[Mod] "Junkyard Dog" (FandyFire L3 turns thrower)
10 posts / 0 new
FmC
FmC's picture
Last seen: 20 hours 29 min ago
 Flashlight parts are easy to hoard. They are light, small, & can be easily stashed out of the way in nice little containers, so normal folks don't notice your affliction.
 After a while, I'm sure most of us here have accumulated various bits & pieces. Don't worry, If you haven't been here long, it will happen to you eventually.... Smile
 I'd been wanting to do something with the FandyFire L3 that I had sitting around, as it was a well built light, & offered some good power potential with it's 2S3P cell arrangement.
In stock form, it's a 7x XML under-powered flooder. I bought it with a gift certificate I won from the 1st DIY comp here a few years back, & promptly blew the driver in it searching for more power.
It got stripped down, & made it's way into one of the nice little containers I mentioned earlier.
 Fast forward to now, I have several containers with all sorts of bits & pieces, & with a little time off work for the silly-season, I had come up with a plan to use some of the parts to resurrect the L3.
 I wanted to do another thrower, but that meant a few mods to the head of the L3... mainly to fit one of these to it;
It's the "KD" 86mm reflector, & the guy on the right looks really happy about it.
 I started by trial fitting the camera hoods & adapters I had lying around(in a neat container), until I had a working solution that would screw together directly onto the host.
 The LED shelf needed beefing up & raising, so I cut a 6mm thick piece of aluminium to size, & fixed it to the head, with JB Weld to fill the old emitter cavities, & secured it with machine screws from the underside.
I centered the head assembly on a bearing, & spun it to mark the exact center for the LED, using a dial gauge. The plate was then drilled & tapped to accept a 32mm Noctigon.
 I needed a buck driver, & I had a few old FL-2's kicking around. After a bit of probing around on the test bench, I found that if I briefly grounded a certain pin, it would change modes, so I was set for the e-switch-only L3.
 The FL-2 needed juicing up a little, but it also needs to be well heat-sinked for long-term operation. After blowing several spare LED's from one of the nice containers, I settled on a resistor combination that gave good, sustainable power, without being too close to the edge.
 The stock driver was stripped, & I added a copper ring, & made a copper cradle to sandwich the driver in, using silicone cubes cut to size on both top & bottom of the main driver components. The copper strips for the cradle were left over from the 2nd DIY comp, where I was attempting to neatly engrave the name plate for the stock....I must have about a dozen or so left....
The above reading is taken at the emitter, at around the two minute mark. It starts off a little higher, but settled down to that. Bring on the clamp-meter, I want to know what it really is....!
 Without a clicky switch, I realized I would have no way to turn the torch off, & there was absolutely no room in the tail (well, there was 1mm..) to install one. To provide a lockout, I modified the rear contact plate by cutting the ground traces, & attaching some more left-over copper scraps, which are connected by a washer which is epoxied to the underside of the tailcap, when it's twisted tight.
 With that tested, it was time to screw it all together, to see if it could become more than the sum of it's parts. The emitter is a XP-G2 S4 2B, de-domed in petrol. I spent a lot of time making sure the LED was centered perfectly in the reflector, & focused the height using shims cut from thin plastic sheet.
Now, a little teaser before I attempt to get some decent beam-shots.... Beer
Well, the beam shots are rubbish, but here's one of a building that's on the opposite side of a sports oval, just under 200 meters away. Mouse-over on the control shot to get the beam shot.
Edited by: FmC on 01/06/2016 - 06:43
pilotdog68
pilotdog68's picture
This is nice. I’ve always eyed that L3 as a high-powered XHP host, but I like what you’ve done with it. Your solution for the tailcap lockout is pretty ingenious as well.
I think I need to start shopping for camera hoods/etc and upgrade my Courui…
The Miller
The Miller's picture
Last seen: 2 months 4 weeks ago
wauw, educational and lots of fun to read as well! Thanks!
tech
pretty slick mod
FmC
FmC's picture
Thanks. Beer
I'm not even going to bother uploading the beamshots I took last night - maybe I'll give it another go tonight at a better location.
I did take a reading on the luxmeter @ 10 meters, though. 814Kcd, which works out to 1804 meters.
I was hoping for a little more, but it's still up there.
FmC
FmC's picture
Updated OP with ~200m beam shot of building.
JasonJ
Sadly I cannot see the beam shot. Not sure I can mouse over the control pic when I’m using my tablet. :_(
Otherwise, awesome job!
I’d be interested in the details on what lens hoods you used for this and the Courui D01.
pilotdog68
Tap the picture to “mouseover” then tap somewhere else to “mouseout”. At least that works on my phone.
FmC
FmC's picture
JasonJ wrote:
Sadly I cannot see the beam shot. Not sure I can mouse over the control pic when I'm using my tablet. :_( Otherwise, awesome job! I'd be interested in the details on what lens hoods you used for this and the Courui D01.
lol - you are not missing much with the beam shot. It shows up on my Android phone - maybe try a different browser?
With the lens hoods, etc, for this build I used (from the top down);
86mm "UV" lens
35mm deep 82mm telephoto lens hood
20mm deep 77mm standard lens hood
82mm - 77mm adapter (using the internal thread)
77mm - 72mm adapter
72mm lens ring, which slips perfectly over the bezel threads, & is held on with the original bezel.
I bought this set of adapters, which will come in handy if you are thinking of doing this kind of thing.
With the D01 build, I think there are some links to the hoods used in Linus Hoffman's original thread.
I detailed the process in my own build thread as well, but my method differed slightly from Linus'.
Beer
MRsDNF
MRsDNF's picture
Last seen: 21 hours 58 min ago
Nice mod and very creative. Love your work as usual.
