What did you mod today?
9499 posts / 0 new
Rdubya18
Last seen: 2 weeks 17 hours ago
Turned my S2+ copper into a triple Love
LouieAtienza
YuvalS wrote:
LouieAtienza wrote:
Cool, would like to see the finished light as I do have a friend that’s a avid caver…
I decided to use the original flood led and only changed the malfunctioning driver and spot led
Looks like a heavy duty headlamp… thanks!
Wieselflinkpro
Wieselflinkpro's picture
Modded a Astrolux S41:
- 7x XM-L2 on https://oshpark.com/shared_projects/hZGiHT7T
- AWG18 Driver-Cable
- changed Switch-Board against copper board with brass two pills
- bridged driver spring with AWG18
Got 6300 Lumen with VTC6 and without bezel and glass. With bezel and glass only 5100 Lumen.
It is not verry precise as twisty flashlight.
Now the head is in nitro-thinner for dedoming.
Didn checked amps.
Firelight2
Firelight2's picture
Last seen: 13 min 36 sec ago
Last night I took a Lexel D4 aux board and manually replaced all 15 LEDs with different colored ones.
Those 0603 LEDs are absolutely tiny! Evil Even with the fan on the hot air gun of my reflow station set to minimum it was still enough thrust to blow those miniscule LEDs right off the board from 6 inches away when they weren’t soldered on. After some trial and error, I finally got technique going where I held the LED in position with tweezers in my right hand while blowing hot air on it with the hot air gun in my left hand.
Took me a couple hours to replace all 15 LEDs. Cool
DB Custom
DB Custom's picture
Last seen: 4 weeks 22 hours ago
Wow Firelight, nice sticktoitiveness! Smile
I played around with a couple of lights today, one for a buddy of mine and one for me. The friends light is a TK61, I put a White Flat on a 32mm MaxToch MCPCB in it. I had done a power boost to it some time back for him with a de-domed XM-L2 and he told me it was doing 575Kcd when he sent it to me. Today it’s making 830Kcd at 5M indoors… too cold and yucky out for me to be doing a longer distance test. Big Smile It makes 980 lumens using 2 30Q’s in the 4 cell carrier. I think he’s going to be pleased. Wink
The other, my light, is a Convoy C8+, a prototype in desert sand with a black coated metal button in the tail cap. Simon decided to make the production C8+‘s with rubber boots so this one is a bit different. Now it’s even more different, it has a boost driver and XHP-35 D4 3A HI making 2139 lumens on a 30Q. Big Smile I had to re-cut the driver shelf to accept a 20mm driver, instead of making a threaded retaining ring I made a slightly oversized brass press fit spacer to allow the battery tube to mate to it and press the driver in. Works nice, should serve to heat sink the driver via the tube. Love it when a plan comes together! I don’t have a lot of regulated lights so this one will be unique in that regard as far as my working collection goes. This one’s going to be getting a lot of use now for sure!
KawiBoy1428
KawiBoy1428's picture
Last seen: 9 min 32 sec ago
Maybe try 7x XHP50.2 3volt emitters next…. Shocked Might need a bigger battery..like a 30T Big Smile
KB1428 “Live Life WOT
Texas_Ace
Texas_Ace's picture
Last seen: 12 hours 57 min ago
Very interesting PCB, I wounder how well that works?
Each LED is only being driven to about spec with a non-dtp mcpcb right now but I wounder how well it would work on a single LED setup.
djozz
djozz's picture
Last seen: 3 hours 19 min ago
LOL, I remember that ledboard, still have 3 but never used them, I believe it was a scaru project, at least 4 years ago. Pictures of the build would be welcome of course. Smile
DB Custom
DB Custom's picture
Haven’t seen David around for a WHILE!
Wieselflinkpro
Oh no, too expensive for a funny hot rod.
I have some SST40’s laying around and 7 good old XM-L
I used the 2oz chopper foil on OSH Park and the thinner board to improve heat dissipation.
And it is soldered directly to copper, of cause.
Yes I post them possibly tomorrow.
Now the head is in nitro-thinner.
The domes of the LED locked not well. They have had contact to my rasp as I wanted to make the aluminium pcb smaller to fit it to my copper heatsink in the skyray king.
And now they got hot from the bunsen burner.
The LEDs are from this flashlight: https://www.taschenlampen-forum.de/threads/skyray-king-srk-mit-3-x-nichi... before I have changed the LEDs to Nichia 144.
Tom E
Tom E's picture
Last seen: 36 min 36 sec ago
Finished a ZY-T11 clone quad mod:
  • 4 LH351D 4000K 90+ CRI's on a MtnE quad, 10621 optic, UCL glass lens, 18 AWG wires extended for re-programming
  • CK driver designed for the ZY-T11 clones, RED aux LED w/10K resistor via a light pipe in the pill, Blue BeCu driver spring w/bypass
  • S2(+) alum spacer sanded down to fit, 1978 copper penny under the shelf, brass screws to secire down, MX4 between layers, MX4 for most of the MCPCB mount but Arctic Alumina thermal epoxy spot used to secure it in place and prevent sliding/movement
Tape used to center the spacer - centering had to be bout perfect:
What we do for lumens...
Pre-assembly parts:
CK's OSHPark driver, switch is surface mounted - extra solder in front and 2 part epoxy (clear) behind the switch for extra support:
Abe in the mounted position - 2nd picture shows the end of the light pipe in the upper right:
All done:
On a 25S at 4.19V, ~17.5 amps, 3929 at start, 3300 at 30 secs, 9.5 kcd (lumens in manufacturer lumens), great tint/beam
Lightbringer
Lightbringer's picture
Last seen: 7 min 54 sec ago
Tom E wrote:
Poor Lincoln… like he needs another hole in his head…
Looks nice, though, 3900lemons out the pipe… not bad. Big Smile
Tom E
Tom E's picture
Thanx! $11 light, throw $40 in parts at it, hours of sanding/drilling/tap'n/soldering/wiring and you got something almost as nice as a FW3A or D4. These clones are a bit over sized for today, and the anodizing and threading isn't so great, but the clones are actually better quality than the original - clones have true alum reflectors while the original had plastic. For this one, the reflector had a hazy finish, pretty bad, so this mod worked out well for it. I do like the feel of the switch though on these - great for ramping smile
contactcr
Last seen: 45 min 16 sec ago
Tom E wrote:
$11 light, throw $40 in parts at it, hours of sanding/drilling/tap’n/soldering/wiring and you got something almost as nice as a FW3A or D4.
Quoted for truth. What a hobby we have..
Lightbringer
Tom E wrote:
Thanx! $11 light, throw $40 in parts at it, hours of sanding/drilling/tap’n/soldering/wiring and you got something almost as nice as a FW3A or D4. These clones are a bit over sized for today, and the anodizing and threading isn’t so great, but the clones are actually better quality than the original – clones have true alum reflectors while the original had plastic. For this one, the reflector had a hazy finish, pretty bad, so this mod worked out well for it.
Yeah, I never got around to making an F13 into a triple. That’s a nice beefy host, but works quite well with the stock… “host”? Replace the driver and emitter and it kicks arse. Or could. I don’t push mine terribly hard.
Dunno if you can get F13s as hosts-only, so you just buy a complete light and gut it. LOL
Agro
Agro's picture
Last seen: 4 hours 17 min ago
!{width:40%}https://www.taschenlampen-forum.de/media/skyray-king-7x-xm-l2-mit-kupfer...!
Great mod. Smile
I wonder how would it work with XHP50.2…
Wieselflinkpro
As you see in the pictures, the LEDs are not jet ready dedomed.
Some Pictures
kikkoman
kikkoman's picture
Turned my franken-Astrolux E02 into a triple. (My first triple! How many years am I behind?) The e-switch was bouncy and the old Anduril had a few kinks that needed fixing so it was time for an overhaul.
The driver is basically the same as before, though this time I made use of the FET footprint of the L4P MCPCB. 3 channels, 1+2 [7135] + 7136 for “Turbo” (a moderate 3 amps).
3× 5000k LH351C (edit: C, not D!) 80CRI in a Carclo 10507. The MCPCB plus the optics’ legs had to be cut down to 18mm for everything to fit. A 10g copper slug sits in the head.
This time I got the “good” 7135s (the Nanjing ones) and the lowest flicker-free level in Anduril is 1. (I also added 10k pull-downs on all 3 channels, that may have helped too.)
Current on “moon” is 1.1mA, quiescent current is 0.25µA (down from 2.4mA / 15µA). (Thanks Toykeeper for all the good work! Beer )
Yes the 7136 is a bit iffy. It doesn’t like PWM at all due to its soft-start (I only use it for turbo anyways), specs from different mfr’s are all over the place etc etc. I wouldn’t recommend it, it gives you headaches.
There’s one red AUX LED for map reading etc. under the optics but something went horribly wrong and I sure as hell won’t desolder every wire again just to get into the driver compartment… maybe next time.
Flashing… tweaking…flashing…
Can’t complain about the beam. The only visible artifact is the petals in the periphery but otherwise it’s very clean. This is @1m from the wall.
If I wanted this to be ultra-compact I’d go back to the 18350 tube but I feel the reduction in capacity isn’t worth it. Plus it just doesn’t feel right in the hand, the 18650 does (and it’s only 105mm long anyways.)
KawiBoy1428
^ Damn…… Nice Job! Thumbs Up
djozz
djozz's picture
Very nice, never bought an E01 because of the UI, but I sure like the size and looks!
tekwyzrd
tekwyzrd's picture
Last seen: 5 days 4 hours ago
Currently working on giving an unreliable crelant v4a a new life. 2s2p 14500, 17mm 2s ta narsil driver from lexel, and 5000k Q0 mt-g2 from intl-outdoor when they were bargain priced. Something to work on while waiting for new reflectors from fasttech and replacement emitter for the L6 from banggood. Will post photos in a build thread in the near future.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
kikkoman
kikkoman's picture
A brain fart caused me to think I’d soldered to GND when I hadn’t. So the AUX LED is working now.
This is with a cheap chinese red one, probably not too efficient, pulls about 1.2mA total (1k5 resistor). Due to its size it sits somewhat behind the lens (and quite a bit of light is lost internally). I’ll fix this when I find a better LED.
EDIT: found a suitable 0603 LED, it now sits on a little stem right in the middle, directly under the lens. Current draw on “low” is ~55µA, on “high” it’s ~1.2mA.
A 2-die (series) red one would be ideal for this but I don’t think there are any. I think even on low it’s useful with dark-adapted vision, I’ll have to wait until tonight to find out. Pics below.
Low:
High:
I got away with a single-sided driver btw.
Yup once one gets rid of its original innards it’s a nice and very EDC-able little light. It takes all sorts of reflectors and optics due to the screw-on bezel, a few mm +/- don’t matter, very flexible. This one will live a long life I’m pretty sure.
kikkoman
kikkoman's picture
OK, I can confirm. 56 microamps is enough for reading a newspaper in total darkness.
(Although every grandma will tell you “don’t do that, you’ll go blind”)
Lightbringer
Ummmm, no. Not going there…
Marc E
Last seen: 2 days 13 hours ago
Tom E wrote:
…1978 copper penny under the shelf…
Ohhhhhhhh, suddenly the penny mod i’ve seen mentioned makes sense! It’s not a UK penny… Facepalm
Marc E
Yeah, i know, a newspaper in this day and age…
shirnask
shirnask's picture
Last seen: 1 hour 6 min ago
Yeah, that’s not where he is not going
Pavlo
Last seen: 3 hours 49 min ago
Finally getting back into modding.
First two mods:
1) Thrunite TH20 Headlamp, change LED to 219C 3500K 90 CRI.
Loving this headlamp now. So much more pleasant and calming than stock LED with wonderful color rendering.
2) Eagletac M30LC2-C, changed XP-G2 70 CRI Leds to Luminus SST-20 3500K 95 CRI Leds.
There is a noticeable drop in output with the new LEDs. The light out throws my Zebralight SC600w MK III Hi by a small but still noticeable amount. The center intensity is higher than the Zebralight, but the spot is much narrower too. Its my first high CRI “thrower” and I am very impressed by the color rendering of these LEDs. Its refreshing to see colors pop from a distance. It makes reds/browns pop much more than the 3500K Nichia 219C above. The best part about this light is that it maintains the highest level without overheating at all, and its fully regulated. My guess is that it now outputs about 750 lumens, but this is purely a guess based on my perception of other lights. The spill is quite dim compared to the main spot so its very good at not blowing out your night vision so you can focus on the center spot in the distance. I am curious to see how an XP-L Hi 80 CRI 4000K Led would do in this light, but sourcing these seems expensive.
gchart
gchart's picture
Last seen: 3 hours 35 min ago
Modified TomE and TK’s RampingIOS to run on the new attiny412 (and in single-channel mode). Loaded it up on my D25 headlamp. The UI is so much better now (vs the D25’s original UI)! Full details in this post.
DB Custom
DB Custom's picture
You say that (“the UI is so much better now!”) as if there were something wrong with ToyKeepers UI to begin with.
Edit: Ah, I am going to assume you mean the light is better with Anduril Ramping IOS than with the OEM UI… sometimes I’m so dense. Facepalm
