What did you mod today?
8579 posts / 0 new
contactcr
Last seen: 1 hour 9 min ago
djozz wrote:
Nice work on the D18! My ROT66 has 9 of those leds, you got môah!
So I’m known as the one that always uses too much solder paste? Facepalm
But we love your LED tests <3
contactcr
Reflow money shot: https://imgur.com/Uul0jS6
gchart
gchart's picture
Last seen: 38 min 58 sec ago
Today I replaced the MCU in my Sofirn SC31. It had a PIC (or similar) and now it has an attiny412.
It’s running a custom (from scratch) firmware, tailored for use as a nightlight in my toddler’s room. MCU is sipping power by clocking off the internal ULP (ultra low power) oscillator. Once the battery is inserted, it begins a cycle of 10 hours on, 14 hours off. Single click of the e-switch temporarily overrides on/off. Click and hold for ramping up and down. At 3.00V, the aux LEDs begin to blink for LVP warning.
USB recharging probably still works, but I haven’t fully tested it yet. The aux LEDs aren’t lighting up, but I don’t know if it’s charging or not. The charging circuit is the usual suspect: TP4056. I need to check into this more. Probably need a USB analyzer to know for sure what’s going on.
CRX
CRX's picture
Last seen: 1 hour 19 min ago
Cord wrap on the LAN Mokume Gane.
Inkidu
Modified one of Lexel’s FET switches to be less remote. Fits fairly well in a Convoy L6 tailcap. Might be a better fit in a Convoy M21A. Giving it a second look, I could of used a spacer to raise it up a bit and the spring choice might not be ideal. Slightly limited because of the location of the FET. I also could of done a better job with cable management, but it works. The spacer used was from a remote tail switch with the nubbin cut off. I’m assuming getting a voltage reading when off is normal and not that I screwed something up. A bit of a hack job, but there aren’t a lot of offerings for these kind of switches. Lexel has started a GoFundMe for a high current tail board among other campaigns.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 5 hours 1 min ago
Changed the handlebar on my new bought Kawasaky Versys 650 to a silver ABM 230
I had this from my former Motorbike the Kawasaki KLE500.
Positioning was hard because of the fitting holes for the instruments. And there is not much space to the cassis and the windshield. I have to buy a separate mounting for the mirror, because the left mounting on the coupling is too wide away from the handlingbar and too near to the windshield.
staticx57
Last seen: 10 hours 25 min ago
i42dk wrote:
Inspired by the D18 tint mixing. I wanted to finally give it a go.
Heard both negative and positive opinions about mixing leds.
In my case i changed two of the four 219C 5000K emitters in a D4 with two 219C 4000K.
I know that doesn’t magically make it 4500K. But i was surprised by the result. Way better than expected.
Here’s a comparison:
D4 with 219B 4500K
D4 with 219C 4000K + 5000K
and a D4 with all 5000K
all three @ turbo. all three with a Sony VTC6
Camera: Canon EOS 40D (1/2Sec – f/3.5 – ISO160 – WB 4500K)
It doesn’t have the rosyness of the 219B, but in a side by side comparison it shows how much more lumens the 219C produce.
And the results were amazing (to my eyes). It’s still a little green. But the addition of some 4000K makes the beam way more lovely.
Not as pretty as 219B 4500, but close, and with more output.
Here’s a white wall comparison.
Very nice! If you want to try it again, the further you separate the CCT the rosier the output
jericho0o
Last seen: 7 hours 18 min ago
Accidentally dedomed an LHD351D by ripping off the silicone dome clean while it was hot – should mention I was pretty heavy-handed with the initial reflow (read: left the iron on the original MCPCB a bit longer than I should have) – but it survived and I decided to not waste it.
So I mounted it on my Lumintop Tool AA 2.0 and just put a tailcap bypass – simple stuff – but it keeps me sharp for the bigger boy projects that may come Smile
Much better tint than the original XPL-HD imo –
"And God said, 'Let there be light,' and there was light." - Gen. 1:3
e1000
Last seen: 5 days 13 hours ago
Two copper S2+
So, I've been working on this project for a while now. As soon as I received my first copper S2+, I knew I wanted to do something special with them.
Batch 1 build - I'm technically not done with this build yet, I'm waiting for a new copper pill, but got this one working nonetheless. It's a XHP-70.2 being run by a MTN-BST2 driver. As far as I can tell, there's no donut and the light doesn't get as hot as quickly as I expected it to. I love the way this package looks.
Batch 2 build - I decided to go a different route to get to big outputs on this one. Did a triple build using 3 Nichia 219c's @ 4000k, and a CWF Dragon driver and a copper triple pill by Kiriba-ru.  I decided on amber secondary LED's.
They both are run off of Sony VTC5A's (I feel like the green color is like an inner Hulk) and have the little things done like tail spring bypasses, etc. LOVING them
acab
acab's picture
those are very beautiful lights.
-X3-
-X3-'s picture
Last seen: 14 hours 17 min ago
I opened up the bezel of my short triple S2+ with the lathe at my work :
Went from 600 lumens to 700…
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
TrueRMS
Last seen: 1 month 1 week ago
Today was FW update day on some of my anduril lights so I took a family pic. One more, an EA4 is my glove box light for the summer since it runs AA NiMH’s so it didn’t make the pic.
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 hours 25 min ago
Added glow gaskets to some lights. One of these lights comes standard with a glow gasket.
It doesn’t show real well in the pic but the one on the far left closely colour matches the lighted tail.
TheOnlyDocc
TheOnlyDocc's picture
Yesterday was a good day (today not so much) so i made another stepp to complete my heatplate. Its fully funktional now. But i have to cut a Aluminium plate to cover the inside right and left from the heatplates.
It looks scrappy. But i wanted to invest only a few bucks. So almost everything is repurposed. From the fans, the wooden bier box, the switches, the heatplates (Aluminium cooler from a dead amplifier with removed finns). I had the DC-DC converters here (bought in a lot of 10 in the past). So i only bought the heating elements, Temp controller and the cob leds. The wodden box is repurposed multiple times. I installed the fans when i used it with a old PC powersuply. But now they keep the fumes out of my nose. Hope to get the Aluminium cover made soon and then i will put a few drops of paint on the outside to make it look less scrappy. And i have to get my new powersupply ready. The car batteries voltage is not stable when i pull max ~17A. The battery was not fully loaded when i took the pics so the current readings are a bit lower.
I have 2 Temp zones. The more black one has ~50W controlled by a bimetal switch (120°C) and the main plate ~100W controlled by the tempcontroller with Thermocouple. The fan is controlled by the poti on the front. I removed the original poti from the DC-DC converter and connected the poti in the front. Leds run on ~3V @1,4A. It takes some time to get hot but it gets there and on the mainplate i can hold the temp +-5°C. I made a new wire with Banana plugs out of 12AWG wire (the red one) and i ordered a blue 12AWG to make also a new one for the negative pole. For now i use 2 of my usual testing wires to not run into problems with voltage losses.
And i got the message that Kirill shipped my new pill for the ZY-T08. I like the light and i want to put a 3V XHP-50 in it. The pill has a 20mm driver pocket with retaining ring. I will use the original sripped driver with a custom brass ring as contact plate (also with retaining ring. The threads on the outside are cut on the complete length. To improve the heatpath. Should work nice. Thanks to Kirill for making my drawing a reality.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
CRX
CRX's picture
FW3A Triple XP-L HI 3D - SD - 18650 - 3375lm.
I didn't like the diaphragm popper on the operation on the FW3A so I decided to install a proper tactile momentary switch with a smaller button and a magnetic shrouded enclosure.
Carbon fibre switch enclosure with 15 neodymium magnets, 8mm diameter linear button with 6mm x 1.5mm green tritium vial.
The button can only move in a straight line and accidental activation is not as easy now.
The carbon fibre/ magnets are fixed in place, sit flush with the tailcap edge and strong enough to hold the light horizontally.FW3A Triple XP-L HI 3D - SD - 18650 - 3375lm.
TheOnlyDocc
Jaxman X1 with extension tube + 6V MZ led (LMZ9-RW57), Led4Power LD-B4HV (6A). Driver soldert to two adapter rings to fit the X1 pill. Without spring bypass at the tail i get 5,75A .
FW3A With LH351D 10509 optic on turbo
Jaxman X1+ extension tube, 6V MZ led, orange peel reflector, LD-B4HV (6A) driver, On Low
Jaxman X1+ extension tube, 6V MZ led, orange peel reflector, LD-B4HV (6A) driver, On Mid
Jaxman X1+ extension tube, 6V MZ led, orange peel reflector, LD-B4HV (6A) driver, On High
evil_andy
evil_andy's picture
Last seen: 1 month 1 day ago
Today I re-modded my s2+ triple 219c emitter build. It's using a Dr Jones H17F driver and mtn emitter. I've noticed that the output can get a bit jittery on higher outputs and it doesn't seem to be doing thermal protection (I set the level to 40°C and my infrared thermometer is showing the head getting up past 60°C
I took everything apart and redid the thermal paste with some newer artic silver. I resoldered the emitter then jb welded the spacer to the pill.
Hopefully tomorrow everything will be better and the thermal issues mostly gone.
MascaratumB
MascaratumB's picture
Last seen: 5 hours 9 min ago
Today I changed the reflector in my convoy S2 (with S2+ short tube, Led4Power 4-6A driver & spring) and Convoy forward clicky switch) with Osram White Flat 1mm2 ! I liked the beam with the OP reflector, but wanted to try it with SMO.
Here are some pictures, before and after, OP > SMO!
Not sure if this is the best way to show them in gif and side by side, but I hope it works!!
I have some doubts for those who installed this led under a SMO. Is it normal to get some “rings” or at least a “larger corona” between the hotspot and the spill, or do I need to refine the placement of the gasket+reflector to reduce the artifacts?
Thanks in advance Beer
Overall, the beam looks tighter as it should. I need to test it outside yet and see how it performs. Still, this is my “pocket throwerBig Smile
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
CRX
CRX's picture
Good idea with the before & after comparison GIFs Thumbs Up
MascaratumB
Thanks CRX! Thumbs Up
I noticed I had different WB calibration so there’s a difference in the overall colour of the photos and it is not related to the LED.
I guess it can be seen the slightly tighter hotspot and the larger corona, right?
The LED is centered (I see the “flower” shapped hole in a close beam) but I don’t know if it could be improved or not. It is hard to put it in place.
I had to use white electrical tape around the SMO reflector as well so that it didn’t move while screwing in the pill… Tired
OL Contest 2019
GIVEAWAY: 1 / 2
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 17 min ago
That’s some serious skill. You make it look easy. Smile
gchart
gchart's picture
Thanks, TK! That means a lot
khas
Last seen: 2 weeks 3 days ago
I put a Luxeon V 4000K on a Manker 28mm MCPCB in a MATEMINCO MT35 Mini.
I had to use a small strip of kapton tape on the central pad of the emitter to isolate it from the positive side.
djozz
djozz's picture
Last seen: 5 hours 51 min ago
Interesting solution, so the strip of tape is in fact soldered in now?
Long time no see khas btw Smile
khas
It looks something like this :
I don’t know about the longevity, it’s not perfect if the little piece of tape ever fails it will create a short circuit hopefully “just” melting the springs.
I have run it on turbo until it was to hot to hold, but only time will tell. I tried to find a 28mm 4040 MCPCB, but I could only find a 20mm or a 32mm. I will try this for awhile and if it fails maybe I will try to file the 32mm to make it fit.
Chatika vas Paus
Last seen: 3 hours 40 min ago
I haven’t posted anything here for a long time.
Gray C8. Dual 2nd Blue spring on the tail. TA fet+6+1 with 20awg wire. 3x lh351d 4000k & 3x lh351d 5000k, both cri90. Ledil Anna-40-6-M. Mcpcb and alu spacer from l4p.
I measured almost 10A on the tail with vtc5a. Probably it would be more if I had a clamp meter.
I would like to be able to do more measurements…
Geuzzz
Geuzzz's picture
Very nice! A wall of hi cri.
contactcr
Nice build! The LH351D look good with the narrow smooth optic too if you ever want more reach.
kikkoman
kikkoman's picture
New switch and boot for the MT22A so it can tailstand.
Also turned down the edge of the release button a tad so it’s much less prone to opening accidentally.
Next – a better driver (of course)
TheOnlyDocc
First pic is the original Switch rubber boot from the ZY-T08. On the second pic you see the original 1288 switch that i would like to change to the one on the pic. To make space for it i dremel milled the ring where the retaining ring is screwed in down from 5 to 2mm. After that i noticed that the Convoy S2+ metal switch boot could fit. So i grinded a 1,5mm metall ring to fit the Metal switch boot to the tailcap. And to make it look a bit better i added a o-ring. One is a simple black o-ring the other a blue GITD o-ring. The metal switch boot sits 100% flush with the tailcap end. So tailstand is possible and it feels soooo nice compared to the original 1288 with rubber boot. Now i have to get the new pill and the 3V XHP-50.
