Convoy L6... XHP70 Beast!
4823 posts / 0 new
klrman
klrman's picture
Last seen: 9 hours 36 min ago
Thanks.  I have one of those round spacers that have the springs on either side for contact so that may just work.
DoNkEyConN
DoNkEyConN's picture
Last seen: 1 week 4 days ago
Length is not the issue, diameter is.
as you can see in this pic the 26650 on the left 18650 on the right
same length different diameter
klrman
klrman's picture
Ah, I see.  I found some spacers then that would work from an old flash light, thanks.
EasyB
Last seen: 10 hours 7 min ago
klrman wrote:
I forgot, but will my L6 work with two NCR18650B protected cells?  I am looking at these ones.  They are 65.5mm flat tops.  https://www.amazon.ca/gp/product/B010LTDFBK/ref=pe_1243740_268305490_em_...
You can use 18650s as long as you have the spacer, but the NCR18650B is not a great choice for this light because of the cell’s high internal resistance. They will work, but the light output will drop more quickly than with higher performance cells.
klrman
klrman's picture
Yeah, wasn't sure about that.  Hard to get Keeppower 26650's sent to canada with the new laws that was why I was asking.
Lightbringer
Lightbringer's picture
Last seen: 4 hours 32 min ago
Gnope. If you’re gonna use 2, you’ll need button-tops. You “can” use small Nd magnets to bridge them, but drop the light and they theoretically can shift and short the positive to the (negative) tube.
Plus, they’re great for up to 3A or so, which is fine for smaller lights, but will limit current to the L6.
Should work fine in lower modes, but…
Lightbringer
Or you can try a solder blob to act as a bump, but be careful.
klrman
klrman's picture
Lightbringer wrote:
Gnope. If you're gonna use 2, you'll need button-tops. You "can" use small Nd magnets to bridge them, but drop the light and they theoretically can shift and short the positive to the (negative) tube. Plus, they're great for up to 3A or so, which is fine for smaller lights, but will limit current to the L6. Should work fine in lower modes, but...
Thanks, I think I may as well just get some good 26650's then.
Lightbringer
klrman wrote:
Thanks, I think I may as well just get some good 26650’s then.
Yeah, best bet, albeit not the cheapest.
You can still use 18650s, even without sleeves, but they’ll have a tendency to rattle around when the light’s shaken. Otherwise, a thin sleeve (even cardboard from a cereal box Big Smile ) can be wrapped around the cells a coupla times to keep them centered and somewhat cushioned.
DB Custom
DB Custom's picture
Last seen: 9 hours 23 min ago
Simon usually includes a clear flower looking rubbery ring, 2 of them (or 4) that are for putting around an 18650 so they won’t rattle in the 26650 tube. They’re usually inside the tail cap or in the package the light came in.
Lightbringer
Oh yeah, forgot about them. Got ‘em with my L2s, so makes sense that they’d be included with the L6, too.
JasonWW
JasonWW's picture
Last seen: 1 hour 50 min ago
I don’t think those spacers come with the L6. Maybe the L2 or smaller lights only.
Click this to go to signature links.
Lightbringer
‘K, so we’re back to cereal-box cardboard… Big Smile
DoNkEyConN
+1
I did not receive them with my L6
mortuus
mortuus's picture
Last seen: 1 hour 7 min ago
Didnt get spacers eithers in mine, but i dont get it why would anyone run this light with 18650? i dont see the point in putting those in a big light that throws almost 4000lumens, longer runtimes is better and the batteries sit tight and no need worry about some cheap spacer..
...where Frugal meets with Flashlight!
JasonWW
JasonWW's picture
It’s mainly because protected 26650 cost double the price of protected 18650.
Protected 26650 are also very hard to find right now.
klrman
klrman's picture
Is the L2 extension tube in Simons link below the same tube as the L6?  I need two of these tubes and they
really look the same as the L6 but I want to make 100% sure before I order them.
https://www.aliexpress.com/store/product/battery-tube-for-Convoy-L2-bloc...
DoNkEyConN
That looks like an L6 tube, if I’m correct the L2 Tube is made of 2 parts as the L2 can run off 1 or 2, 26650 cells.
In saying that it would still work for both the L2 and L6.
DoNkEyConN
Can anyone tell me if i can reflow an XHP70.2 LED onto a stock L6 MCPCB (XHP70)?
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 min 34 sec ago
Same…Block or Ring style 2×26650 tubes will work between the L2/L6 even the 2pc L2 tubes. all interchange/lego.
KB1428 “Live Life WOT
KawiBoy1428
Yep. XHP70 and XHP70.2 are the same.
DoNkEyConN
Excellent. thankyou KawiBoy Beer Beer
KawiBoy1428
Beer Wink Thumbs Up
surasakkongtha
Last seen: 2 days 9 hours ago
I have a question about where to buy silicone sidecaps?
DoNkEyConN
contact simon on Convoys aliexpress store.
https://convoy.aliexpress.com/store/330416?spm=2114.12010615.0.0.6679a90...
send him a message and he may be able to send you some just for the cost of shipping.
surasakkongtha
thank you
Andrew_Debbie
Last seen: 2 hours 18 min ago
I got 2 protected KeepPower 26650s from Banggood for $18.11. I used the generic 4BLF discount code. Ordered 6 December and received just after Christmas. These are the batteries Convoy recommend for the L6.
They are in stock. I just checked.
mortuus
mortuus's picture
the keeppowers are real shortage why its drivin me nuts.. been checking nkon forever and they are never in stock.. i dont get it, is the production on those halted for now or?
Andrew_Debbie
Can you order them from Banggood? They had them in stock a few hours ago when I checked.
klrman
klrman's picture
Same...Block or Ring style 2x26650 tubes will work between the L2/L6 even the 2pc L2 tubes. all interchange/lego.
Thats good new, thanks!
