DQG Tiny 4th 18650 xml-2 review
125 posts / 0 new
Serp
Serp's picture
Last seen: 4 months 1 week ago
need to grind the star to 19.1mm ±
Make a spacer thickness of 2,05mm.
in the spacer should be a gap for the button
http://forum.fonarevka.ru/picture.php?albumid=1062&pictureid=15217
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15253
vresto
vresto's picture
Last seen: 14 min 22 sec ago
this small baby flashlight is a atriple xplhi is really suicide..some convoy i have and its really hot model:)
but i would like to get this tiny with better driver and it would be enough.7 amps on IMR
EDC- Jetbeam E40R,Emisar D4V2 XPLHI
Headlamp-Thrunite th30
Firelight2
Firelight2's picture
Last seen: 1 hour 39 min ago
Yes, there’s enough room inside for a triple. You might even fit in a quad, though you’d have to file down the sides of the optic and star.
For the triple, there’s also enough room for a small heatsink behind the star
Firelight2
vresto wrote:
this small baby flashlight is a atriple xplhi is really suicide..some convoy i have and its really hot model:) but i would like to get this tiny with better driver and it would be enough.7 amps on IMR
Yes, one downside is with the FET driver at max power, the head gets VERY hot very fast. Too hot too comfortably touch in 15 seconds is possible.
This was such a problem on my DQG Tiny III triple I ended up installing an external heatsink and button cover. This enlarged the head of the light, but made it able to run considerably longer without overheating.
Note that the Tiny III’s button is setup differently than the Tiny IV. In the Tiny III, the button is mounted inside its socket in the head and is connected to the driver via 2 tiny wires. In the Tiny IV, the button is part of the driver.
For purposes of modding the light into a triple, I think it’s easier to mount the button in the socket in the head rather than as part of the driver. Glue a replacement switch in place with arctic alumina then wire it to the driver. File off a notch in the star and heatsink so the switch wires can get from the switch to the driver. You can buy switches 50 to a pack for a few bucks on Ebay.
Firelight2
Here’s a link to my thread on Modding the DQG Tiny III into a Triple
The exact same mod can be done with the Tiny IV. The only changes you would need to make:
  • The Tiny IV’s head is actually removable from the body. They didn’t use too much glue. Instead of drilling out the center of the stock driver, simply unscrew the head and remove it. Then install a replacement driver. I haven’t measured exactly, but I suspect either a 20mm or 22mm FET driver from MtnElectronics would be the right size. Measure before you buy your driver.
  • Install a replacement microswitch in the head under the button boot with arctic alumina. You may need to slice off part of the inside bottom of the button boot to give enough room for the switch.
Be advised with a FET driver the head will get incredibly hot. This may not damage the light, but it could cause your pants or your hand to catch on fire. Use caution.
Serp
Serp's picture
Xenovora
Last seen: 3 weeks 1 day ago
Considering buying this light, but I’m stuck between this or the HC30 NW by Nitecore… Anyone recommend one over the other? DQG wins in size and half the price but turbo sucks in comparison, probably worse build quality I imagine, and better tint on HC30… Will I miss the small size of 0.4 inches in length and 0.1 inch in diameter difference?
I own Nitecore MH20 and can’t EDC (too big to,carry, I don’t want to move to any smaller capacity battery because of losing so much battery time, 18650 or nothing!!) looking for replacement EDC. Thanks.
Dutcheee
Last seen: 1 day 21 hours ago
I have the Nitecore P12GT,and the buildquality is the best from all the lights I own.
The HC30 is a totally different light than the DQG. Quality of DQG is definately worse than Nitecore IMHO. However my DQG 4 is ok, besides some scratches in the ano. Very very light (allmost too light) and super small. I like it, and for EDC 1 cm shorter is a lot. I like the modes on the DQG 4. I think it’s slightly under 850lm, but it gets rather warm already. The 18650 seems to be the heatsink, warms up as fast or faster than the light itself.
I don’t own the HC30.
Buy the DQG in NW tint, my CW tint is hideous, but I am modding it into a triple XPL-HI anyway.
Edit: If you go for the DQG, don’t buy from cnqualitygoods. Their customer service is non-existent..
In the end, it’s really up to you. The DQG is $27 with the coupon found on BLF
Xenovora
Thank you very much for your input sir, though I am mostly concerned about turbo run times… 60s for an overrated 850 is horrible because I use my light on turbo for 5-10 min streaks usually. Especially getting home and bringing in groceries….
Serp
Serp's picture
Light module burn out in long turbo.
Dutcheee
I don’t know about the HC30 turbo stepdown. Maybe there is none? HI in DQG is about the same (400lm) I guess as the nitecore.
If you like the looks of the nitecore and don’t mind the bigger size, I’d go for it. Looks like quite a floody (not much throw) headlight.
If you want the smallest possible 18650, go for the DQG.
Xenovora
I do very much mind the bigger size, but it’s a regulated drop in output, dependent on cooling ability (air temp, air flow, heat dissipation from other objects) and the smooth drop is mostly unnoticeable, I believe it will still be around 700-800 lumens after 10-15 mins on turbo according to reviews I read.
The timed step I can imagine being frustrated pausing what I’m doing to turn the light off and back on every minute literally… And I think they have nearly equal hot spot size and throw, but the spill is a lot more usable on the HC30. In fact, the HC30 might have more throw (177m on Nitecore site vs I thought I read the DQG having a mere 140m? I would buy the HC30W that just dropped rather than cool white, I heard the neutral option on the DQG is unpleasant and extremely warm yellow. (I have no warm lights, so to dive in the deep end to 3k rather than a small drop from 6k to 4.5-5k temp might leave me disappointed.)
PS. My experience on this forum started an hour ago and it is awesome!!! So active, replies flying left and right in minutes, CPF seems less popular at least in some forum categories lol.
wle
wle's picture
Last seen: 1 hour 14 min ago
no, if you click it once, it goes to low
no memory
if you click twice, med, 3 x – high
turbo from off is one long press
{answering question “does dqg tiny 18650 start on high?”}
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Serp
Serp's picture
some photos
plus of the battery is connected to the LED Thermo
Grieflar
Grieflar's picture
Got my DQG Tiny IV today….
Sad enough it looked horrible.
I submitted a ticket to seller, hope I atleast can get a refund…
Gotta love the Swedish postal service – $9 added to every package from China…
-X3-
-X3-'s picture
Last seen: 6 hours 18 min ago
I submitted a ticket to Gearbest, hope I atleast can get a refund…
You’re welcome
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
ReManG
II
http://i.imgur.com/23AEH84.jpg
http://i.imgur.com/48WpiMJ.jpg
http://i.imgur.com/TjDvHh9.jpg
http://i.imgur.com/ZRA8zCq.jpg
http://i.imgur.com/oeSk0Mb.jpg
http://i.imgur.com/nqEzxAa.jpg
What is so horrible on your light?
The different anodizing colors? That had been a thing since the first one…..
Edit: Saw the scratches now… Well that stinks, on the up side, it is broken in…
ALL of my links are non-affiliated for your pleasure...
My Reviews
Lithium Ion Battery Safety 101
Grieflar
Grieflar's picture
X3 wrote:
You’re welcome
What? Smile
ReManG wrote:
II
Yep. bad scratches and a couple of dents. Looks like its been rolling in a conveyor belt for a while Silly
Dutcheee
Mine’s got some comparable scratches. I bought a faulty DQG AAA in the past, at least this one works Big Smile
Still very much like the size, but quality in general sucks. With only slight scratches as an EDC for me it’s oke though..
Offcourse it should be flawless, good luk with aftermarket sales..
Will post my mod once done. Still need some work on the driver.
Serp
Serp's picture
Grey color have bad anodizing. They send me black for rewiew and it was OK.
ReManG
I have a grey from Banggood, and it was very nice anodizing, with the bit of color mismatch that is “normal” for DQG tiny it seems. No scratches or flaws like shown…
My Reviews
Firelight2
If you want long runtimes at max power, how about the Zebralight SC600w III HI
  • Build quality is superb both inside and out.
  • The light has no timed turbo stepdown.
  • Thermal stepdown is unnoticeable. The light will maintain near max brightness for the life of the battery.
  • Excellent output: over 1100 lumens
  • Wide flood, with excellent throw (19,000 lux)
  • Shorter than most other 1×18650 lights, which is important for pocket-carry. Still considerably larger than the DQG though.
  • Flawless build quality
  • Perfect tint
  • Great UI
In my opinion, the SC600w III HI is probably the best stock light I’ve ever owned. It’s so good that Vinh gave up on modifying one because none of his modifications made a significant difference on performance. About the only bad thing about Zebralights is they can’t be modded by most amateur modders.
vresto
vresto's picture
people,which driver will be fit into this flashlight? 3amps are not enough for me.i want change it.thanks
Serp
Serp's picture
about driver Smile
2000mA
Just look what they’re doing
it’s step down driver and 3th tiny
http://forum.fonarevka.ru/showthread.php?t=22959
But you need new bezel & bit process on a lathe head Smile
http://forum.fonarevka.ru/album.php?albumid=940
list this two pages
http://forum.fonarevka.ru/showthread.php?p=731180&highlight=%F2%F0%E8%EF...
http://forum.fonarevka.ru/showpost.php?p=731443&postcount=151
Dutcheee
Some more pictures over here in my DQG 4 triple mod thread:
DQG 4th 18650 tiny triple XPL Hi
Firelight2
Not sure exactly what size driver will fit in. It’s larger than 17mm. I think maybe 20mm.
HOWEVER… the biggest problems is that the original driver includes both the driver and emitter on the same board. This allows for the most compact light possible, but unfortunately doesn’t allow you to simply swap in a new driver. Any new driver you could buy won’t have the emitter on it, and there isn’t room to install a single-emitter star, the optic and a new separate driver board.
Essentially, if you want more power, the only option is to convert this light to a triple. The Carclo triple TIR optic is 7mm shallower than the stock TIR. This frees up enough space to mount a star in front of the driver.
Serp
Serp's picture
Dutcheee
Maybe use somewhat thinner glass. On mine (1mm x 21.3mm glass) it screws down all the way.
But nice, how’s the driver section working out?
Serp
Serp's picture
I’m reorder new glass (1mm)
Driver glued. I squeezed it with a screwdriver. But in the end broke the resistor R50.
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15196
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15201
Serp
Serp's picture
