What did you mod today?
9170 posts / 0 new
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 7 hours ago
Have you been drinking something guys? LOL Beer
Lightbringer
Lightbringer's picture
Last seen: 36 min 6 sec ago
Yeah, only light beer, haha. LOL
PH_Oton
PH_Oton's picture
Locally produced “pale” ale Party
DB Custom
DB Custom's picture
Last seen: 2 days 16 hours ago
I’ll shine a light on my beautiful bottle of Imperia Vodka any day, coupled with Kahlua it’s the perfect Black Russian. Wink
beam0
beam0's picture
Last seen: 1 month 4 days ago
Vodka for Dog People Star Texas Star
SpAwN
SpAwN's picture
Did a lighted Convoy black button mod today, some how I missed this topic, so here it goes, more information here:
http://budgetlightforum.com/comment/1277893#comment-1277893
gchart
gchart's picture
Last seen: 26 min ago
!https://i.imgur.com/BdJr9dI.jpg!
That’s pretty sweet. I imagine it would look amazing if someone could make (3d print?) the center piece of the switch out of a clear material.
I love lit tailswitches and the metal switches, but have never been satisfied with just using the clear gasket on the metal switches. It just doesn’t let enough light through.
Yokiamy
Yokiamy's picture
Last seen: 51 min 14 sec ago
Not really modding, but did some polishing
g_damian
g_damian's picture
Last seen: 1 hour 23 sec ago
What have you used to achieve this effect?
Yokiamy
Yokiamy's picture
I have used an old cotton T-shirt together with Brasso
The finish of this flashlight is not 100% smooth, as you can see on the image
It came that way actually, but it is not very well visible on the first picture with the patina on it.
CRX
CRX's picture
Last seen: 2 hours 19 min ago
DQG Spy SS Nichia 219B SW45K 9080 & GITD.
Convoy S6 XM-L2 3C & Lighted switch.
MBI HF-R Copper Nichia 219B repair.
FourSevens Mini Turbo Mk II XP-L HI 5A3
giorgoskok
giorgoskok's picture
That MBI HF-R Copper is sweet , i haven’t seen one before .
CRX
CRX's picture
Yeah quite rare, isn’t mine unfortunately, just needed fixed.
CRX
CRX's picture
Xiaomi 10000mAh Powerbank II hack.
Built in short micro usb lead and 3W warm white cob LED with reverse clicky switch, acrylic window.
I usually do the lead mod with my powerbanks but noticed there was maybe just enough space for the cob and a switch, so why not Wink
MtnDon
MtnDon's picture
Last seen: 52 min 53 sec ago
Thumbs Up
DB Custom
DB Custom's picture
The MBI HF was among the first custom direct drive lights, these from Japan and running on custom made high discharge Li-ion cells. I was very into the MBI products when The-Guy-With-No-Name was first getting started, have several HF’s, a Torpedo and an aspheric head for a Ti HF. They’re very compact and tweak all the output possible from a small cell.
As the story goes, the inventor worked for a large Japanese company that dis-allowed the employees to have a public face, hence, the-guy-with-no-name. Wink His packaging is incredible, especially with the Torpedo, really way over the top…
Firelight2
Firelight2's picture
Last seen: 42 min 14 sec ago
Stuck a Quad-5D XPL HI into my grey D4 last night.
It’s bright, but something doesn’t seem quite right. The 5D emitters that came with my cyan D4 and Titanium D4 are both considerably brighter on turbo mode and heat up considerably faster. I suspect my grey is outputting about 1000 lumens less on a fresh VTC5A. Not sure what’s causing the loss of output, but I don’t think it’s the emitters as I had the same issue with a previous set of XPL HI emitters in my grey.
steel_1024
steel_1024's picture
Last seen: 1 week 13 hours ago
ArmyTek Wizard Pro XM-L2
Nichia E21A 6500K R9080 & 5000K R9080
Next mod on the right……
Sorry for my poor english.
Mike C
Mike C's picture
That’s a sweet mod. Good job!
Pöbel
Pöbel's picture
could be just the VF. As soon as bat Voltage under load falls below VF you will lose output.
Lexel
Lexel's picture
Last seen: 3 days 8 hours ago
Hi,
First I tried it on my regular 6x Tail boards with conventional 6 Balance resistors and a 1kOhm Bleeder
Main Problem was that with low battery voltage the higher voltage LEds (Blue, White, pink, ice blue) get dimmer tan the low voltage ones (red, yellow, green)
I came up to enhance this idea with a voltage regulator, but had to do some steps to make it work
first get the voltage and resistor value for each LED at the same brightness
Then I made some calculation to get fixed current draw versions
It is also possible to use this with side switch lights like Convoy L6, as I can get the parasitic drain for the 18kOhm bleeder down to 0.4mA when the tail board has 0.15mA for the LEDs
Now the first 4 Prototypes
I did quite some measurements and tests to even out the brighteness of them
Firt L6/L2 prototypes are build and successfully tested on my bench, modding the lights will follow
One tme i skipped the very current hungry Emerald green for a warm white
The tail board itself uses a voltage regulator so the brightness is constant down to 3V cell voltage and can be fitted with 1S or 2S voltage regulator
The 2S Voltage regulator has a 0.1mA higher drain
I haver also ordered fitting 3×3mm trimmers so that the brightness of the board can be adjusted for 2V and 2.5V LEds in 2 groups
On the other hand I can also build em with a current draw from 0.15-1mA with the balance resistors without trimmers
The rainbow LED boards have one drawback which are the inefficient Emerald green and yellow LEDs,
so their brightness is lower than green or white LEDs at the same current
led4power
led4power's picture
Last seen: 5 hours 18 min ago
Convoy M1 with Luxeon MZ 3V 5700K 90CRI led on mosDTP powered by 12Amp LD-B4:
Ceiling lumen show around 2200lm LED lumens which matches Koef3 test. Tint is very unusual because of combination of high CRI and hight CCT. Beam uniformity is best I've seen, just pure white light without color deviations. It looks like there is small donut hole in center of beam, but it's not very noticeable,in any case much less annoying than CREE XHP50.2 purple spot and greeny/yellow corona.
Test at 100mA:
djozz
djozz's picture
Last seen: 14 min 46 sec ago
That looks really good. So you have to fiddle a bit with the center piece to make it fit, then this led will work very well in any flashlight with a decent OP-reflector. Smile
Are you planning to sell the led as well? (MZ90CRI 5700K)
led4power
led4power's picture
Gasket is stock rotated XM-L, it works good enough, maybe focus point is not perfect, but actual amount of throw is impressive for Convoy M1 with op reflector, reason for that is lumen output and domeless design of course.
I was trying to get T bin of LMZ7-QW50 ,lumen output should be 30% higher, but I'm not sure if it's available anymore.
alberto7
Last seen: 1 month 1 week ago
Very nice build led4power!
There is any reason to use washers for the screws?
djozz
djozz's picture
Btw, your pic reminds me of builds way way back:
_____________2018________________________________2009_________
led4power
led4power's picture
That convoy host has unusually large diameter of MCPCB space,23-34mm, washers help to center MCPCB.
CRX
CRX's picture
Another couple of DQG's today.
DQG Hobi ti Nichia 219C, magnetic forward clicky tail switch. Can work by tail switch or twisty, starts on low or high mode.
DQG Hobi ti SST-40, QTC/ direct drive. From 0-200lm variable then 1300lm DD.
djozz
djozz's picture
Immaculate and beautiful work again CRX, not completely sure what happened in every picture but those are some nice flashlights!
My mod today is not that lot of work but it was a special led in a special light.
I had this Olight M10 Maverick (EDC-size with 16340 battery) in my to-mod box for a year now, from a GB clearance sale, and I was looking for a host to check out one of the Nichia E21A 6500K R9080 leds that I bought from Clemence. The about 1A constant that this light is driven at on max, should be great for this led on my non-DTP 119-board. The tricky part was the reflowing, it took a while to get the led centered and there is a bit of flux-residu on the side of the phosfor, but on the bright side the board fitted snugly in the flashlight so that centering did not depend on the center piece. I still used a XP-centerpiece (not doing much centering because the hole is too large), that I sanded really thin, to seat the reflecor at the correct focus and insulate it from the solder pads.
Not perfectly centered.
But the beam looks really good: if you look for it a slight bit of brown in the center of the hotspot, not too much tint shift over the beam and in this host this led is quite throwy even.
The output is pretty good: a steady 265 lumen (the stock XM-L2 gives 350lm according to the manual).
The trees are at 25 meter. Don’t mind the tint in this picture, it is much nicer than it seems here.
So the mod was very succesful, and I hope that the dirty phosfor layer holds up over time.
But what about the goal of this mod, what does 6500K R9080 look like?: in short, amazingly good! On a white wall you see nothing special: a well balanced cold white tint, a well-chosen Cree led could look like that. But once you start illuminating things this is completely different: great colour contrast, red is very red and blue is very blue etc., and everything shows the correct colour including natural stuff like food, wood and skin. I checked with a Convoy S9 with 6500K XM-L2, the E21A sw65 R9080 blows it completely away in light quality. If you like cold white tints (I don’t, really Silly ) and care about accurate colours, these leds are little gems!
CRX
CRX's picture
Nice, so what’s the max these fella’s are happy at?
