Silicone Oil
21 posts / 0 new
alfreddajero
alfreddajero's picture
Last seen: 2 years 7 months ago
Silicone Oil
I really dont know what you guys and gals use to lube up your o-rings but i have a lot of this stuff from my rc days when i looked forward to racing at Debbies RC World.......it is Silicone shock oil and for me it does the job.  I can change the viscosity of the oil by going to a heavier weight by the number or go lower if need be.  This is a good way to keep a good supply of silicone oil around and know that you will always have an ample supply.  Check around for pricing at your local hobby shop.  A drop or two will keep your o-rings in good shape and calm that awful noise when you put the bezel or tail cap on.  And yes i have tried Silicone Grease but it just never lasts long, especially if the light got hot the grease would just be everywhere because the heat of the torch would cause it to thin out.  As of right now i am looking for those little bottles (the eye drop kind) that you can refill so i can share this stuff with others that either dont know where to get it, or using not so quality oil or grease.
Here's a good place to get this stuff.......they sell 2oz bottles, your wallet and torch will thank you for it.
http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=shock+oil&search=Go
With Darkness, there will always be Light.
Edited by: alfreddajero on 09/15/2011 - 21:35
shhh
shhh's picture
Last seen: 4 weeks 21 hours ago
I have always used synthetic rear end oil.
Got a pint of it from work and it works great for me.
kragmutt
What's rear end oil? Sounds dirty... =O
Budgeteer
Budgeteer's picture
Last seen: 6 years 10 months ago
LOL Kragmutt. Smile
I bought locally 100ml of sewing machine lubricant fro dirt cheap. I use that, also for a hair trimmer. Smile Silicone based for sure.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
SPAMBOT
SPAMBOT's picture
I use bisely silicone gun oil, deoxit and a special ptfe grease on my lights. Got some nextorch silicone grease in the mail, but have not tried it yet.
Now with 100% all natural asbestos!
the_moth
Last seen: 8 years 10 months ago
I use die-electric grease, the same stuff used used to seal out crud from car headlight plugs.  Good for lubing the threads too.  A cheaper die-electric grease might be the stuff used to aid the conduction in aluminum house wiring at the main panel....used between the aluminum wire and the copper bus bars.
alfreddajero
Always nice to see what others are using......
Don
Don's picture
Last seen: 3 years 3 months ago
Works for me. I got a cheap dispenser bottle from DX.
http://www.dealextreme.com/p/alcohol-and-liquid-container-dispensing-bot...
Use normal multigrade engine oil in it. Works for me.
If it doesn't, I use silicone grease or Copaslip (http://www.molyslip.co.uk/anti_sieze_compounds/) if the threads are really nasty and if I can find the tube. Which I bought in 1981. A little of the stuff goes a very long way.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
alfreddajero
Thanks buddy, now that is something that i need.......i noticed that with the Silicone Grease that when the light would warm up and get hot that the grease would just flow everywhere.......needed something better so i started using my rc shock oil for it and works so much better.
fishmaniac
fishmaniac's picture
Last seen: 5 years 8 months ago
I either use machine oil or honing oil on my threads and orings. I don't like using grease because it gets everywhere whenever I change batteries...lol Guess I'm a bit messy.
Rear end oil....hahaha.
alfreddajero
What about Duck Butter have you guys tried that lol.......i am bad huh.
shhh
shhh's picture
I see here people take what you type to the letter. lolLaughing
rear differential oil is what i was talking about. lol
gcbryan
I either use silicone lube from little tubes that came with camera equipment or dive equipment. You can also get a little dish of silicone grease at any dive store that will last you forever. It's the size of an Oreo Cookie.
Chicago X
Chicago X's picture
Last seen: 7 years 1 month ago
Please avoid using petroleum-based lubes on your O-rings, as it will cause them to degrade.
This means no machine oil, motor oil, or rear end lube (lol.)
While most dielectric greases are silicone-based, I would avoid their use as well.  Any transfer of DG from the threads to the unanodized portion of the body can affect light output.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
atbglenn
atbglenn's picture
Last seen: 1 year 1 month ago
I use this on everything
Boycott Nike
JohnnyMac
JohnnyMac's picture
Last seen: 2 months 2 days ago
Everything?? Your wife must hate you. ROFL!
Sorry, couldn't resist. Silly
the_moth
You are correct, I typed before thinking.  The grease used for aluminum house wiring is anti-ox, a conducive "compound" and a bout $3-$5 a tube.
alfreddajero
So where can one get some of that GB tube......would not mind giving it a try.
atbglenn
atbglenn's picture
Sorry, couldn't resist. :P
lol! except I'm not married. Maybe that's the reason!
Boycott Nike
s1mp13m4n
s1mp13m4n's picture
I am using this on my lights.....not knowing what I should be using to lube my lights.
Amsoil Grease
Lights seen from the blind side
Don
Don's picture
Amsoil Grease
It'll be fine. These days I'm using engine oil dispensed from a syringe with a filling cannula attached to it - but I work in a hospital where such stuff is easy to get hold of.
