What did you mod today?
8825 posts / 0 new
EasyB
Last seen: 7 hours 21 min ago
Thanks djozz.
Here is the aftermath.
There is black soot/carbon between the positive and ground.
After cleaning it out I saw that part of the dielectric layer was burned, leaving a cavity. I think this MCPCB is probably not usable anymore.
This is the flux paste I’m using. It says solder paste but there is no metal in it, as far as I know. I don’t use a solder paste; I just tin the pads and keep them clean with some flux.
I notice it says to clean to avoid shorts. I’ve been using this flux for years and have had a few similar instances of shorts at the LED footprint, none as serious as this one. Is there a different type of flux you guys know of that would be less likely to produce shorts?
Lightbringer
Lightbringer's picture
Last seen: 5 hours 10 min ago
Quick goggling shows 2 kinds of Pro’sKit soldering paste (with pix of each)… acid-free and lots of acid.
Guess which one you got?
Chatika vas Paus
Last seen: 2 hours 10 min ago
Jaxman E1. I changed the switch leds for warm white and replaced the resistor (default 100r for 2k2). Now the LEDs are not so bright, but they can still replace the firefly mode. I also replaced the driver for FET+1 with Anduril so the switch leds have 2 levels of brightness. I left the led wires as they were and used the Anduril files for D4-219c, so the flashlight doesn’t get too hot.
djozz
djozz's picture
Last seen: 41 min 11 sec ago
Nice mod, CvP!
EasyB
I could not find a with-acid variety.
My flux paste is old and filthy looking. I wonder if that has something to do with it. In any case I think I will try a new flux.
Lightbringer
Wellp, it also says right on the tin that it’s not for ICs and such.
With: https://www.amazon.com/dp/B00CU7MYS2
Without: https://www.amazon.com/dp/B06×6CYVR4
NeutralFan
NeutralFan's picture
Last seen: 9 hours 58 min ago
I just bought some of this soldering flux tonight since I was running out: MG Chemicals RA Rosin Flux Paste.
I’d rather use my flashlight around the house than turn on the lights.
EasyB
I have developed a renewed appreciation for convoy S2(+)s. They are compact and the reflector is the right size for medium to close range use. I’ve recently modded a few with regulated drivers and different emitters for biking at night. I use 3A or 1.5A mode depending on the length of my ride and use different size emitters for my helmet and handlebars and whether I’m road riding or mountain biking.
Don’t pay too much attention to the tints in the image because I’ve dimmed the lights to be close in beam intensity to one another, and some of the drivers use PWM to dim while others use constant current dimming.
Top left: S2+, smooth reflector, sliced 3V XHP50.2 1D with convoy linear driver.
Tint of the sliced emitter at ~3A current is close to a cree 3D tint. At 2.95A current I measured 5.5kcd and 70lux ceiling bounce. It has a very wide and prominent corona (due to the excited side-phosphor) extending almost to the edge of the spill.
Top right: S2+, smooth reflector, LH351D 5000K 90CRI with 8×7135 driver.
At 3.03A I measured 5.7kcd and 63lux ceiling bounce. Beam hotspot is very close in size to the sliced XHP50.2. The relative output/efficiency seems impressive given that it’s 90cri.
Bottom left: S2+, smooth reflector, XPL HI 3D with 8×7135 driver.
At 3.04A I measured 12.9kcd and 60lux ceiling bounce.
Bottom right: S2, smooth reflector, 2mm^2 WF 5400K from kaidomain and convoy linear driver. I bought this hoping for a warmer tint, but to my eye it does not really look warmer than the other CW 2mm WFs I have, but it does have a noticeable purpleish tint, so I guess that is below the BBL. At first I was going to change it out, but I tried it outside and I thought it worked ok and provided good contrast.
At 2.97A I measured 23.7kcd and 50lux ceiling bounce.
So each time the emitter area halves, going from 8mm^2 to 4mm^2 to 2mm^2, the throw at the same current approximately doubles. For off-road trails I use the sliced XHP50.2 on the handlebars and the XPL HI on the helmet. The off road trails around here are typically very curvy so not as much throw is needed. I took this setup on the road (actually paved trails) and I felt I wanted more throw because of my increased speed and farther line of sight. Which is why I made the S2 with the WF.
EasyB
I think those are actually the same product, and there is just a typo in the product title on amazon for the first one. The green in the second one is just a wrapper and they both have the warning about ICs. Anyway I will now heed the warning and hope another flux is better.
Lightbringer
I like organic flux. Blue stuff that looks like washer-fluid.
Fizzes away nicely when hot solder hits, no sticky goo left over.
Chatika vas Paus
Sofirn C8F. 3x xp-l hi V3 3C. I wanted to use 4000k, but I didn’t have one and didn’t know what to do with these 3Cs. Driver is FET+1 with Narsil v1.3. Two amber leds on the switch.
I guess I’ll try to sell it and make another one with luxeon v2 4000k. I like the size and overall shape.
CNCman
CNCman's picture
Last seen: 3 min 20 sec ago
Giving a spring bypass a first try. I was going to put the wire inside the spring, but this effort proved to be impossible. The guys who can do that are Magicians. Shocked
The patient is a MT09R that I’m trying to squeeze a few more lumens from. Evil
This light gets super hot very fast. Shocked
Before new springs, it was already bypassed but it was unclear the size wire, it looked to be 20 gauge.
The driver spring looked to be 22 gauge, not certain.
The two bypass wires in the battery tube were actually 18 gauge so no change needed there.
Cut the springs shorter to match factory length.
Tailcap after new Beryllium copper springs and 18 gauge bypass.
The plastic insulators were removed to allow using flat top batteries.
The driver with a new Gold plated Beryllium copper spring and 18 gauge bypass.
After all this we gained an additional 3 amps to 25 amps and total 14,290 lumens. And yes that’s a bit low lumen reading and now I’m questioning the lumen tube accuracy for high lumen lights. It is calibrated with “ maukka “ lights. So any help or advice is welcome. Smile
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
JaredM
JaredM's picture
Last seen: 8 hours 14 min ago
CNCman, a word of caution about spring bypasses. Be sure to position and size any (+) contact wire such that in the event of a failed solder joint/wire end, that you don’t short internally against (-) components. In your case, the most dangerous one is the driver wire. I would also consider rotating your battery contact board wires 180 degrees
Lexel
Lexel's picture
Last seen: 10 hours 34 min ago
the wire you used has very few strands so it will break relative quick
always use super flexible wire that has hundreds of strands per mm²
here 2 times 0.5mm² one is standard wire the other high flexible silicone
MascaratumB
MascaratumB's picture
Last seen: 3 hours 28 min ago
I was happy today!
I received some drivers from Lexel, I would finally be able to do something to break the quarantine boredom.
And so I did.
I picked my Bliztwolf BW-ET1 (e-switch, 1 or 2 AA cells) that i wanted to mode for a while. It was a light I reviewed a while ago, I took the driver out and never used it again.
I wanted to mod it to use 2 × 14500 Li-Ion cells and Anduril firmware.
So, today I received the 2S 15mm driver and took my chance.
I forgot to ask Lexel to add the switch wires, and had to add them. Small pads, but no issues.
Then I needed to do one of the trickiest parts for me, something like “piggybacking” the light, using the original driver “contact board”, that has a specific size and shape.
I had to remove the spring from the driver (I also forgot to ask to not include it Facepalm ) and put the + wire back in place.
I also had soldered 2 wires onto it the original board, that would be soldered then to the driver.
After this I add to solder the e-switch and I tested the XHP50.2 (soldered onto a aluminum PCB that was from an old XML2 led Facepalm ) I got from a BLF member some weeks ago.
Even without soldering it, it was working , so I consolidated the work.
To avoid contacts/shorts between the reflector and the wires’ solder, I added some tape on the back of it.
With everything mounted, I turned the light ON and…it only worked well for some seconds Oops
After powering it in Turbo, the light started to turn blue.
I immediately shut it OFF and looked to the led… It turned it ON again and it only aggravated the situation Tired
So, what did I do wrong here? Flat Stare
Bad led reflowing?
Too thin PCB?
Other?
Any help concerning this is helpful… Thanks in advance!
I have other mods planned with this type of Led and 2S 15mm drivers (14500 Li-Ion), so I am now thinking to order other XHP50.2 from Simon eventually.
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
Lexel
Lexel's picture
no DTP MCPCB most likely if it was a 6V LED
MascaratumB
I should have used the sinkpads, right? Oops
They are small so I would have problems centering them. But I learned my lesson!
Thanks for the reply! And for the drivers too Wink
OL Contest 2019
GIVEAWAY: 1 / 2
CNCman
CNCman's picture
Thanks, I did not notice that. Thumbs Up
This is the only light I own with bypassed springs. I am going to remove them this weekend because the light simply gets too hot and actually shut off after running on high for 30 seconds and then on turbo for 30 seconds. Not what I was expecting to see from this light. I measured 25 amps with 30Q’s and it gets very hot very fast on turbo, almost useless. I had given thought to water cooling it but it’s too small for that.
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 4 hours 4 min ago
I added a few more photos HERE.
EDC
FW3A, SST20 4000K || S21A, Crescendo MTNdd 20mm, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, LH351D 4000K | L2 w/6A 20mm SST40 driver, XP-L HI | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | SK Zoomie Nichia 5000k, C2 driver | EagleTac clip | Ultrafire C2 w/5A 17mm & XM-L2 | Nichia 219C 2700K with gray S6 |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3)
Chatika vas Paus
Red Convoy S2+ with triple sst20 FD2 on 20mm Noctigon soldered on triple pill from Kiril. FET+6+1 with bistroHD and custom modegroups, Carclo 10511, fireball red turboglow, dual BeCU springs at the tail.
It’s heavy.
jon_slider
jon_slider's picture
Last seen: 6 hours 3 min ago
Installed an sw45k into a V10r Ti+ that originally had an XM-L2
Maximum is 280 Lumens, after 5 minutes it is still producing 230 lumens on a 16340. The lowest mode is 0.04 lumens, which for me, as a firefly lover, is a very nice sublumen option, considerably lower than the spec of 1 lumen minimum for these lights.
Considering the centering challenge, since the centering ring is for a larger LED, and the reflector has a large opening in the bottom, I find the beam very satisfying, and better than the original. The hotspot is tighter, and of course the tint and CRI are vastly superior to the original.
gchart
gchart's picture
Last seen: 5 hours 43 min ago
Great mod, jon_slider. What a beautiful little light, now with beautiful tint/CRI to go with it.
jon_slider
@gchart, thank you for taking the time to comment, I very much appreciate the kind words
The V10r lights are truly a joy to use, I am very fond of the design and operation of the magnetic control rings.
They are also slightly easier to work on than the RRT-01, and I have come to enjoy the tailswitch option of the Sunwayman, which lets me turn the light on and off at the same level as last used, which can be a convenient form of memory.
moderator007
moderator007's picture
Last seen: 3 hours 21 min ago
Oh man, nice looking light jon_slider with your favorite high cri rosy led. Thumbs Up
That xml reflector does take a little bit to get centered, but it does work amazingly well with the smaller led.
Your going to be a sunwayman before you know it. Silly
jon_slider
You are so true Smile
definitely an equal opportunity Magnetic Rotary Man
I like that the Sunwayman V10 and V11 models lego too Wink
The sw45k is much easier to get a good hotspot without donut hole
the E21a sits lower, and benefits from being raised 0.5mm
the bad donut on the E21 light on the far right, is because the LED was not raised, and needs to be redone
while the E21a light second from left IS raised and turned out really well
(both were originally xpg models, with smaller reflector holes than the xm-l2 models (Ti+ and V11r)
shirnask
shirnask's picture
Last seen: 2 hours 6 min ago
So jealous, wish I could find one too. Sad
NeutralFan
I replaced the Samsung LH351D 4000K in my silver S2+ since I didn’t like the tint. I put in triple Samsung LH351D 5000K (SPHWHTL3DA0GF4RTS6) LEDs that I got from Digi-Key. I shaved them to improve the throw and to hopefully lower the CCT a bit. I like the tint of the new LEDs much better. They appear almost pure white with a very slight touch of magenta. BTW, the green lighted tailcap uses only 0.03 milliamps so theoretically should last 10+ years on the Samsung 35E battery.
jon_slider
NeutralFan wrote:
DA0GF4RTS
I like the tint of the new LEDs much better. ..
congrats, those are nice white LEDs, to me slightly pink compared to daylight.
I use my shaved 5000k LH351d often (shout out to contactcr for the hookup). Good tint for a tasklight, during the day imo..
NeutralFan
Thanks jon_slider. The tint looks very good, but I’m still not sure if I like it better than my triple shaved 219B sw45k. But if I had to pick, I guess I would go with the Nichia. But then again, the Samsungs are so much brighter! Choices, choices…
jon_slider
NeutralFan wrote:
if I had to pick
We are fortunate that we can enjoy Both..
im polyamorous, but most faithful to sw45k, after dark
the LH351d is more of a daytime dalliance
