What did you mod today?
9443 posts / 0 new
jon_slider
jon_slider's picture
Last seen: 5 min 50 sec ago
NeutralFan wrote:
Huge improvement jon_slider!
thank you for taking the time to comment
I agree completely
Sunwayman V11r mod to 219b 3000k 9080 sw30
on 16340
Max 220 lumens
min 0.01 lumens
id30209
id30209's picture
Last seen: 1 hour 34 min ago
jon_slider wrote:
![img]https://i.imgur.com/Mq165qbl.jpg[/img]!
OMG
Just realized what's in this happy box...
Outstanding!!
WTB Titanium 4sevens 2xAA tube
contactcr
Last seen: 1 hour 26 min ago
What is top row #5 and when are your old ones getting new higher output drivers? Smile
jon_slider
I may try one of the 2020 drivers, although Im perfectly happy with longer runtimes and less horsepower.. I seldom use more than half the available lumens
top #5 is a Nitecore EX10 Ti from Russtang, similar to the Legendary D10 with piston drive with a ramping UI that works on primaries, unlike all the presently available Anduril lights.
Scallywag
Scallywag's picture
Last seen: 1 day 21 hours ago
Today, hodor’s Olight S15 Ti and Jetbeam E3S arrived. Also today, Quadrupel’s Boruit D10 driver arrived.
I disassembled hodor’s lights. They were exactly as described.
Jetbeam E3S: I consulted with CRX (he’s done one before ) and found an old “other forum” thread. CRX recommended that the driver be pressed out from above. (He also found a horrifying disassembly video on youtube .) It was at this point that I decided I wasn’t going to save the old driver. I pressed it out from above with a straightened paperclip and needlenose pliers. A replacement driver is in the works, but will be straightforward.
Olight S15 Ti: Indeed, the switch itself is busted. It’s one of those tiny surface-mount tactile button switches. Also, I suspect the rubber/plastic physical button itself is damaged. Most likely, it should have been removed before the pill was removed, and the pill caught some of it. Also, it’s possible that’s not the case at all – I can’t tell. I was debating ordering some replacements and indeed thought I had placed the order, despite the estimated arrival time of September 30 – October 22.
I moved on to my Boruit D10. The Quadrupel driver was almost a perfect fit for the plastic part of the charger-driver sandwich, but I did end up having to file it slightly. I also only has 22 gauge high strand count silicone insulated wire, where I would highly recommend 24 gauge for this mod. For this reason, getting fitment of the wires through the sandwich, as well as into the grooves inside the body tube, was rather difficult. (I was unable to reuse the original leads as they were severed in the process of removing the MCPCB.) I’m currently debating throwing a Luxeon V2 in, or the original emitter back in, or waiting for my optics to arrive from Fasttech (probably next year). A provisional low-power test with test-leads works, and the on-board charging is functional. The lit tailcap is cool!
So I was sitting here, about to put my tools away, and I noticed the old D10 driver sitting, button facing up, on my workbench. Inspiration smacked me in the face and I took some quick measurements: it was a match for the broken switch on the Olight. I grabbed my solder wick and swapped them – it was a lot faster than I expected. I then tested the Olight pill partially assembled (MCPCB was loose but attached) with test leads connecting the battery. It functioned great. So I went to assemble the light and the switch did not actuate. With a lot of fiddling I decided that either the new switch was not as tall as the old one had been – impossible to tell, since the old one was in pieces – or the exterior physical button piece had been damaged. I eventually devised a method using UV glue on the inside of Kapton tape, wrapped around the pill partially and holding the hardened blob of UV glue over the microswitch on the pill. With even more fiddling I got everything back together and assembled – although not without almost ruining the entire driver with sloppy soldering on the MCPCB (I noticed because the reflector did not tighten fully – it actually screws into the pill!!).
So – if I ever feel stupid/crazy enough to pull that pill back out of the Olight, I would swap the emitter, clean the reflector, and clean the lens as well – I’ve muddied them a bit with all my fiddling. But for now, the switch and its silly adaptation are aligned perfectly and the switch actually has a really great feel.
Quick review of the S15: The emitter is almost the equal to the NW XP-L in my T10T V2, but it’s a bit yellow-green-er… the most noticeable “above BBL” tint of any emitter I’ve yet tried. (To guess – if the Thrunite were a 3D tint, the Olight is probably a bad 3C.) The output with 14500 is about equal to the Thrunite’s turbo on NiMh. The hotspot is very slightly tighter than the Thrunite. The body tube diameter and overall length are also basically identical to the Thrunite T10T V2, but the Olight S15’s head is decidedly chunkier. The switch is way easier to find than the Thrunite, and the pocket clip is slightly better (though it carries head-up). The UI is different than on my Olight S1: The S15 mode memory remembers moonlight (the S1 does not), and the S15 has a lockout (continuing to hold the button for another second after the 1 second hold for moonlight). Also, the S15 has 3 modes on NiMh/alkaline (four modes if two cells are used), but four modes on 14500. The threads are on the nicer end of Titanium threads I’ve dealt with.
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Firelight2
Firelight2's picture
Last seen: 29 min 42 sec ago
Swapped emitters between my Eagtac DX3B and my Thrunite T1. Both had neutral white XHP 50 emitters.
  • The DX3B had a great beam pattern with beautiful creamy tint. Unfortunately, mine is flawed with horrendous parasitic drain which can drain a full 18350 cell in less than 3 days with the light off the entire time.
  • The Thrunite T1 is a nice compact 18350 light, but comes with horrible green tint.
Since the Eagtac is too flawed to EDC and the T1 had such a greenish tint, I figured a good solution was to swap the emitters.
The swap went without a hitch. The Eagtac has a tiny ultra-thin square copper star press-fit into position by the reflector. The Thrunite had a much larger and thicker standard size 16mm copper star that was screwed down.
Unfortunately, when I turned them on…
  • The Eagtac’s beam seems a little whiter. It no longer has the great creamy tint of before.
  • The T1’s tint is STILL green even with the other emitter. Sick
I tried the T1 with the lens off, and then even replaced the lens with a UCL one I had laying around. Didn’t help… still seems greenish.
There’s only 3 remaining possible causes of the green in the T1 and they aren’t fixable:
  • The T1 is a lower powered light… approximately 1500 lumens compared to 2300 for the DX3B. Cree emitters are known to sometimes get more greenish as the current goes down.
  • The T1 has a much shallower reflector leading to a dimmer hotspot. Perhaps the lack of intensity makes the hotspot look greener.
  • Perhaps something about the coating on the T1’s reflector is making things greenish. This seems unlikely to me though.
Oh well.
StihlMad
Last seen: 3 hours 11 min ago
I joined this forum to buy some of these 219B’s not available anywhere else and today I installed my first one in a light!
  • FW1A w/SS bezel
  • 219B R9080 SW45K
  • firmware controlled Aux LED’s in red / blue as a show of support for first responders
Low
High
Neither camera settings nor lighting conditions are the same from shot to shot, sorry about that.
trakcon
trakcon's picture
Last seen: 6 min ago
Nice, StihlMad! I’ve been thinking about adding aux LEDs similarly. Looks good.
gchart
gchart's picture
Last seen: 44 min 28 sec ago
What a great light, StihlMad! And welcome to BLF Thumbs Up
jon_slider
StihlMad wrote:
  • 219B R9080 SW45K
very cool!
red and blue gratitude Thumbs Up
related: red and blue, in Titanium
Scallywag
Scallywag's picture
  • FW1A w/SS bezel
  • 219B R9080 SW45K
Low
High
Be careful with the 219B on a FET driver. The FW1A can overdrive the 219B and destroy it.
There are likely firmware revisions that could fix it…
le cigare volant
Last seen: 18 hours 49 min ago
Grabbed a very inexpensive Maglite Mini Incandescent 2-Cell AA flashlight online to play with. Swapped over the 395nm UV emitter from an Olight i3UV EOS and wired it to the original switch to keep the twist-on action.
https://imgur.com/a/CjhtJvp
andrx
andrx's picture
Last seen: 8 hours 40 min ago
tool aa biscotti
View post on imgur.com
turbiny
Last seen: 1 week 5 days ago
would it make a difference if each optics holder was (inner side) wraped with reflective tape
contactcr wrote:
contactcr
No I dont think so, all of the light should be reflected inside the optic. (TIR = total internal reflection)
Here’s a good diagram from LEDiL:
mitsuki08
Last seen: 14 hours 24 min ago
Did you just sand down a normal 17mm convoy driver?
moderator007
moderator007's picture
Last seen: 1 hour 44 min ago
Emitter swaped two Thrunite Ti3’s. These are very easy to mod, nothing is glued.
First one is a shaved LH351D 3500k 90cri from digikey.
Second one is a XP-G3 photo red.
Factory NW Ti3 on the left and LH351D on the right, set at 5000k white balance.
The NW has noticeable green around the cornea that the pic doesn’t show that much.
White balance set at 4500k.
Ti3 with the XP-G3 photo red.
Drver uses resistors for modes that can be changed to acheive different outputs.
More info in this post http://budgetlightforum.com/comment/1682835#comment-1682835
andrx
andrx's picture
yes and the pill too
turbiny
modded SK98 clone with nichia 219c 4000k
2mm spacer for tailstand
GITD tape hand cut
beam shots with fixed focus&exposure
zoom
high
medium
low
auto focus&exposure
artifacts i believe are due to bad cut of GITD tape and the small footprint of LED and big hole of the brown spacer (KDlight text is projected on zoom)
soldered the tail spring to the brass cap/cup
trakcon
trakcon's picture
StihlMad wrote:
I was looking more closely at your photos. Are the aux LEDs mounted to a separate board?
gchart
gchart's picture
Likely using this or something similar: http://budgetlightforum.com/node/66094
To be honest, I’m surprised we don’t see more of this mod. It’s pretty sweet. Come to think of it, I need to try that myself!
MascaratumB
MascaratumB's picture
Last seen: 20 min 38 sec ago
Nice one moderator007 Wink
The 3500K led seems quite nice !
And certainly better than the original one Silly
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
MascaratumB
Today I modded my original Convoy S2+ Desert Tan with a LD-x4 7A-9A driver and a Luxeon MZ 5700K 90CRI, both from led4power!
I kept the original pill with the Biscotti driver and XPL-HI led, and use another pill with a kiriba-ru custom retaining ring. The gasket is typical 3535 gasket filed to accomodate a 4040 led, like the Luxeon MZ
I like the tint, that is on the “border” of NW to CW, and specially it’s colour rendering! I would say it looks like a Nichia 5700K 90 CRI (although I don’t have mine installed to compare).
As seen in other experiences, this led creates a slight “donut hole”, even with OP reflector. However, that is more noticeable in close range. At distance (+5m), no problems!
LEFT: Luxeon MZ 5700K > 4 x Samsung 5000K > Nichia Nichia NVSW219BT ~5000K
RIGHT: Luxeon MZ 5700K > Luxeon V2 5000K > Luxeon V2 4000K > 4 x Luxeon V 4000K > Luxeon V2 3000K
EDIT:
Luxeon MZ 90 CRI vs XPL-HI 70 CRI
contactcr
Ugh now I ordered a few more just cause I know you are tinkering with the driver. Hope you ordered some extra resistors so I can ride your coat tails, lol.
Chatika vas Paus
Last seen: 3 hours 33 min ago
YLP X1 xp-g2 > 219b 4500k
My first keychain that have an integrated pill. The bezel is glued, but can be unscrewed without the use of heavy equipment.
Mcpcb is aluminum and glued, but something very weak. Easy to clean. The driver does not need to be removed to replace the led.
gchart
gchart's picture
Umm… is that the YLP’s driver? The one suspiciously labelled TANK007?
contactcr
integrated shelf but they anodized it Facepalm
if you sanded that you could probably convert this to FET 10440 and fill up dead driver space with 10mm copper MCPCB glued to bottom side
CNCman
CNCman's picture
Last seen: 15 min 59 sec ago
Unheard wrote:
CNCman, or use an ordinary pan and maybe some (very thin layer) thermal grease. I’m always recycling the grease from the MCPCB. Check temperatur with IR thermometer and watch solder after 180 or 220 °C to not miss the melting point by too much time. After unsoldering the MCPCB you’ll know if solder is leadfree or nice.
If it is lead free, do you know how to save the led ?
I did not know anyone was using lead free for led to mcpcb’s.
Thanks Thumbs Up
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
CNCman
CNCman's picture
kiriba-ru wrote:
CNCman wrote:
I tried using one of these cheap hot plates with no luck, temp control lets it get too cold and then too hot. I may try fixing it or trashing it.
Try to add some thermal mass between heater and pcb. Even 50gr copper spacer makes difference.
Yep, that is a good idea for extra buffer heat transfer space between off and on. Thumbs Up
Chatika vas Paus
Yes, this is the driver that was in this flashlight by default. That surprised me a bit too.
I’ve been thinking about something like this, but I don’t know how to sand a shelf that is “hidden”.
Besides, I prefer to power small lights with aaa, because I usually carry these with my keys and I do not have to remember to charge the battery.
