Test/Review of Nitecore 14500 NL147 750mAh (Black-yellow)
Official specifications:
  • Battery Capacity: 750 mAh
  • Battery Rated Voltage: 3.7 V
  • Charge current: Maximum 750mA (350mA recommended)
  • Maximum output current: 3.5A
  • Cycle count: >500 times
  • Diameter: 14.2mm
  • Length:51.5mm
  • Width 20.6g
A protected button top AA sized LiIon cell from Nitecore.
Fairly good tracking between the two cells, this is a high capacity cells and not a high current cell.
Conclusion
This cell is at best average in performance, voltage when loaded is on the low side, even for a high capacity cell and capacity is also a bit low for a high capacity cell.
Notes and links
Comparison to other LiIon batteries
I have a couple of these, confirms my thoughts, thanks HKJ
