Test/Review of TrustFire IMR16340 700mAh (Red)
Official specifications:
  • Battery Capacity (FastTech Tested): 600 mAh
  • Battery Capacity (Mfg Rated): 700 mAh
  • Battery Chemistry: Li-Ion
  • Battery Feature: Rechargeable
  • Battery Form Factor: 16340
  • Battery Maximum Voltage: 4.20 ± 0.05 V
  • Battery Rated Voltage: 3.7 V
  • Electrolyte: LiPF6
  • Battery core: LiNiCOMnO2-C
TrustFire is not the best brand around, how well do these high current cells work?
The curves do not match, but are in the same range, current handling looks acceptable for IMR cells (They are not that different from other brands).
Conclusion
The high current performance for this cell is about average, the cell matching is worse than average.
Notes and links
Comparison to other LiIon batteries
Thanks.
I have a couple of these, I use them in single cell lights and they seem to do fine. I now will never use them in series after seeing the mismatch between your examples.
Thanks again HKJ!
