Olight S1 Limited versions
23 posts / 0 new
Tete
Last seen: 2 days 4 hours ago
Have the amounts of each different finish been stated anywhere?
Tried to search, but all I found was that there will be 5000 Titanium-ones being made. But how are those divided between the two options?
And the Copper-ones?
will34
will34's picture
Last seen: 1 hour 55 min ago
I ordered a Raw copper with SS bezel from goinggear. Supposedly it was exclusive to them and limited to only 500pcs. Coated copper with SS and blue bezel are available in many other shops, I don’t believe this one would have any collective value of some sorts. This one is being made by the thousands.
Olights are not available from several chinese shops anymore because of MAP policy violations, but there are decent coupons that you can use on Goinggear and Illumn, both USA sellers.
freeme
freeme's picture
Last seen: 6 hours 9 min ago
Cu with SS is not exclusive from what I saw. Perhaps they have the smaller serial numbers?
will34 wrote:
I ordered a Raw copper with SS bezel from goinggear. Supposedly it was exclusive to them and limited to only 500pcs. Coated copper with SS and blue bezel are available in many other shops, I don't believe this one would have any collective value of some sorts. This one is being made by the thousands. Olights are not available from several chinese shops anymore because of MAP policy violations, but there are decent coupons that you can use on Goinggear and Illumn, both USA sellers.
©freemex1thedeals.com
will34
will34's picture
According to GG, the RAW Cu + SS Bezel is exclusive to them, I was able to find Cu + SS elsewhere but is was the coated copper version, IMO not as nice as bare copper… http://goinggear.com/featured-products/olight-s1-cu-baton-exclusive-raw-...
freeme
freeme's picture
And it is much cheaper than GG.
will34 wrote:
According to GG, the RAW Cu + SS Bezel is exclusive to them, I was able to find Cu + SS elsewhere but is was the coated copper version, IMO not as nice as bare copper... http://goinggear.com/featured-products/olight-s1-cu-baton-exclusive-raw-...
will34
will34's picture
Sounds interesting.. do you have a link? I’m also after the titanium one
Gunga
Gunga's picture
Last seen: 1 day 15 hours ago
Me too.
Old Mate
Last seen: 4 days 13 hours ago
Tete wrote:
Have the amounts of each different finish been stated anywhere? Tried to search, but all I found was that there will be 5000 Titanium-ones being made. But how are those divided between the two options? And the Copper-ones?
I also wondered about the titanium 5000 limited number quoted, i thought there might be 2500/2500 polished/ sand blasted but when i got my polished version the serial number is 2515.
So it may be there are more polished s1,s than bead blasted, or 5000 of each version, or for some reason, they split the number between the two finishes- a bit confusing.
Old Mate
Tete
My thoughts exactly! The Ti-one, I got, is 2652…
mortuus
mortuus's picture
Last seen: 1 hour 19 min ago
Im interested in the S1 titanium version but i wonder how easy is it to scratch the finish, is it well done or sloppy ?
...where Frugal meets with Flashlight!
wedlpine
I’m sure the finish is well done, but Titanium does scratch relatively easy compared to HAIII Aluminum.
will34
will34's picture
Polished titanium is a bit tougher than SS but still prone to scratches, however bead blasted titanium finish is very tough, I have a Titanium coyoo bead blasted finish in my keychain and after 3 months still no signs of any scratch.
wedlpine
will34 wrote:
Polished titanium is a bit tougher than SS but still prone to scratches…
I have found just the opposite. My polished Titanium Maratac aaa scratches way easier then my polished SS Maratac aaa.
mortuus
mortuus's picture
okay i see thanks for your answers Smile
AaLF
Last seen: 2 years 11 months ago
1) How does the S1 Baton titanium hold up scratch-wise now you guys have had one for a few months?
2) Read a complaint elsewhere that the lumens is much less than the black version + the light appears ‘yellow’. Agreed or dismiss the complaint?
Tete
Well, I have both Ti-versions, but they mostly sit on the shelf, so no scratching happening to my samples…
And since the Ti has NW-emitter instead of the CW-ones found in Cu- and standardversions, I guess you can call it “yellow”. Hence the appearence being “dimmer”. Lumen difference is supposed to be only 20 and at least to my eyes, that seems quite accurate…
KeepingItLight
KeepingItLight's picture
Last seen: 1 day 3 hours ago
I was pleasantly surprised to discover that my Olight S1 Copper Rose Gold flashlight has a relatively neutral beam. It is advertised as cool white, and certainly it is cooler than the "neutral-white" titanium edition.
I come from the world of photography, where anything between about 5000K and 5600K is considered to be neutral. Based on that, and also on testing against white walls and various light-colored wood targets, I would describe the tint of my copper S1 as neutral.
Maukka confirmed my observations when he measured output from his copper S1. He measured CCT at 5410K.
maukka wrote:
CRI Chart for Olight S1
Source: http://budgetlightforum.com/node/44469
Sad to say, maukka also reported that CRI on his S1 was the lowest that he had measured on any flashlight up to that time.
I do not have any measurements for the Ti edition that Olight sells as "neutral white." I believe it is at least 1000K cooler, i.e., its CCT is in the range 4000K to 4400K.
AaLF
KeepingItLight wrote:
I was pleasantly surprised to discover that my Olight S1 Copper Rose Gold flashlight has a relatively neutral beam. It is advertised as cool white, and certainly it is cooler than the “neutral-white” titanium edition.
I do not have any measurements for the Ti edition that Olight sells as “neutral white.” I believe it is at least 1000K cooler, i.e., its CCT is in the range 4000K to 4400K.
Thanks. Yes Ive heard that before that about 5000k is optimum light. That ends my titanium quest.
xevious
xevious's picture
Last seen: 4 hours 57 min ago
The Titanium S1 that I received seems different from the stock photos I’d seen of the S1 Ti polished.
Mine has the copper colored accents, instead of the blue color. Here’s a stock photo of what it should look like: PHOTO LINK.
But what makes mine different is the tint of the titanium body. Rather than being a brightly polished “chrome-like” finish, it’s almost like a “dark chrome”. I think it’s terrific as I was a little concerned about the light being too shiny in the polished titanium version. It looks like this:
Is this how it was supposed to be? Or did Olight make some kind of batch variation on the S1 Ti polished models? The stock photos certainly show it looking more like a bright silver finish.
-X3-
-X3-'s picture
Last seen: 13 hours 33 min ago
Titanium is darker than steel
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
xevious
xevious's picture
I’ve seen some examples of polished titanium flashlights looking very bright, almost like polished stainless steel.
Tete
I got my S1 with the copper accents, too. Seems that the first batch had the blue ones and latter ones copper. Which was actually a shame since I’d preferred the blue. And points to HK Equipment for verifying before shipping the light!
What comes to the color of titanium, at least my S1 looks very bright, almost like polished SS, as you described. And compared to the titanium S30, I have, they are the same…
xevious
xevious's picture
I’m finding in bright sunlight, the finish shines pretty brightly… it’s only in shaded or indoors where it looks less brightly polished than stainless steel. It’s a little fragile too… already noticed a couple minor scratches and I’ve not pocketed the light with keys.
I’m a bit disappointed in not having a lockout. That’s a really nice feature to have, especially if you are pocketing.
You can’t run the S1 too long on high. I find within 5 minutes it becomes very warm to the touch.
I must say that the tint is absolutely fantastic. Probably the most neutral tint I’ve ever seen. I wonder if this is exclusive to the titanium version, or if you can get this tint on the aluminum models?
