Are these TrustFire Flame batteries any good?
I want some 14500 and 18650 Protected "TrustFire Flame" batteries. DinoDirect has a coupon for September 2011 that makes the following batteries reasonably affordable. (https://budgetlightforum.com/t/-/3825 "FREECASH")
14500A: http://www.dinodirect.com/TrustFire-Rechargeable-Li-ion-Battery-900mAh-TF14500.html
14500B Protected: http://www.dinodirect.com/TrustFire-Rechargeable-Li-ion-Battery-900mAh-Protected-TF14500.html
18650C Protected: http://www.dinodirect.com/trustfire-lithium-battery-18650-2400mah.html
18650D: http://www.dinodirect.com/TrustFire-Rechargeable-Li-ion-Battery-2400mAh-TF18650.html
Has anyone tested these recently (maybe in the last two months)? If so, are these TrustFire Flame batteries any good?
Thanks! :)
EDIT: I just noticed, only two of the four links are to batteries that are Protected, which is what I want.
I ordered some TF 14500 unprotected (A) along with a 2100 last week.
Will let you know how they compare with some protected ones I got from DX.
I can't recommend them.
you do can better for 18650's.
The 14500 's are okay but the quality can vary.
heres a dd review
Joseph Spengler Bought this item on 04-04-2011 20 DinoPoint gained for this post
Overall:
Other Thoughts:
Worth the price. They cost about 2x more than regular alkaline batteries, but last at least 4-5x longer. I've had a pair in a seldom used (about twice a month) Flip camcorder for over two years and every time I power it up, it's ready to go.
Do you think this is about the tf flames or some other battery..... hmmmm.... he used them in his camcorder. hmmmm......
and another
PROJECKTCHAOS Bought this item on 04-26-2011 20 DinoPoint gained for this post
Overall:
Other Thoughts:
I purchased these batteries for my fenix pd31 flashlight. They fit right and work pretty good. I recommend this product if your looking to save money, instead of buying regular ones over and over.
Didnt know the PD31 took 18650's???
PD 31
• Cree XP-G LED (R5) with a lifespan of 50,000 hours
• Uses two 3V CR123A batteries (Lithium)
• 120mm (Length) x24 mm (Diameter)
• the inner diameter of the tube is 18.8mm
might though its not listed like it is with other fenix lights
like
TK 21
• Cree XM-L LED with a lifespan of 50,000 hours
• Uses two 3V CR123A batteries (Lithium) or one 18650 rechargeable battery (Li-ion)
All I can say is the Trustfire Flame 18650 batteries I got have all been very good batteries and take and hold a charge very well.
I have the 14500 protected and for the price i got some good ones......there hit and miss with the quality but for the price you might just get a good set. Compared to AW's the TF's are a tad bit longer, so you might have problems screwing in the tail cap all the way.
I tested some TF flames a few weeks ago I bought on DX. I was not impressed. They came in at about 2200 mah... not bad but they did suffer from high internal resistance. I think the quality has dropped in the last few months. Someone also posted about not getting matching batteries.
However if your getting the 18650's $6.99 their probably worth it.
Sounds like a great deal for only 7 bucks .
Yeah... Ordered some 14500 - Great Price :) After using the Dino Points from the Last Fenix Order just 1.40$ left to pay
edc, I (mostly) agree with you, but I ordered the batteries anyway. :p By the way, I miss your Pinhead avatar; I didn't think that pic was all that disturbing.
I learned that the FREECASH coupon code can be used with every order over $5. If the items you want are less than $20, then create a separate order for each item and milk the freecash. If the individual items are over $20, there are a couple of 10% off coupon codes out there (CABIN10 and DINOGIFTCARD), but I didn't use them because everything I wanted was under $20.
I ordered some Flames- 3000mah in 18650 and the 900mah 14500's from FocalPrice. They may not have the best price but they ship pretty fast and they have Genuine Trustfire Batteries.
