What did you mod today?
9027 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 15 min 44 sec ago
djozz wrote:
^ a blue thrower, very useful too.
19A? More like a gamma thrower… Shocked
ToyKeeper
ToyKeeper's picture
Last seen: 1 day 7 hours ago
Agro wrote:
ToyKeeper wrote:
I managed to get a picture of my bare XHP50.2 while it was on. This involved shining it through a slide projector lens onto a big sheet of paper, and taking a picture of the projected image.
On your first picture it really looks like the die spacing is very uneven. On the second and third picture that does not seem to be the case. Though the bottom dies don’t seem to line up…and the top ones don’t either.
It’s less uneven than it looks in the first pic. There’s still a bit of phosphor between the top two dies, and between the left two… so it lights up and looks white in the picture, which makes it look like there’s more space between the dies.
djozz wrote:
That is really nice of him. And it must be a nice tint now?
It’s definitely better than other SST-20 lights I’ve tried. It could probably stand to have more of the 3000K + 6500K emitters and fewer 4000K + 5000K though. Farther apart should help pull the Duv down more.
Agro
Agro's picture
Last seen: 7 sec ago
But then: 5000K and 6500K are low CRI. Maybe it would be better with just 3000K and 4000K mix as a base with few 6500K emitters to make it cooler and rosier?
contactcr
Last seen: 22 hours 29 min ago
Plus the low CRI ones have quite a bit more output to offset the high CCT. So i’d guess you need less of them to balance it out
ToyKeeper
ToyKeeper's picture
No. At ~4200K, I find it’s already about as warm as I can deal with. If I made it warmer, it would look even less white. Even at 100 CRI, it would still look worse. Warm incandescent-style lights make my eyes hurt, literally.
I’ll enjoy my medium-CRI neutral white instead, thanks.
Agro
Agro's picture
I did not mean to lower the total CCT. Rather – use 6500K exclusively as the cooling agent rather than the mix of 5000K and 6500K. It should arrive at about the same CCT with fewer low-CRI LEDs.
I view it like: mix 4000K and 6500K only, with a good majority of 4000K. If that’s not rosy enough, replace some 4000K with a mix of 3000K and 6500K.
ToyKeeper
ToyKeeper's picture
Ah, okay. That makes sense. Smile
contactcr
Added a volt meter to my VC2S cause the dial sucks, problem is I think it never stops charging now so I may need to add a momentary switch. Idk anything about electronics so don’t replicate this terrible idea.
Lightbringer
Keep in mind, though, that those meters are powered by the voltage source they’re sensing. That means that “charging current” will quite possibly never go low enough for the charging-IC to sense, “Okay, time to stop…”.
The charger will or at least should hold it in CV mode at ~4.20V, and not overcharge, but it just won’t ever show it as being topped off.
contactcr
Yeah that’s the issue I’m seeing. Basically trickle charging hence I will probably add a switch for it
Lightbringer
Ideally, it should balance out when its leftover “trickle charge” equals the current-draw of the meter/display.
Eleziel
I put a 3v XHP50.2 in my convoy l2 (single cell) with the intention to make it more of a single cell Q8, didn’t work. still throws like a beast considering what it is. but i do like the slightly larger spot.
I’m not sure if i’m just getting used to high lumens (my edc has a ~2200 turbo) but it doesn’t seem that bright. maybe it’s the X6 driver? still waiting on a LD-A4
TheOnlyDocc
TheOnlyDocc's picture
Because i have to much time but can not make much physical stuff i am using my head and plan a new case for my old Soundstrem SS10R chassis.
They were in my car many many years ago. Because space was tight they are in a not so optimal case now.
The plan will be to build two chases like this
Each woofer will get a Mivoc AM 80 as amplifier
First data from the programm
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
ToyKeeper
ToyKeeper's picture
contactcr wrote:
problem is I think it never stops charging …
I found a cell which had been discharged to 1.8V. Out of curiosity, I tried charging it. Things went pretty well until it was nearly full, and then it refused to go up above ~4.12V or so. It just kept charging and charging.
So… that cell is basically dead. It may still be usable for some lightweight purposes, but I drew sad Sad faces all over it to make sure I don’t forget which cell it is.
BlueSwordM
BlueSwordM's picture
Last seen: 17 hours 22 min ago
How did you charge it?
Basically, below 2V, you want to charge the cell as slowly as possible.
contactcr
I found that even with the volt meter it does stop charging. I think the lower resistance batteries terminate quicker and maybe just the smaller protected ones take forever
Scallywag
Scallywag's picture
Last seen: 1 day 3 hours ago
ToyKeeper wrote:
I found a cell which had been discharged to 1.8V. Out of curiosity, I tried charging it. Things went pretty well until it was nearly full, and then it refused to go up above ~4.12V or so. It just kept charging and charging. So... that cell is basically dead. It may still be usable for some lightweight purposes, but I drew sad Sad faces all over it to make sure I don't forget which cell it is.
Braver than me. I throw them out recycle my cells responsibly without charging at that point.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
DB Custom
DB Custom's picture
Put a 3V XHP-50.2 in my TK61, the driver is cranking amperage safe for an XM-L2 so I need to address power level, not sure how to go about making the TK61 do the amperage this emitter is capable of… as it is it’s only doing some 2100 lumens.
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 min 4 sec ago
Is it this driver…
KB1428 “Live Life WOT
Th558
Th558's picture
Last seen: 44 min 35 sec ago
I’m trying to install an osram white flat in a GT mini but the screw cutouts of the new 20mm pcb don’t line up. Should I just use thermal paste without screws?
Lightbringer
Hm? Whaddya mean “don’t line up”?
Th558
Th558's picture
Well for some reason the screw cutouts on my gtmini stock pcb are spaced equally whereas the ones on L4Ps 20mm 3030 board are closer together so there no way to screw the board in.
Ignore the super bad de-soldering job.
Eleziel
!{width:65%}https://i.imgur.com/qmBjrfH.jpg!
Most of my lights don’t use screws to hold down the pcb.
Centering ring and bezel should be fine.
Lightbringer
Aha, so holes for the wires and holes for the screws don’t all line up… Gotcha.
I only got a micro, so can’t say how the mini’s put together, but if the reflector pushes down hard enough on the pcb, regular thermal goop like AS5 should work fine. The reflector (and presumably centering spacer?) should keep it lined up and centered. It’ll “float” and self-center via the reflector.
I had that issue with C8s before.
Lexel
Lexel's picture
Last seen: 1 min 41 sec ago
still its always risky with the LED holes within the MCPCB diameter
if it rotates as well it will easily cut through the wire insulation, had that often enough in the past
best is to drill fitting holes and thread them
or
use a grinding tool or file to remove material from MCPCB
if you work on MCPCB always make sure if you are finished the bottom is flat!
Henk4U2
Henk4U2's picture
Last seen: 2 hours 43 min ago
or
Because axial fixation is done by bezel/reflector/centering ring, one screw should be enough to prevent the MCPCB from rotating and shearing off the leads. IMHO there will always be one cutout that fits. Just don’t overtighten the screw to keep the MCPCB flat. Easy does it.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
DB Custom
DB Custom's picture
Kawi, I have that but I don’t think it will supply enough power to the 50.2… so… I modded the TK61 entirely.
I wiped the factory driver , installed an FET+1 with ramping and reversing 7 level firmware, then modified the carrier for 4P. With Efest 3500mAh cells it does 4490 lumens on level 7. Smile
This is with my light box diffused and calibrated per Maukka. May be a little low but my meter shows actual lumens now with no multiplier so it’s pretty cool not having to mess with the math. lol
jasontheguitarist
Last seen: 17 hours 18 min ago
I did a simple driver swap on a Thorfire TG06S. I decided I wasn’t crazy about it always starting on high, so I swapped in a Nanjg 101 AK-A1 with guppydrv. It’s 14500 only now but I like the programmable firmware. The only issue is moonlight doesn’t work. It’s a dead setting, all the others work fine though. I don’t know if the driver is defective or if moonlight is just finicky.
contactcr
E07 mod time!
I took my trusty Work Sharp w/ Blade Grinder attachment and beveled the edge and took just a hair off the total diameter from a 90 degree angle then used some wet 2500 sandpaper to finish the bottom
Old emitters removed, board cleaned up. LH351D 3000K 90CRI + LH351D 5000K 90CRI set aside
She works! The long lines on either side of the emitter pad are negative
My what nice legs you have
One more test before we mess with aux board. The LED wires are so hard with solder and cut exactly to length, this requires some finesse tweezer action
Aux connected without much trouble, too bad this color combo isn’t available anymore
All back together
Measurements:
OUT: 6,118 lm at 0s (Molicel P42A 21700)
CCT: 4143K
CRI: 92 Ra 64 R9
djozz
djozz's picture
Last seen: 8 min 21 sec ago
Nice version, contactcr! And you ended up only very slightly above the BBL. At what current was the tint measurement?
And are you happy with the result?
