 weeks 13 hours ago
Received mine today. Hopefully those KeepPower will be charged by the time it gets dark! Smile
JasonWW
JasonWW's picture
Sounds like you need an Xtar SV2 Rocket charger. 2 amp to each cell. Charges fast.
JasonWW
JasonWW's picture
Does anyone know if Convoy is the only place to buy a new tail switch?
Flying Luminosity
None of my chargers can supply more than 1A per channel (Nitecore i4, Xtar VC4 & Liitokala Lii-202), so I’ve been looking at MiBoxer’s range. But I’m pretty impressed with my Xtar, so it seems that I’ll need to give their rocket charger some consideration. I’ve got several lights that take 4 18650 cells though, so I might be better off getting a 4-bay charger. (or both?)
Currently got my 26650s in the Lii-202 hooked up to a 2.4A USB charger (Orico 4-port), so it should be charging with 1A per channel. But my (cheap) USB meter is only showing me a current that is varying between about 0.5 and 0.7A, and the light for 0.5A charging is lit up on the charger … Flat Stare I can see myself ordering a YZXstudio meter soon, so I know I’m getting accurate readings. And then I’ll need to find a multi-port USB charger that actually supplies what it promises!
JasonWW
JasonWW's picture
I bought a Rocket especially to charge my L6 batteries. I actually bought 2 at $18 each since I have other lights that use 26650 as well.
The new I4 charger only does 0.375A x 4.
The VC4 charger only does 0.5A x 4. I have my VC4 hooked up to a good tablet usb charger rated at over 2A. Sometimes it seems the connection is not good and I’ll see the charge rate on the charger drop down a little. That’s worrysome. I’m going to avoid usb chargers from now on.
Have you looked at the lii-500 charger? It does 1A x 4. Thats pretty good.
I am on the lookout for a 4 bay charger that can do 1.5 amps each for 18650. That’s about the most a good 18650 can do. I’ve looked a little, but haven’t seen one yet.
Flying Luminosity
Yes, I realised after posting that it might be a problem with the battery charger, and not the USB meter or phone charger. I’ve now got the batteries charging in the i4, which uses 750mA per channel if only slots 1&3 or 2&4 are used. I can’t currently remember where I’ve put my VC4 which would give me 2× 1A with 2-slot charging (provided that the USB charger works properly). If I can find it, I should at least be able to narrow down where the fault lies.
The_Driver
The_Driver's picture
Last seen: 3 hours 31 min ago
Has Simon ever thought about offering a diffusor for the light? Just a simple one to be stuck on the head. I think this would be a very practical addition.
JasonWW
JasonWW's picture
That seems bizarre to me. What purpose would it serve?
I guess you could add diffusion film over the lens.
The_Driver
Sometimes one wants a floodlight. The L6 is easily bright enough to also be used as a work light.
