What did you mod today?
9511 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 1 hour 49 min ago
I have a Solarforce L2P with an M3 head on it, modified it several years ago with a de-domed XM-L2 and Wights Rev 1 MOSFET driver, it had the big Vishay 07N02 on it. Already had a McClicky switch from the previous mod session.
Set out today to bring it up to date with an SST-40 emitter. Went fine til I put a fresh charged Sony VTC5A in it, at a bit over 9.7A the emitter balked, it’d light and show 5 modes but was very dim. So. I took it back apart and went a different direction using LED4Power’s LD2 driver and a new XM-L2 U4 1A emitter. Making a nice beam, pulling 4A at the tail on a VTC5 for 1090.2 lumens. Moon or the lowest setting is 4.5195 lumens, with a 61.41 lumen Low and 522.33 lumen High. I didn’t do any spring bypasses, figured to leave it in an eco mode set so it lasts longer. Wink
The SST40 showed me about 1600 lumens before it quit, using a VTC4 down to 3.78V.
Still, this old light now has a new modern driver and emitter, pretty nice light even by today’s standards. Seemed odd, going back to a P-60 style light. This one has a bigger reflector screwed onto the brass pill, but still. Oh well, it was something to do for a little while anyway. lol
ToyKeeper
ToyKeeper's picture
Last seen: 32 min 46 sec ago
I modded the moon today.
Well, maybe not *the* moon, but moon levels, at least.
I added dynamic CPU underclocking and some idle modes to make low levels more efficient. The result is that moon mode runtime went up by about 3X or 4X.
lumenzilla
lumenzilla's picture
Last seen: 3 days 16 hours ago
somnambulism wrote:
Some more pictures
Love the warm colors Love
glide 1
Last seen: 1 year 9 months ago
Thumbs Up
DB Custom
DB Custom's picture
l42dk, I need some of your gas! That’s a VERY clean de-dome! Nice work! Wink
mrheosuper
I change the led of my manker e14 to xp-e2 to amber red, change the driver to amc7135*8 for safety
Now it looks very “red” and quite scary to me Silly
(The wire on TIR is temporary, i removed it)
Forgot my pen
djozz
djozz's picture
Last seen: 8 hours 29 min ago
ehm, my E14 has 4 leds
CRX
CRX's picture
Last seen: 6 hours 12 min ago
USB rechargeable Emisar D4 with red locator light
Edit:
The heatshrink was keeping in too much heat so I removed it and tidied the tail up a bit
Nicolicous
Nicolicous's picture
Last seen: 8 hours 7 min ago
thumbs up for u CRX Thumbs Up
Nico -.-
mrheosuper
djozz wrote:
ehm, my E14 has 4 leds !{width:2%}http://rs1090.pbsrc.com/albums/i367/doggoneson/Emoticons%20ESB/think.gif...!
oops, i forgot to say i also change the mcpcb to fit the tir len, bought from kaidomain
Forgot my pen
agnelucio
agnelucio's picture
Last seen: 1 hour 8 min ago
I’ve been reading this and similar threads on here on a regular basis for the last year, but have not got involved despite doing lots of little projects and mods myself. Big Smile
So to start off, I’d like to mention my recent DQG Tiny 18650 mod, which I documented here:
http://budgetlightforum.com/node/56536
ZozzV6
ZozzV6's picture
Last seen: 3 weeks 6 days ago
Finally I got my UT02 open. It has very low output. Only 897 lumens and it drawed 2,2A from battery. It has an intensity of 74800 Cd. And throwed 547m.
I tried to heat carefully with a heat gun but I can not break the glue with a pipe wrench.
I wrapped the head neck with a thick wire and wrapped the tube with leather. Then I had a ball joint press tool for cars. I tightened it on the tube.
Then I managed to break the glue. It has a lot.
The glue sticked the PCB too So I needed to remove the reflector and the switch board. The switch board also glued a little. And the reflector ripped off the led from the MCPCB. Luckily nothing damaged so I can resolder it.
I was able to desolder the led positive wire from the switch hole so with a screwdriver I can push the PCB out through the shelf led wire hole.
Then resistor modded the driver with R100. Reflowed the led on MCPCB. And assembled it again.
After the mod it draws 3,65A from battery.
It puts out 1250 lumens
Intensity: 103000 Cd
Throw: 642m
Still under specifications but for this current draw it has pretty good numbers and the current bump is safe for both driver and led.
DB Custom
DB Custom's picture
I was given a Nitecore EA8 Caveman some time back, the one that takes 8 AA NiMH cells, and today I got around to modifying it so it has an up-to-date emitter. It was stock with an XM-L, I put an SST-40 in it on a thicker SinkPAD to better control heat. Nitecore claimed 900 lumens in stock form, now it does right at 1400 lumens, much better! Smile The low Vf of the Luminus emitter allows it to do half again the output of an XM-L, even at the relatively low power level from the 4S2P AA’s.
Still can’t figure out why my Nitecore EC4 drains batteries like it does…
Been shuffling a lot of stuff around today, reduced my Convoy L2 with XHP-35 from 4 26650’s to 4 26350’s, also reduced my 2X Shooter from 4 18650’s to 4 18350’s. Cleared up some cells for other lights and should me about ready to mod my TR-J20. [again.] Wink
khas
Last seen: 1 month 4 weeks ago
I downgraded my Emisar D1 :
From this :
To this :
The DD SST-40 has great output, but the tint of the XM-L2 T3 7A3 CRI90 is simply gorgeous.
i42dk
i42dk's picture
Last seen: 2 min 47 sec ago
Thanks Smile
If it’s any help, it was soaked 12 hours in unleaded “95 octane” (that’s what it’s called here in Denmark).
somnambulism
Last seen: 1 year 2 weeks ago
lumenzilla wrote:
Thanks!
It would be interesting if you did take a look at the moon — my testing has indicated a very subtle and slow pulsing, at about 2.4 µHz. Seems too slow and gradual to be PWM, almost like it’s stuck in an eternal ramping mode for some reason.
ToyKeeper
ToyKeeper's picture
You measured an oscillation with a cycle of 4.82 days?
Speaking of moons and µHz, did you know the moon’s synodic period runs at 0.392 µHz?
somnambulism
Ugh, I screwed up the math. Was going for a 28-day cycle Wink
luminarium iaculator
luminarium iaculator's picture
Last seen: 22 hours 36 min ago
vinte77
Last seen: 1 month 1 week ago
I got a chance to work on a light last night: stripped solarforce parts + kiribaru p60 neck, nichia 219b 9080 4500k, led4power quad mcpcb & ld4-b4 driver, orange/red tail light, and pflexpro lens.
ZozzV6
ZozzV6's picture
I bought a Convoy S2 XP-L HI SMO version with 8×7135 driver and a Convoy S8 XM-L2 T5 5B with 6×7135 driver and mixed them.
I wanted an XP-L HI SMO reflector S8 so the internals exchanged in both. The S8 got one more 7135 because it has heat fins. And added a 3 led green lighted tailcap and flashed Biscotti in it. I really like this intense green color. They look in real life as on the pics.
Tomorrow I finish the S2. It will be the property of a young boy relative of my friend so I remove some 7135s and leave 4 on the driver. The firmware remains the old 3/5 and I will add light blue lighted tailcap like in my old S2+ grey:
He will be very proud of it among his friends I think Big Smile
djozz
djozz's picture
Really nice mods, both vinte77 & ZozzV6 ! Smile
Sledgestone
Last seen: 11 months 2 weeks ago
Looks awesome ZozzV6!
How did you make the lighted tailcaps?
ZozzV6
ZozzV6's picture
Thank you!
ZozzV6 wrote:
PD68 design REV5 lighted tailcap board. You can read more about it here
Sledgestone
Thanks!
Are they expensive to make?
ZozzV6
ZozzV6's picture
You can buy 3 ring boards from Oshpark fro a little more than 2$ and you can buy the leds and resistors for cents on ebay.
ToyKeeper
ToyKeeper's picture
LOL, accidentally fixed your joke for you. Silly
ZozzV6
ZozzV6's picture
Today I finished the S2-S8 internals swap and added light blue lighted tailcap to the S2.
I removed 2 7135s of the 6 because 4 is enough for a 5 year old kid. The tailcap contains a big switch PD68 board and white leds. The rubber boot is a light blue from Simon’s aliexpress store.
Sirius9
Sirius9's picture
Last seen: 2 hours 14 min ago
Can you show modification to the driver for blue taillight to work!
ZozzV6
ZozzV6's picture
Sure!
It has 10K resistors for each pair of led on the switch ring board and the driver has a 560 Ohm bleeder resistor soldered this way between the spring and the side ground ring of driver extended with a very tiny wire what you ant see in the soldering.
I know I ripped off the Q6 pad when removed the 7135 and cleaned with solder wick Facepalm
