What did you mod today?
9051 posts / 0 new
Rdubya18
Last seen: 6 days 9 hours ago
Nice ! Patience pay off . Thumbs Up
NeutralFan
NeutralFan's picture
Last seen: 4 hours 25 min ago
Nice job jon_slider! So which V10a do you like better, the sw45k or the 4500k E21a? Or is that like choosing your favorite child? Oops
I’d rather use my flashlight around the house than turn on the lights.
jon_slider
jon_slider's picture
Last seen: 40 min 11 sec ago
Thank you Rdubya18 for the kind words. You are right, I was glad I took my time and did not crush the head tube..
and thank you also NeutralFan
My favorite is the sw45k in the evening (the tint is closer to incandescent), and e21a during the day (the tint is closer to daylight)
because
the sw45k is an easier mod to get a decent beam, and it is not as green as the E21a. Green is relative, another way to say that is the E21a is less pink, hence closer to daylight, which is greener than incandescent.
E21a makes whiter whites, but sw45k makes juicier reds
the E21a mcpcb is NLA, whereas the sw45k is an easy reflow to the stock mcpcb, in these models that were xpg
even in the xpl models, the sw45k is easier to get a good beam, the E21a sits lower, which is not good for the beam.. (the LH351d 5000k dogfart is dedomed, which lowered the cct)
output and weight:
the V10a w AA Alkaline weighs 82 grams and makes 65 initial lumens, the same head on a V11r body w 16340 weighs 65 grams and makes 210 lumens at startup
Both of the V10a have firefly lows below 0.01 lumens on my meter
(I can see they are on, but my light meter reads 0.00)
the stock xpg is 10% brighter than the sw45k
form factor:
Im new to AA… it is heavier and longer, easier to hold, though personally, Ive always liked smaller things. For me, the smaller and lighter 16340 body is easier to carry.
UI:
Im very happy to fill an AA niche with a Rotary.. the V10a fits that role nicely.
Beamshots:
all things considered… the sw45k is the winner!
"High CRI lights for sale":http://budgetlightforum.com/node/72660
Scavenger177
Does anyone know where I can get spare cree xhp 50.2 reflector spacers for the convoy c8+
Scavenger177
Chatika vas Paus
Last seen: 40 min 37 sec ago
Here is for reflector with 9mm hole
And here for 7mm hole
Scavenger177
Thanks, appreciate it!!
Scavenger177
CNCman
CNCman's picture
Last seen: 4 hours 23 min ago
Finally received an order for food grade silicon tubing and installed on the Water cooled MT 35 light.
The workshop is portable as we are still renting a small house.
The tubing wanted to kink so I made something from .005 thick ss shim to keep it round in the sharp corners.
After several attempts and failures it finally fit correctly. Beer
I’m finished for now until I find the correct SBT90.2 and see if Lexel will make a driver for it. Smile
Wrapped the battery tube with tennis racket tape for a better grip. Also added a simple switch on the pump.
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
EasyB
Last seen: 3 hours 6 min ago
Put an SBT90.2 in an emisar D1S. It pulled 20.5A from a VTC5A and I measured 184kcd. A high output thrower in the palm of your hand.
Rdubya18
My flashlight mods are pretty boring compared to what most of you guys are doing , but I did modify a slab of steel into these Smile
bassoverflow
bassoverflow's picture
Last seen: 1 day 13 hours ago
I sent my Olight Autumn Ti off and had it bead blasted. Here’s the before and after.
KawiBoy1428
KawiBoy1428's picture
Last seen: 31 min 28 sec ago
Added a few more modded (NovaTac) E-switch tail cap lights to my collection….
. Got’em off evil-bay $30 bucks a piece.. dude has 8 more Evil
. Running one on the Mini 14….stock 80lm now 500lm nice little CQB light.
KB1428 “Live Life WOT
jon_slider
KawiBoy1428 wrote:
…NovaTac… stock 80lm now 500lm
congrats
what mods produced that result?
If interested in the option to program those Novatac Spa Defense models (they come set up as 120T, but can be changed to 120P configuration), there is info in this thread.
And if you want a Titanium bezel, they are available from RPM (guessing you can make your own too).
my latest mod cut the output in half, XP-L to 3000k 219b in a Thrunite T10t (in the middle).
pic is a link to teardown
Marc E
Last seen: 9 hours 26 min ago
What are ‘these’?
Firelight2
Firelight2's picture
Last seen: 25 min 27 sec ago
Marc E wrote:
What are ‘these’?
Fidget Spinners?
Pocket Toys for kids?
Desk Sculptures?
Rdubya18
Marc E wrote:
What are ‘these’?
Those are tools for a lathe and milling machine . I am practicing to get good enough to make flashlights , for myself . Can’t seem to get making the small , fine threads I want yet . I’m getting there slowly .
KawiBoy1428
jon_slider wrote:
congrats
I have found they use 2 different drivers/pills…. This one/style will get you 500+ (580 tested) lumens The other style just over 200lms using a 16340 or18350….I know the 250 click trick also..
. The stock LED is a real POS
jon_slider
KawiBoy1428 wrote:
they use 2 different drivers/pills:
great info!
some of the reflectors differ also
This model of the reflector has more throw and a tighter hotspot.
This model, has the rings in the reflector, that produces a slightly diffused hotspot, with less throw.
KawiBoy1428
Yep these are Triple Candidates ….with a FW3 driver.. Big Smile
jon_slider
KawiBoy1428 wrote:
Wow Yes!
Looks like you scored a light w black stainless bezel
NovaClips are hard to come by, but I think HDS clips can work if the hole is reamed out a bit
per Henry:
the Novatac clip hole is 0.950”
the HDS clip hole is 0.930”
KawiBoy1428
This is the one I want… Love
Tom E
Tom E's picture
Last seen: 7 hours 7 min ago
Modded an Amutorch AX4 quad to run a FET+1 Anduril driver. Fairly simple mod, stayed with the stock SST-20 4000K's - I thought they look relatively above avg for SST-20 4000K's, smooth tints in the beam, yes - slightly green at low modes, not as much as I've seen from other SST-20's though.
This quad reflector light with SST-20's has a tighter hot spot than triple or quad TIR optics, brighter,maybe wider spill.
AX4 on the right, AX3 on the left, AX2's in the middle. If you didn't know, I'm a fan of the Amutorch lights:
More complete view of my Amutorch collection:
AX4 tear down. Classic driver mounted switch:
Dry style thermal grease - needs to be replaced:
The driver cavity is extremely tight. This quad light is the same length as a FW3A so sacrifices are made. I used the hot air station to removed the ground brass ring off the stock driver. The driver board is CK's design from here: http://budgetlightforum.com/comment/1437313#comment-1437313, which turned out to be about perfect fit
Reflowed:
Had to move the switch to the very edge, resulting in the back feet not making contact to the pads. Patched in solder/jumper wire to bridge the gap. tested the switch, then epoxied the switch in place to give it back support, keep from breaking/bending as these switches tend to do:
Didn't end up working reliably. Somewhere between 5-10 clicks, it stops working, the let it cool, get another 5-10 clicks with stopping again. So, got bad solder joint on the patch work, and it's epoxy sealed up now Facepalm (I'm using this moji a lot lately...). Used 36 AWG to patch the patch, taking advantage of the exposed metal tabs near the top of the switch:
All good now! Working well with Anduril, temp calib, voltage calib.
I replaced a low profile driver spring with a brass button, and added a 22 AWG bypass to the tail spring. New 22 AWG LED wires, that are pretty short.
The light does get red hot in a few secs, as expected.
Does about 3000 calibrated lumens at turn on (VTC5D cell), drops quick. I measured 20 kcd throw, taken at 5m. Stock I measured 2500 lumens, 17.5 kcd on the same cell. I'ts not much of a power increase, but getting Anduril on it was the main reason for the mod.
jon_slider
V10r mod to sw45k
CRX
CRX's picture
Last seen: 10 hours 59 min ago
NovaTac 120T Triple XP-L HI - D4UI - 18350 - E-Tail Sw - 2240lm.NovaTac 120T Triple XP-L HI  - D4UI - 18350 - E-Tail Sw - 2240lm.
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
BOO5TED
BOO5TED's picture
Last seen: 2 hours 40 min ago
Titanium Tool modded for deep pocket clip. Love this light but couldn’t stand the clip that came with it so I made my own. Well Benchmade made the clip, I just made it work with the light lol.
First holes I drilled didn’t work as planned so I just opened the lanyard loop a little(might just remove the loop all together since I’ll never use a lanyard with this one anyway).
It doesn’t tail stand now but this is my work EDC light, tail standing is not in this guy’s requirement.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
Firelight2
Simple mod: Modded an old early-model grey Emisar D4.
  • Reflashed the stock firmware to the latest version of Anduril.
  • Replaced the stock 10622 optic with a slightly throwier 10621.
I was hoping to replace the stock SST-20 high CRI with ones of better tint, but turns out I don’t have any with better tint that aren’t already sitting in an FW3A.
JaredM
JaredM's picture
Last seen: 17 hours 22 min ago
Today (when I shouldn’t have been toying with lights)..
Rebuilt my ET G25C2 from a direct drive single mode dedomed XM-L2 making 66kcd >> Convoy 5A driver w/ Bistro and a J5 4000k SST20w from Mouser under a LEDIL IRIS 12077 making 45kcd. I really like it now. The goal for this light was a “foul-weather-pocket-thrower”. Minimal spill and NW/WW. So far, I think I’ve accomplished my goal. Other CCTs will be tried, but this 4k is looking good under the TIR at ~5A.
Retuned the reflector focus/ centering ring in my Convoy M2 running the 5A/Bistro driver and a 1mm White Flat. Got it mostly centered and mostly artifact free. I’ll perfect it some other day but it’s 95% right now. Getting 79kcd at 4.62A. This was a PITA getting this setup tuned in. The M2 reflector/host interface/shelf doesn’t allow it to sit deep enough to focus the WF1. After filing the reflector, I managed to maximize throw, but halos and crescents were everywhere. Then I needed to add an additional o-ring between the glass and the bezel since the stackup height changed….
The 3030 gaskets available today seem to cause a strong halo artifact in the lights that I’ve used them in. I ended up gluing an XP ring in instead, as that yielded a mostly clean beam. I plan on pulling it out and painting it flat black when I get bored again.
lumenzilla
lumenzilla's picture
Last seen: 21 hours 41 min ago
CRX wrote:
NovaTac 120T Triple XP-L HI – D4UI – 18350 – E-Tail Sw – 2240lm.NovaTac 120T Triple XP-L HI  - D4UI - 18350 - E-Tail Sw - 2240lm.
18350?
Did you remove the signal spring? What driver are you using?
Agro
Agro's picture
Last seen: 46 min 11 sec ago
lumenzilla wrote:
18350?
Yes, you can see a piece of copper that carries the signal. I guess this is what enables 18350 support.
CRX
CRX's picture
The picture is a link Wink
lumenzilla
Sorry, didn’t notice if the pic is link.
Thanks CRX & Agro Beer
