Convoy L6... XHP70 Beast!
4823 posts / 0 new
giorgoskok
giorgoskok's picture
I understand how you think , but it thought i would mention it if anyone has the emitter as 6V in his mind while reading your post . Thumbs Up
DB Custom
DB Custom's picture
Last seen: 3 days 15 hours ago
Convoluted, that’s what it is.
There is no 4V equation here. The XP-L’s in the Q8 pull 3.3-3.6V, even though the cells are 4.2V when charged. Similarly, there is no 6V equation in the L6 with XHP-70 or 70.2, since that emitters forward voltage is over 6V, especially when pushed, so if you’re figuring wattage of each light then a more accurate reading of voltage and amperage needs to be taken at the emitters. The Cree datasheet on the 70.2 shows that at 4.8A max current the Vf is between 5.6V and 6.1V, so figuring in 4V just to play easy with the math doesn’t actually equate to what’s going on. In the same way, Giorgo was exactly right in that 2 26650’s in the L6 are an 8.4V 5000mAh battery. Pushing the 70.2 hard with an FET driver has it’s Vf up around 6.8V or more, so there is a 6.8Vf on a falling 8.4V power supply. You can’t divide up the amperage being drawn just to satisfy easy math. 12A at 6.8V (2 parallel 2 series emitters) is 81.6 watts of power being consumed, in the same way that 21A at ~3.6V (4 parallel emitters) is 75.6 watts in an over- driven Q8. Since the 4 cells of the Q8 (all 4 cells together, a battery) are being drawn on in parallel, using 3000mAh cells will indeed give 12,000mAh of power supply, so the battery is running at a 1.75C draw, while in the L6 (at 12A) the 5000mAh battery is seeing a 2.4C draw, obviously falling faster due to the extra hit they’re taking.
Dealing with actual numbers, real time at-the-emitter voltages and amperages, makes it easier to understand where the heat is coming from and why the cells drain so fast. For me, anyway.
And for the record, merely swapping XP-L2’s into a Q8 only nets around 7300 lumens, even with spring bypasses. More needs to be done to get more output. And my Q8 with SST-40’s is making over 11,200 lumens on rested VTC5A cells.
JasonWW
JasonWW's picture
Last seen: 42 min 47 sec ago
Thanks Dale. I have a tendency to over simplify things to make it easier to understand. I’m like a elementary school teacher and your like a high school teacher. Lol
klrman
klrman's picture
Last seen: 1 week 3 days ago
One of my L6 stopped working.  Oddly enough, the one I don't use and keep in the box as new.
I have a few L6's so could swap things around to determine what is going and so far no luck.
1 Tail cap is working
2 Batteries are working
3 battery tube works on other L6's no problem.
4 Head does not work when using on my other L6's
KawiBoy1428
KawiBoy1428's picture
Last seen: 10 min 35 sec ago
klrman wrote:
One of my L6 stopped working.  Oddly enough, the one I don’t use and keep in the box as new.
I have a few L6’s so could swap things around to determine what is going and so far no luck.
3 battery tube works on other L6’s no problem.
4 Head does not work when using on my other L6’s
Driver retaining ring tight?
KB1428 “Live Life WOT
klrman
klrman's picture
Ring was tight but you were close!  Had to get out my magnifying glass and I see the spring bypass wire has dislodged.  This is the L6 I posted a long time ago was causing on and off problems, but now we got it.
I'm not the best at soldering, but I'll give it a try.  Looks tight in there!  Any tips are more than welcome.
KawiBoy1428
I’m not the best at soldering, but I’ll give it a try.  Looks tight in there!  Any tips are more than welcome.
It should still work with out the bypass…unless the bypass touched earth (ground)!
Then it might have fried the driver, maybe…
klrman
klrman's picture
Well, goes to show you how much  I know.  Maybe the driver is fried or something, but I never smelled anything when I used it in the beginning to test it.
I don't see that the wire touched ground anywhere.  It was hanging loose in the middle.
Now that I think about it, wire could have touched ground when the batteries were in and the spring compressed.  Are  there any  tests I can do to determine for sure if the driver is fried?
KawiBoy1428
This usually happens when batteries are too long and the springs bottom out, breaking the bypass, like I said usually. could be a weak solder joint ,who knows?
The IC or Buck is pretty tough, some are, they can take a bit of abuse to a point, depending how long or how HOT is got during the ground short. IF this is what happened? Can you pop the driver out and take a pic of the other side?
klrman
klrman's picture
Ok, Will give it a try now and pull the driver and post a pic.  Might take a little while as this is my first time doing that.
I need to go to the hardware store and get some ring tool as the driver is really tight in their.  Will post a pic tonight if I
can get it out.
KawiBoy1428
Well the saving grace is by the looks of your pic, the bypass is still contained within the spring, so lets hope for the best! Not knowing the history of what has been done or tried to the light to get it to work?
It could have popped in and out of the spring during the attempts to get the light working?
It could be just a bad switch wire? I’m looking for the stock driver in the meantime, should have a bunch of them some where? Facepalm
klrman
klrman's picture
I didn't do much to get it work, just today a few minutes switching battery tubes and tail caps that's all.  I also have another driver sitting in my box that I ordered from Simon for the L6 so if all fails, I can try that.  Tonight some time I will have it all apart first and see how it all looks.  Maybe it is just a bad switch wire in the head.
KawiBoy1428
klrman wrote:
I didn’t do much to get it work, just today a few minutes switching battery tubes and tail caps that’s all.  I also have another driver sitting in my box that I ordered from Simon for the L6 so if all fails, I can try that.  Tonight some time I will have it all apart first and see how it all looks.  Maybe it is just a bad switch wire in the head.
Cool check your switch wires! I found a couple of the L6 stock drivers. And going by memory and what I see on the stock driver is the Black lead going to the LED is really close to the ground ring. Now if the driver cavity pocket is oversize and the retainer ring is a bit sloppy, IT could be Possible that the Black lead going to the LED might be grounded out and the driver is not seeing the signal? A possibility….
klrman
klrman's picture
That could explain why sometimes it would work and sometimes not possibly.  I never used that particular L6 more than just testing it a few times if it would work.  All of a sudden in the past it did and I thought everything was fine.  I do remember someone helping me out before as I had the wrong end of the battery tube screwed into the head and they noticed it from the pic I posted.
KawiBoy1428
It also could explain why the driver spring bypass is broken, bottoming out the springs puts force on the driver pcb, could have moved the driver/retaining ring over while twisting everything together. I don’t really know until I have the light in my hands, and I could test it, but I have heard of, done/seen some pretty strange/un-explainable things and shit happens! Big Smile
Lexel
Lexel's picture
Last seen: 1 month 6 days ago
I did some new stuff
I made it possible to run a tail light board for the L6
Best is to use very efficient LEDs to keep the bleeder and tail board parasitic drain low
But for the sage Rainbow is also possible
Also side switch LED Board like this available now
I have 10 colors of LEDs it is possible to mix all kind of them as each LED has its own balance resistor
klrman
klrman's picture
KawiBoy1428 wrote:
It also could explain why the driver spring bypass is broken, bottoming out the springs puts force on the driver pcb, could have moved the driver/retaining ring over while twisting everything together. I don't really know until I have the light in my hands, and I could test it, but I have heard of, done/seen some pretty strange/un-explainable things and shit happens! :D
You got me thinking there so I whipped out my digital calipers and the tail end inner ridge to the end of the threads is 11.50mm and the head end of the tube measures 12mm, so there would not have been any extra pressure on the driver, just a little less and when I insert the batteries with the tube switched, they still protrude the same amount past the tail end.
klrman
klrman's picture
Lexel wrote:
I did some new stuff I made it possible to run a tail light board for the L6 Best is to use very efficient LEDs to keep the bleeder and tail board parasitic drain low But for the sage Rainbow is also possible !{width:50%}http://www.metronixlaser.de/bilder/flashlight/IMG_5220.jpg! Also side switch LED Board like this available now !{width:50%}http://www.metronixlaser.de/bilder/flashlight/Astrolux_MF02/IMG_4953.jpg! I have 10 colors of LEDs it is possible to mix all kind of them as each LED has its own balance resistor
Very nice Lexel, do you have part numbers yet so we can order?
Lexel
Lexel's picture
There is no parts list, I will sell those for a fair price
I spend a lot time to make it work that way and designing the boards
I will make them with a max current and option for 2 potentiometers that can tune about 30-100%
The boards are the easy part, tuning the LEDs was quite time consuming
Biggest thing is you literally need for each LED and each max current of the bord different values
I measured this to find the right values that took a lot time
The LEDs are from various chineese shops and likely not all the same
of course if you do not get the same LEDs the resistor values wont match
First I tried it on my regular 6x tail boards with conventional 6 Balance resistors and a 1kOhm Bleeder
Main Problem was that with low battery voltage the higher voltage LEds (Blue, White, pink, ice blue) get dimmer tan the low voltage ones (red, yellow, green)
I came up to enhance this idea with a voltage regulator, but had to do some steps to make it work
first get the voltage and resistor value for each LED at the same brightness
Then I made some calculation to get fixed current draw versions
But when I made the prototypes I saw that this is pointing in the right direction
but a lot manual changes were needed to equal them out on different board currents
It is also possible to use this with side switch lights like Convoy L6, as I can get the parasitic drain for the 18kOhm bleeder down to 0.4mA when the tail board has 0.15mA for the LEDs
Now the first 4 Prototypes
I did quite some measurements and tests to even out the brighteness of them
Firt L6/L2 prototypes are build and successfully tested on my bench, modding the lights will follow
One tme i skipped the very current hungry Emerald green for a warm white
The tail board itself uses a voltage regulator so the brightness is constant down to 3V cell voltage and can be fitted with 1S or 2S voltage regulator
The 2S Voltage regulator has a 0.1mA higher drain
I haver also ordered fitting 3×3mm trimmers so that the brightness of the board can be adjusted for 2V and 2.5V LEds in 2 groups
On the other hand I can also build em with a current draw from 0.15-1mA with the balance resistors without trimmers
The rainbow LED boards have one drawback which are the inefficient Emerald green and yellow LEDs,
so their brightness is lower than green or white LEDs at the same current
The LEDs are all measured by me and trimmed to equal brightness
The thing is adding the tail cap cover I also saw some colors do not get equally through it, so again minor changes were needed
klrman
klrman's picture
Lexel, after reading your post, I think I can confirm that I am still in the dark ages when it comes to electronics. You sure put a lot of research and work into this project to make it work, hats off to  you.
Lexel
Lexel's picture
The simple Layout without a voltage regulator is shared on oshpark
Those work great with 2-3 colors that have about the same LED voltage or you will see one LED type getting dimmer with droping cell voltage
you can find them here as well a lot other shared stuff
http://budgetlightforum.com/node/57488
The ones with balance resistors for each LED are better
klrman
klrman's picture
KawiBoy1428 wrote:
This usually happens when batteries are too long and the springs bottom out, breaking the bypass, like I said usually. could be a weak solder joint ,who knows? p. The IC or Buck is pretty tough, some are, they can take a bit of abuse to a point, depending how long or how HOT is got during the ground short. IF this is what happened? Can you pop the driver out and take a pic of the other side?
Here is the driver.  I don't see anything out of the ordinary as to why the light doesn't work?
BTW, I unscrewed the star with the LED on it thinking I need it to expose the driver more. Now I know I did not need to do that.
Anyway, the star came off the heat sink with some silvery grey powder residue.  I assume I need this paste before putting
the star back on?
KawiBoy1428
Good the Leads and switch wires are still attached, I have had LED leads/Switch wires either break or come loose due to cold solder joints.Can you hook up a 2S 8.4v battery set up to the driver and see if it works, now the driver is clear.
klrman
klrman's picture
I probably could but I don't know how
KawiBoy1428
I have a quite a few good 18650 Laptop pulls so I soldered 2 in series and then soldered leads to the ends for quick portable Brewster Projects home boy testing. Big Smile
https://en.wikipedia.org/wiki/Brewster-Douglass_Housing_Projects
klrman
klrman's picture
KawiBoy1428 wrote:
I have a quite a few good 18650 Laptop pulls so I soldered 2 in series and then soldered leads to the ends for quick portable Brewster Projects home boy testing. Big Smile p. !{width:50%}https://s19.postimg.org/ysb8dx1qb/IMG_20180217_014604.jpg! !{width:50%}https://s19.postimg.org/ldy5i6kv7/IMG_20180217_014737.jpg! p. https://en.wikipedia.org/wiki/Brewster-Douglass_Housing_Projects[/quote]
I like your setup, good old fashion engineering   Is there any easier way for me to test the driver though?
KawiBoy1428
You could ring it out with a DMM, check for ground short, ground ring on the driver to the driver spring. E-switch should/could blip once, but if it is truly grounded out will continue to ring.
The battery/power set-up is just easier to check the whole set-up. You can remove the leads from the star and check the LED off the battery set-up too. Just don’t over heat the LED it’s going to get HOT real fast!
klrman
klrman's picture
Ok, I will run a few tests and see if I can figure out what is going on there.  I'm going to watch a few how to youtube vids first just to make sure I know what I am doing.
klrman
klrman's picture
I touched the LED + and - terminals briefly with a little 9v battery that I wired up and the L6 led lights up, so  I don't think there is anything left except that the driver died for no reason  unless anyone else has any ideas?  BTW what paste is recommended to use to mount the the star on the heat sink?
bilakos10
bilakos10's picture
Last seen: 2 hours 37 min ago
klrman wrote:
I touched the LED + and – terminals briefly with a little 9v battery that I wired up and the L6 led lights up, so  I don’t think there is anything left except that the driver died for no reason  unless anyone else has any ideas?  BTW what paste is recommended to use to mount the the star on the heat sink?
Try to jiggle all the components of the driver to see if anything has be unsoldered from its pad.
Also set your multimeter in Ohms and check the resistance between the power wires.
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
