What did you mod today?
9461 posts / 0 new
djozz
djozz's picture
Last seen: 2 hours 10 min ago
Etex wrote:
djozz wrote:
This is my take on a lantern attachment for he Q8. My girlfriend thinks it is ugly but I think it …
I’m curious if the reflector is actually doing anything useful, in this setup. Have you tried it without?
It does good things, quite some light that comes off the hood’s white surface gets back into the head, and because everything is shiny in there almost all of it is not lost but is just reflected back out again for another chance to leave the light. But I agree that the shape of the reflector is of no influence on the beam/output.
MRsDNF
MRsDNF's picture
Last seen: 20 hours 52 min ago
Nice mod djozz. Its very creative the way you have attached the hood. Had me thinking for awhile. Thumbs Up
DB Custom
DB Custom's picture
Last seen: 1 week 15 hours ago
Quite a while back, I modified my SupFire M6 to FET with 7 modes and reversing. It had XM-L2’s in it and a lockout tail switch. Today I got some SST-40’s in, so I swapped them in and re-flashed the driver (piggybacked FET) with Ramping firmware from TK.
Now, with a rested set of 30Q button tops, it makes 8866.5 lumens at the top level, 23.84 at the bottom. That’s over 3000 lumens increase, for swapping in a new emitter. Pretty sweet! Smile
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 1 min ago
I finally opened my first D4 one too many times and broke a switch wire. Opened it up, took everything apart, soldered new wires onto the switch PCB, soldered them onto the driver, went to put the driver back in, and one of the switch wires fell off again. Those switch PCB contacts are tiny and fragile and hard to attach anything to.
So I got the switch out again, tried to re-connect the wire, and the pad refused to take any solder. While trying to fix that, I managed to melt the switch itself into two pieces.
Fail.
I eventually got it working again, but I had to sacrifice parts from a dev host.
It reminds me of when I made some anagrams out of a friend’s name. One anagram was “Anna’s having oatmeal”. However, it can also spell “Oatmeal’s having Anna”. It seemed fitting; she can pick one or the other depending on how her day is going.
Today is definitely an “Oatmeal’s having Anna” kind of day.
Jensen567
Last seen: 1 year 3 months ago
More fun with boost drivers and tint/emitter mixing today. Finished my Convoy M1 kiriba-ru quad build today. Emitters are run in 2S2P on one of Richards MTN Quad boards.
I have 4 different nichias, 219B SW45K R9080 in series with a 219C SM303 R9050, and 219B SW40 R9080 in series with 219C SM4070e R9050.
The result is a beautiful 3800k-ish beam with a bit of rosyness and no yellow at all really to my eyes. My favorite light I’ve ever built actually. The beam on the 25mm Khatod quad optics is excellent as well, much nicer than the Carclo IMHO.
I have to thank Clemence for making these emitters available, kiriba-ru for making the M1 quad kit available, RMM for making the quad boards available, and Kaidomain for making a quality boost driver (H1-A) easily available. Wouldn’t be possible without their efforts too.
The white balance and exposure on the beamshot don’t do it justice, but the best I could do on my phone.
Jensen567
Also because I didn’t post it in this thread last time, here is my previous mixed emitter build. Mostly done just to show off why I find boost drivers to be advantageous. It is a Convoy S2+ with a kiriba-ru triple pill, modified to accept a 20mm driver so I can run H1-A. Optics are Carclo 10507
Emitters are a Nichia 219B SW40 R9080, Nichia 319A SM355 R8000, and Cree XP-G3 30G 80+ CRI. Result is a 3500k-ish beam which is quite nice, and thankfully doesn’t exhibit the tint shift of the XP-G3 once blended with the nichias.
Being able to freely mix emitters regardless of Vf in multi-emitter lights is a game changer IMO, and is one of the reasons I adopted boost drivers for almost all of my multi-emitter builds now. I will be running series emitters whenever possible from here out.
ZozzV6
ZozzV6's picture
Last seen: 1 day 7 hours ago
The H1-A isn’t for 6V emitters? 3pieces of 3V leds in series need 9V or not? Or you mod something on driver too?
LightRider
LightRider's picture
Last seen: 2 years 5 months ago
@Jensen567
Very nice! I would like to try something like this. I only WISH the H1-A had an eswitch version!
Jensen567
ZozzV6:
You are correct. Stock the H1-A is suited for 6V emitters (like the 2S2P), but by changing one of the 47k feedback resistors to a 75k it can be setup for 9V operation no problem. I have several setup that way now, some have been running for a couple of months without issue.
LightRider:
I agree that they should make an e-switch version available, the MCU has a free pin which could be used for it. In the meantime, BLF user Cousin Elmer has written some basic custom firmware for the PIC on H1-A, so e-switch could likely be added if you’re willing to flash it yourself.
ZozzV6
ZozzV6's picture
Jensen567 That is awsome. I think I will buy some. How much current it can put on the leds?
Jensen567
You are limited by the 10A input ceiling on the TPS61088 chip, so you can get about 24W fully regulated. Can do less too, tune the sense resistor to get the desired output. In my triples I usually use an R030 which is about 2.4A, for the 6V stuff I usually go with R020 which is good for about 3.5A. Stock is R025 which is a bit over 2.8A.
LightRider
Jensen567 wrote:
LightRider:
Really! What do I need to be able to flash? I suppose not usbasp, atmel studio, and avrdud and such?
Jensen567
Either the microchip ICD3 programmer, a PICKit, or Cousin Elmer built something out of a raspberry pi that he is using. There is some minor PCB modification to be done as well so you can pull the MCLR pin to programming voltage. Or you can just pull the IC off, program it, then stick it back on if you don’t change it often.
g_damian
g_damian's picture
Last seen: 4 hours 6 min ago
I’ve put triple Nichia 219C 4000K CRI92 into S41:
Album: on imgur
Original thread
Jensen567
Kaidomain triple? Nice emitters! I like the KD optics too.
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 2 min ago
Just wondering if it’s a possibility, but couldn’t you just air wire a 13a MCU instead?
KB1428 “Live Life WOT
Jensen567
You could if you have the space in the host for it.
KawiBoy1428
Cool, I just might attempt it, if I new how? Big Smile
Now if the driver originally was push button driver, and I wire up a 13a e-switch MCU it should work, since I’m going thru this MCU, or would I need something else?
Lexel
Lexel's picture
Last seen: 1 day 17 hours ago
Q8 modded
- cleaned the brass ring
- 3.2mm holes and countersunk 120° on the driver
- spring bypass
- Reflector screw replaced and LEDs centered
- original lubricant with a lot eloxal removed and replaced
- glue from all holes removed cutting the threads again
- some glue from the tubes tail blank surfaces removed
Unsoldered LEDs and switch just holding my temp stabilized iron at 300°C at the other side
also skillet might work well
then cut the trace to one LED and add a resistor
add solder paste
add resistor and wire
2 white LEDs with 19.1kOhms each
the camera might be false because of the button here, both are excactly the same brightness
vwpieces
vwpieces's picture
Last seen: 11 hours 28 min ago
Cool stuff Lexel.
basically same to mine with only one 0805 size 22K resistor in original placement, it barely fit, but works. My white LEDs are also blue under the cap, not that blue to the eye but camera looks more blue.
staticx57
Last seen: 27 min 55 sec ago
Lexel, I find you work to be remarkable. Always enjoy seeing your creativity.
-X3-
-X3-'s picture
Last seen: 12 hours 3 min ago
I swapped the emitter in my D4 few weeks ago for the KD 4000K ones, and today I decided to slice the domes for a little more throw :
Before and after :
As expected, the throw is improved and the tint has changed for a more rosy beam, nothing bad at all Smile
Unfortunately, the beam is now more square-ish, as in the XP-L HI version I would guess.
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
CRX
CRX's picture
Last seen: 3 weeks 10 min ago
Made a metal switch for the Noctigon M43
And did the D4 too
Tally-ho
Tally-ho's picture
Last seen: 2 hours 22 min ago
With 2 LEDs in diagonale, when seing this some people with OCD are going to be pissed.
CRX
CRX's picture
Tally-ho wrote:
With 2 LEDs in diagonale, when seing this some people with OCD are going to be pissed. !http://forum-images.hardware.fr/images/perso/vince_astuce.gif!
That is the way they are set out with the three different colours, just more noticeable now, but you’re right, I prefer it when the green ones are lit Big Smile
This is the third iteration of this mod
Tally-ho
Tally-ho's picture
I’d wish i had your skills and creativity.
CRX
CRX's picture
Thanks mate, but I wasn’t born with them, it’s more of a perseverance thing Big Smile
Anthon
Last seen: 5 hours 58 min ago
Got a Jaxman X1S XHP35 HI C4
Stock was pulling 1050lm and 110.000cd
swapped the emiter with a XHP35 E2 3C and added a R100 resistor to the driver
now it blasts 1650lm and 181.000cd.
It’s surprising how good is this flashlight with two inexpensive mods.
i42dk
i42dk's picture
Did my very first de-dome.
As it was my very first time doing this. I first tested the method on my “beater” light, an old “UltraFire XML-L2 U2 800lm 7000K”.
Got the sinkpad out, and left it in a sealed container with gasoline over night.
12 hours later the dome came off with no force at all, in one big piece. That was surprisingly easy Big Smile
Throw is better, more focused beam, and the color is warmer. But i do have to get used to the green’ish tint it has now.
somnambulism
Last seen: 11 months 3 weeks ago
lumenzilla wrote:
Last night, LED swap on Vollsion EOSLAMP SP11 from CREE XP-G2 to Nichia bin from Fasttech.
It’s warmer than I thought.
I did a similar thing, putting Nichia 219C (4000K, 90+ CRI) LEDs into a Vollsion SP11-S and Fenix E99Ti.
Left to right in these pictures: Vollsion SP11-S, Fenix E99Ti, BLF-348. Before and after.
Some more pictures
