Groupbuy for UNI-T UT210e clamp meter for tailcap current readings
258 posts / 0 new
mattheww
mattheww's picture
Yes it would be nice to now. There are over 70 people signed up, so the problem definitely isn’t lack of interest on the part of buyers. However I don’t have a lot of patience. If the GB doesn’t happen within the next week, I’ll probably just buy one elsewhere. They can be bought for about $36 from US based Sellers on eBay. The box I see is that if the GB doesn’t happen in the next week or so, we are looking at a roughly 4 week delay because of Chinese New Year, so delivery ends up Late February-Early March. Don’t know about others, but generally I buy things because I need them, and I tend to need them sooner rather than later. It doesn’t seem to me that 6-8 week delivery time frame is worth the $5-$8 we may save on the GB.
Tom E
Tom E's picture
Last seen: 1 hour 50 min ago
Got a UT210E today from Tomtop - wow, excellent! I thought my DMM setup was pretty tweaked, but did a couple of quick comparisons, measuring at the tail. I got 14 AWG leads on my DMM, and used a short 16 AWG wire looped thru the clamp meter wit wire from the cell minus to the battery tube edge:
  • new Nitefighter F30B stock: 2.31A on the DMM, 2.41A on the UT210E
  • fully modded Convoy L2 (dedomed U4 1C, FET+1 driver): 5.09A on the DMM, 5.43A on the UT210E
This is sort of what I might expect - low amps close, high amps the clamp meter shows higher. Still I was thinking in the 3A and below range, my DM tail readings were pretty good, matching well with the # of 7135's I'm using in the drivers.
UT210E readings are with ZERO'ing before taking readings, and using the 20A scale.
For the group buy, freeme has been OD'ed on GB's, so he's catch'n up now - should happen real soon (hoping...), along with the BOSS1. I think GB's out of the norm are probably more involved, norm being stock Olight, SWM, NiteCore, etc...
MRsDNF
MRsDNF's picture
Last seen: 9 min 41 sec ago
Thanks for the update Tom E. Does your clamp meter hold a steady reading or does it waver slightly?
freeme
freeme's picture
Last seen: 57 min 9 sec ago
I will PM to all in awhile. Cool
pilotdog68
pilotdog68's picture
Last seen: 4 hours 31 min ago
That’s exciting… Should I wait up? Wink
Vene67
Very nice, if soon can start ordering
DB Custom
DB Custom's picture
Last seen: 4 hours 37 min ago
Tom, do you have any Triple’s you could measure? On that theme of more is more, it’d be interesting to see what would happen at the top end of your DMM.
I have single cell lights pulling 17-21Amps. One is even a single emitter light! This alone is worth getting the clamp meter for, as the DMM would surely fry up there.
bugsy36
bugsy36's picture
Last seen: 1 year 4 months ago
Ah hell. Add me to the list also.
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
Vene67
Firts unit ordered, great and many thanks to freeme !!
Second as well.
fran82
Last seen: 5 hours 5 min ago
Received PM. Thanks freeme! I will order asap!!
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
aslpg
Last seen: 1 day 12 hours ago
UT210E ordered. Thank you!
Henk4U2
Henk4U2's picture
Last seen: 2 hours 45 min ago
UT210E ordered. Thank you freeme!
Hope it gets shipped before Chinese Newyear. Waiting to compare the readings of this one to those of my old DMM.
I always think long and hard before I say something really stupid.
luminarium iaculator
luminarium iaculator's picture
Last seen: 17 hours 9 min ago
I have this meter for more than a year and half and I really don't know how to zero it Smile
I also got much higher readings than with dmm for high current draw lights.
Also I would suggest very hard press to both surfaces (battery - and exposed aluminum on flashlight, or you could get lower readings).
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
Zanders
Tom E wrote:
Got a UT210E today from Tomtop – wow, excellent! I thought my DMM setup was pretty tweaked, but did a couple of quick comparisons, measuring at the tail. I got 14 AWG leads on my DMM, and used a short 16 AWG wire looped thru the clamp meter wit wire from the cell minus to the battery tube edge:
This is sort of what I might expect – low amps close, high amps the clamp meter shows higher. Still I was thinking in the 3A and below range, my DM tail readings were pretty good, matching well with the # of 7135’s I’m using in the drivers.
UT210E readings are with ZERO’ing before taking readings, and using the 20A scale.
For the group buy, freeme has been OD’ed on GB’s, so he’s catch’n up now – should happen real soon (hoping…), along with the BOSS1. I think GB’s out of the norm are probably more involved, norm being stock Olight, SWM, NiteCore, etc…
What happens if you turn the cable the other way around in the clamp?
I got a UNI-T UT203 that I useally use for higher amp readings and when I messure it with the cables the other way I got higher readings.
anduril
Last seen: 1 year 8 months ago
PM the info please.
JamesB
Last seen: 6 hours 32 min ago
I’m on the list Freeme, could you send me the code? thanks for your efforts !
Tom E
Tom E's picture
DB Custom wrote:
Tom, do you have any Triple's you could measure? On that theme of more is more, it'd be interesting to see what would happen at the top end of your DMM. I have single cell lights pulling 17-21Amps. One is even a single emitter light! This alone is worth getting the clamp meter for, as the DMM would surely fry up there.
My DMM is rated up to 20A (UT50B here at FT), so don't think it's a problem, maybe?? I do have a couple triples - one S2, one X6, one quad X6, one quad SupFire.
Tom E
Tom E's picture
Zanders wrote:
What happens if you turn the cable the other way around in the clamp? I got a UNI-T UT203 that I useally use for higher amp readings and when I messure it with the cables the other way I got higher readings.
I did do some quick testing on that - pretty sure when the clamp meter read negative, the amps readings was lower. @work now - no access.
Tom E
Tom E's picture
Mine has a black button labeled: ZERO, press it, and the reading zeroes ?? Yes - I do always press hard, but also found a little NO-OX-ID treatment helps bump up the readings by improving connectivity at the contact points.
Again over the years, very consistent 2.9A to 3.0A readings with my DMM on 2.8A Nanjg 350 7135 drivers, so always thought my DMM setup was dead-on accurate for these relatively low amp readings. Again, drivers with 350 7135's always read high, 380 7135's always read low. Others have commented on the same thing.
I really need to do more head-to-head testing though, plus I didn't do it today, but plan on bringing my lights/meters into work and compare against the o-scopes with clamp meter attachments we have here. We got Tektronix, Fluke, and I was told the clamp meter attachments were pretty expensive, but I'll get more info on the equipment first. Don't think we do much here with this level of DC voltage at amps this high, but not sure.
DEL
DEL's picture
Last seen: 11 months 3 weeks ago
One thing to consider is that the meter type has a much bigger impact on DD lights than current-regulated lights.
You can use a multi-meter with a relatively high burden voltage (shunt + fuse + leads resistance) and it will give good results with a regulated light. The driver will simply compensate to get to the correct output current, as long as the cell voltage is high enough.
But that high burden voltage will make a significant difference when measuring a DD light.
Tom E
Tom E's picture
Ahh, thanks DEL - was suspecting something like that.
Lazy-R-us
Last seen: 2 weeks 5 days ago
Sprung for insurance, order tracking and and slightly upgraded the shipping to priority direct.
Thanks for the code Freeme, I used your link, but I copy/pasted from one browser to another, not sure how that works.
For those who already have this meter from Banggood, how are the included test leads?
Lazy-R-us
TheBo
TheBo's picture
Last seen: 7 months 3 days ago
mmm they are standard decent quality AWG14 (externally look-wise, not written) famous brand chinese cable, pretty much identical to mastech
Rufusbduck wrote:
Getting discouraged is normal but doesn't finish the job.
jhullin
Last seen: 11 months 6 days ago
ordered. Thanks very much
ImA4Wheelr
Last seen: 8 hours 26 min ago
Ordered 1.  Posted a thank you to freeme in his thread.  I'll post a thank you to PD68 here.  Smile
OscarM
I ordered mine just now. Thanks for making me buying things i didn’t realize i needed before Silly
Intruderdriver
Intruderdriver's picture
Last seen: 6 months 1 week ago
Just ordered mine. Thanks for setting this up!
kronological
kronological's picture
How much is it?
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
freeme
freeme's picture
$28
kronological wrote:
How much is it?
MRsDNF
MRsDNF's picture
kronological wrote:
How much is it?
With the effort you put in here it should be free from the supplier. freeme is organising this.
Edit. Took to long to type. Smile
