What did you mod today?
9496 posts / 0 new
luminarium iaculator
luminarium iaculator's picture
Last seen: 15 min 25 sec ago
djozz wrote:
Yes, nice experimenting! The hotspot actually looks really decent through the fresnel lens!
I agree Thumbs Up
Where is Enderman? You see Enderman that was I talking to you few days ago…
Bravo Wieselflinkpro… Very good build.
I know Enderman would say that fresnel lens are no go but I really like it Thumbs Up
MascaratumB
MascaratumB's picture
Last seen: 2 hours 30 min ago
Turned the Lumintop Tool AA into a UV flashlight.
I used a SK68 clone driver (1 mode, AA/14500), a Nichia UV 365nm from Convoy S2+, and a UV filter from the S2+ as well.
To make it shorter, I am using it with the magnetic tail (making it a 1 mode twisty), not the clicky tail!
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Enderman
Enderman's picture
Last seen: 1 day 13 hours ago
luminarium iaculator wrote:
I agree Thumbs Up
I already posted above you… Silly
Seems like he got an aspheric fresnel lens, which are kinda rare, as you can tell from the sharp die projection in the spot.
It’s still very low performance compared to what a normal aspheric glass lens would do, closer to 3Mcd.
Of course it has it’s advantages like being cheaper and lighter.
djozz
djozz's picture
Last seen: 1 hour 43 min ago
Nice UV Tool MascaratumB! I take it that you had to sand the filter quite a bit smaller?
I tried the new Osram KW CSLNM1.TG led in a BLF D80. I made a 12×7135 biscotti driver by adding 4 chips. In the end I measured only 3.9A so 1 chips is probably not cooperating, but 3.9A is pretty nice for this led anyway.
The output is 710 djozz-lumen which is close enough to max, and I think I did a good job focussing it (I combined two centering rings, one inside the other, both sanded down on the underside until the rims were paper-thin), see the beam at 5m distance, but still I got “only” 140 kcd throw on max, while I hoped for 170 kcd.
It has become a nice little light though, I think this led fits very well in the D80..
MascaratumB
Thanks djozz!! Smile
Yes, I had to use a “dremmel”-like tool (Parkside from Lidl Silly ) and had to grind it (with a disc) for a while!
Method: I used the original Tool AA lens to draw and cut a DC-Fix circle and “glued” it on one side of the filter. After that, I put the disc in perpendicular position towards the lens and started grinding until some glass started to jump. From then on, I’ve passed in circles on the edges of the lens until it fit on the flashlight! The DC-Fix circle not only helped to make the “tour” around the lens, but also prevented some glass breaking in an already fragile part!
And it was it Wink I’m not very good at these things, but it works well, and most of all, it is small Big Smile
djozz wrote:
And that’s what I’d call a tight spot!! Nice Cool
-X3-
-X3-'s picture
Last seen: 4 hours 57 min ago
Put a Black Flat in my D1.
I don’t how much we can trust the numbers but I get about 100kCd out of it. D1S is about 350 with the same LED and M3XS about 400.
I need to re-focus the D1 farther with a centering ring though
EDIT : crap pic of the M3XS beam, nice and tight :
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Well at 5.8A draw you can expect 15-20% more but we have to think on runtime and used host… I think performance is superb for such a small reflector light… Back in 2007. reflectors with 20kcd were considered as superthrowers…
The_Driver
The_Driver's picture
Last seen: 1 day 21 hours ago
If you let the light become warm to the touch, the Osram LED will overheat at over 5A. 5.8A only works with perfect cooling.
Nope… My test subject(osram white ) does not overheats even after 3 full minutes on Samsung 30Q (more than 7A draw)… Performance drops for more than 20% but it does not dies and after that it act normal at 5.5 A.
So it should be fine for short run times on turbo mode at 5.8 A. Sure without control or by accident it could cook itself. But that is case with any overdriven led? I don’t want to leave even xpg2s42b on turbo for more than 5 minutes… And now imagine to toggle lets say middle mode in same light at only 3.5A and you actually see that performance just slightly dropped Smile So that new Little Osram guy is like Viagra… Very constant in performance Smile
BTW. I know that there are certain emitters that can pull around 13A on single cell without dying and have similar lux performance as new Osram white with more lumens. So they will not die that easily… Even with passive cooling. So future seems to be bright for led technology these days. They seem to be more robust than ever with lover vf than ever.
Enderman
Enderman's picture
You might be able to get more performance by running a lower current somewhere between 3-5 amps since it will be producing less heat and running at higher efficiency.
I’ve ran mine up to 6A with lots of cooling.
I’ve also killed one at 6-6.5A probably because I didn’t let it warm up long enough at first turn on.
contactcr
Last seen: 1 hour 29 min ago
What driver or resistance changes did you make for the D1S?
-X3-
-X3-'s picture
None, but I only use it for short burst on Turbo… might not be ideal since it’s a FET driver Sad
Maybe I should use a lower amp cell
Cereal_killer
Cereal_killer's picture
Last seen: 9 months 3 weeks ago
Not a physical mod but still tons of work yesterday.
My wife came to me a few weeks ago needing a light for a very specific use;
Wide even beam with no hot spot
Red light
Single mode
Small host
USB rechargeable
Like most people I try to provide everything my significant other needs but there’s some things we’re just not able to provide like unlimited money or things not in my field of expertise so when a need I can perfectly fulfill comes along you just gotta love that feeling. Yea babe, I got this!
So I ordered up a utorch s1 mini, got it stripped down and got the driver board out then set to work making up a driver for it. This is the end result ordered from oshpark.
Interesting bit- the heart BATT+ pad is a library part, after I drew it with the line tool then cloned it and changed that to bStop for the mask then needed to reposition it a fraction of a mm and all that going to crap cause it just wouldn’t move right as a group I wasn’t doing it on the board again so I just drew up a 5mm heart shaped library pad and now I can drag and drop is as needed lol.
Final specs:
Osram Olson ssl-80 in the deeper of the red nm choices
7135×2 with modified Tom E “E-switch 13” FW. Single mode medium with the hidden strobe replaced with hidden max (press hold).
Sub 16mm custom driver design one off for my wife
Uses a gigantic 3×5mm switch that I have a million of.
No thermals on the 7135 tabs with solid Cu pours under them for better heat management cause of the low vF of the red LED.
Cereal_killer
Update: I lost the switch bezel so I made a new one, being that it’s our 6th year married I’ve been incorporating copper into every gift I could and this was no excepting. I feel like this one hit the bullseye (you’ll get the pun in a sec).
Btw this was done with a hand drill, a pair of pliers, a hacksaw and some small files.
380 round, lead drilled out, a tiny sliver cut off.
Ready to fire
The_Driver
I’m talking about much longer runtimes and doing that often.
Not every other overdriven LED will have problems. It depends on how far you overdrive it and how good the heatsinking is.
CRX
CRX's picture
Last seen: 1 month 1 week ago
Nice touch Smile Thumbs Up
contactcr
CRX version:
Replace the battery wrap with a printed note. Install acrylic window on the side with an external way to spin the battery.
MRsDNF
MRsDNF's picture
Last seen: 23 hours 2 min ago
You continue to amaze ck. Love your work. Thumbs Up
ZozzV6
ZozzV6's picture
Last seen: 3 weeks 7 hours ago
Yesterday the new Osram CSLNM1.TG leds arrived from led4power. Putted in one to my modded Convoy S8 and one into my GT mini. Some pics and beamshots:
Convoy S8, S2+ SMO reflector, AR lens, 3,15A. 9×7135. It makes 573 lumens and 30800 cd.
It is slightly smaller than XP leds
GT mini with Emisar D1S reflector. You can see the beam thinner as going away from light so it need to raise the reflector a bit. Making 219000 cd with unfocused reflector and GA cell to not overdrive the led.
Beautiful… You are not using solder paste for re flowing?
When you mentioned smaller than XP led yes it is smaller than XP-G2 de domed but about same or even bit larger than dedomed XP-E2.
ZozzV6
ZozzV6's picture
I bought these soldered to MCPCB but I using paste with bare leds. With size I mean the complete led size smaller than XP centering ring cutout. Not the die. Wink
zeroflow
Got my Astrolux S43 today and of course, it needs to have Anduril!
The bezel can be removed by hand, the MCPCB is held down by 2 screws and after desoldering the MCPCB can be removed.
While I am no subscriber to the motto "the bigger the gob, the better the job" I think we all can agree that this amount may be not really enough.
Removing the button was easy with a pair of tweezers
And now, the whole stack of PCBs can be pushed out.
It is worth noting, that you need to push straight because otherwise the PCB will wedge itself in the threads of the head.
After that, flashing is pretty hard as you cannot use a clip or pogo pins.
But you can use a modified clip to get inbetween the sandwiched PCBs.
My verdict after having the light apart:
  • Not mod friendly
  • Hard do disassemble / reassemble as the PCB likes to get stuck
  • Flimsy switch wires which like to simply snap off
  • Could use more thermal paste
  • (Anduril currently needs workaround so this light can use the 1x7135 channel)
Cereal_killer
Cree XD16, on VirEnce N119 mcpcb on a Kronos X5.
This emitter was my test led and got slightly burned on the edges of the phosphorus during some max power tests, that’s what the odd color is in the reflection of the die. Even as such it still performs well as well as expected (i.e. nothing to write home about but it’s still cool as hell)
XP-L HI (stock) 29,690kcd
damaged XD16 5700cri 25,700kcd.
I have 2 more 5000k 70cri emitters to play with too.
CRX
CRX's picture
contactcr
Another awesome mod CRX
giorgoskok
giorgoskok's picture
Last seen: 1 week 5 days ago
Love the triples on small body lights Smile Awesome mod CRX !
Btw , is there any place to get these Novatac lights at a decent price ? Thanks !
CRX
CRX's picture
Thanks Thumbs Up
jon_slider is the NovaTac man Wink
g_damian
g_damian's picture
Last seen: 23 min 11 sec ago
I installed OSRAM KW CSLNM1.TG in SP32A V2.0:
Throw is comparable with C8. Here is the picture with Convoy C8 with CREE XP-L HI V2 5D at 2.7A, SP32A with OSRAM KW CSLNM1.TG at 3A and stock Acebeam EC35 at 3.3A. Around 2.5 metres to a wall:
More details in this post.
Cereal_killer
Reflowed some more XD16’s onto VR16S1 boards. Man those 1616 LED’s are tiny!!!
CRX
CRX's picture
UltraFire UF-10 OSRAM KW CSLNM1.TG - DD - 16500 - Rv Clicky Lighted Sw - 640/ 250lm.UltraFire UF-10 OSRAM KW CSLNM1.TG - DD - 16500 - Rv Clicky Lighted Sw - 640lm.OSRAM KW CSLNM1.TG 6N 15:
Max – 640lm/ 250lm - 4.5A
60000cd/ Throw 490m
