What did you mod today?
8574 posts / 0 new
gchart
gchart's picture
Last seen: 2 hours 49 min ago
Ooh la la Love
djozz
djozz's picture
Last seen: 8 hours 8 min ago
Very nice! If the upcoming FT03 with this leds performs similar I will be a happy camper! Smile
id30209
id30209's picture
Last seen: 16 min 19 sec ago
Past 1month mods
WTB Titanium 4sevens Quarks & Jetbeam TCR1
id30209
id30209's picture
Removing F from H17F
pearlriver
pearlriver's picture
Last seen: 2 hours 23 min ago
djozz wrote:
pinkpanda3310 wrote:
pearlriver wrote:
Crazy
Looks like you made the host Glasses Any more build pics Smile
Yes please Smile And the feet and coffee are misleading, I bet that was a lot of work Big Smile
Crazy
CRX
CRX's picture
Last seen: 2 hours 16 min ago
CRX DQG Titanium 10180, 10280, 10440 Pocket Charger/ Spare cell carrier.CRX Titanium 10180, 10280, 10440 Pocket Charger..
This titanium spare cell/ pocket charger, being modular can carry and charge 10180, 10280 and 10440 cells.
It has a 100mA charge rate.
Made from a DQG titanium pill capsule & extension pieces plus a charger unit from a 10180 rechargeable flashlight.
The section with the brass rings can be removed & used to extend the laser to use a 10440 cell and the remaining sections will still house the other 10280 cell that the laser normally uses.
This is made to accompany my:
CRX CuTi Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Tail Sw - 1600mW Laser.
10280 cell version:CRX CuTi Laser Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Tail Sw - 1600mW.....
10440 cell version:CRX CuTi Laser Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10440 - Mo Tail Sw - 1600mW.
CRX CuTi Laser Burning Matches CRX CuTi Laser Burning Balloons
I also made another couple of wee titanium gadgets for my keyring..  Smile
CRX Titanium Magnetic Extendable Keyring PenCRX Titanium Magnetic Extendable Keyring Pen.
CRX Titanium Magnetic Extendable Keyring ToothpickCRX Titanium Extendable Keyring Toothpick.
CRX Titanium Extendable Pen &  Toothpick.
CRX Utility Keyring - CRX CuTi Atom Nichia 219C, DQG Hobi+ 365nm UV & Petrol Lighter, 1.6W 450nm Blue Laser.
djozz
djozz's picture
Nice stuff CRX! Have you already seen your designs nicked and produced in China? Maybe start the CRX Gadget Company.
CRX
CRX's picture
It was sort of the other way round this time..  Big Smile
I always had the True Utility telescopic pen but wanted a titanium version, then I saw the toothpicks when searching.
I think I did invent the worlds smallest extendable titanium ferrocerium rod though Smile
DB Custom
DB Custom's picture
Last seen: 12 hours 20 min ago
Since I had another Luminus SBT-90 Gen 2 to do something with, I modified my scratch built 124mm reflector light, DBC-07.
A write up on it HERE.
So now it’s the largest BLF Q8 ever! lol
And it easily hits a hay barn at 1.02 miles distant…
I tested it with Samsung 18650’s, both 35E and 25S, it makes from 4300 to 4800 lumens and a quick 5M test (too close I know but it was still daylight) shows 1.71Mcd! Big Smile
Edit: Worth mentioning that the beamshots here and on the write up were done using the 35E cells at lower output. Wink I have new 25S cells arriving today… the ones I tested with have been, well, Ham’red!
Dutcheee
Last seen: 7 hours 52 min ago
Today I put a Oslon HX Boost HL in my GT Micro. I had bad luck getting a good focus, but it still more than doubled in throw compared to the XPL-HI NW.
It out-throws the FT03 with 50.2.
Before with stock XPL HI NW:
After Oslon HX Boost HL mod
Th558
Th558's picture
Last seen: 28 sec ago
I think that’s the HL.
Agro
Agro's picture
Last seen: 2 min 1 sec ago
Yes, Boost HL.
Unheard
Last seen: 9 min 57 sec ago
WB daylight
Another Jet II MK. Ladies and Gentlemen, this is my very first reflow Beer
Some time ago I modded my C8 (SMO to OPR and XP-L Hi to XHP50.2, A6 driver) and was left with a very nice XP-L Hi U6-4C MCPCB. Now this LED resides on the original board of the Jetbeam. I’m really proud Blushing .
Edit: Yeah, I see it’s not centered Tired Facepalm
NeutralFan
NeutralFan's picture
Last seen: 3 hours 40 min ago
Looks good to me Unheard. Congrats on your first reflow!
I’d rather use my flashlight around the house than turn on the lights.
Unheard
Thanks Smile . Now I know why I ordered some 219B Big Smile .
lumenzilla
lumenzilla's picture
Last seen: 1 day 16 hours ago
Unheard wrote:
WB daylight
Mine was worse. Congrats!
CRX
CRX's picture
TrustFire Mini-08 Electronic Tail Switch.TrustFire Mini 08 XP-G2 S42B - QLite 3A Moppydrv - 16340 - E-Tail Sw - Rechargeable - 700lm.
NeutralFan
An amazing mod CRX!
gchart
gchart's picture
Modded my new Tool AA V2.0 Ti:
  • Reflowed a Luxeon V2 5000K
  • Added a bleeder resistor (stock tailcap works ok without one, but not my custom tailcap – it needs a dependable current path). Used a 0603 footprint 750 Ohm resistor stacked across the main capacitor (see the yellow circle in the picture).
  • Swapped the black tailcap for a very light green GITD one (link). The only problem with these is that they don’t have a “nub” inside, so you really need to press in order to activate the switch. To address this, I put a dab of clear silicone caulk in it and let it cure. Works great now. This lets a TON more light through than the stock black tailcap.
  • Stripped the stock illuminated switch board, which is a similar set up to the Convoy add-on illuminated tailcap that utilizes a clear plastic washer to let the light get to the tailcap (albeit, somewhat inefficiently).
  • Installed a battery-monitoring tailcap. It has 4 LEDs that extinguish one by one as the battery drains down.
  • Attempted to strip the gold clip, but failed. After a 30 minute bath in a strong lye solution, the coating didn’t budge at all. It probably is real gold plating. It’ll stay for now. I’ll probably either just remove the clip or grab a stainless one from another light.
Agro
Agro's picture
Nice upgrade gchart. Is it 10440 or 14500?
gchart
gchart's picture
Oops, it’s AA / 14500. I just updated the post.
Skylight
Skylight's picture
Last seen: 14 hours 54 min ago
Nice and skillful mod, gchart. Cool
That battery-monitoring tailcap is incredibly genious. Shocked I will try to build one. I need this on my flashlights. Party
BOO5TED
BOO5TED's picture
Last seen: 4 hours 34 min ago
That battery tailcap, kinda want.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
gchart
gchart's picture
The HM1160 were cheap enough that I ended up buying 40 just to even out the shipping fees Facepalm
So… I could probably whip some up for folks if you know how to install them (and a bleeder resistor).
lumenzilla
My friend use torch to de-color the clip, works well.
Btw that’s a nice mod of yours Thumbs Up
DB Custom
DB Custom's picture
Y’all probably know that the X6 is one of my favorite lights, right? Like, I have some 19 of these and more than 12 different emitters in use. So today I put the 90.2 in an X6, serial number 62 in the SS/Cu Limited Edition light. Really nice look, really nice power!
Using a Samsung 25S 18650 it pulls 25.5A at the tail for 5190 lumens at start (too hot to hold in 20 seconds), makes 100.6Kcd for 651.25M throw. Me Like! Big Smile
SKV89
Last seen: 47 min 24 sec ago
SBT90.2 in such a small size sounds fun! Did you put it in the copper version?
EasyB
Last seen: 5 hours 56 sec ago
It had to be done! Thumbs Up
Agro
Agro's picture
Beasty. Smile
id30209
id30209's picture
DB Custom wrote:
Y'all probably know that the X6 is one of my favorite lights, right? Like, I have some 19 of these and more than 12 different emitters in use. So today I put the 90.2 in an X6, serial number 62 in the SS/Cu Limited Edition light. Really nice look, really nice power! Using a Samsung 25S 18650 it pulls 25.5A at the tail for 5190 lumens at start (too hot to hold in 20 seconds), makes 100.6Kcd for 651.25M throw. Me Like! :D
Pics please!!!
Did you use stock driver?
