Three Oslons tested: 1) latest gen. Oslon Black Flat 2) SSL80 4000K 92CRI latest gen. 3) SSL80 4500K 96CRI 1 gen. before latest
134 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 7 hours 51 min ago
djozz? Only 600 lumens per Black Flat? Conservative isn’t it? Reckon I’ll find out, should have the emitters here by end of week and the Sofirn Q8 is en-route… as are new boards from Neven. Of course, the original MCPCB should work fine here…
djozz
djozz's picture
Last seen: 10 hours 37 min ago
DB Custom wrote:
If the grounded thermal pad is the only drawback, that can be dealt with. I have Arctic Alumina Thermal Adhesive to make a “mask” between the emitter shelf and MCPCB, I can make polycarbonate screws if need be to ensure the MCPCB doesn’t ground through the mounts. Or I can get ceramic screws. Or nylon ones, whatever. Don’t even need the screws if the MCPCB is glued down in the first place…
If during curing of the thermal glue you connect led+ on the ledboard and the Q8 housing to a small power source (I use a led-tester for that), the Black Flats will light up if you have a short between ledboard and housing, so you still have time to correct before the glue is hardened.
DB Custom
DB Custom's picture
The only danger even if the thermal pad grounds out is not having modes, same as shorting the negative lead, so it’s not really that big a deal overall anyway. Thanks though, I know to take precaution so it should work out all right. Thinking about using a similar light and putting 9 of em in. Big Smile
I like the Arctic Alumina Thermal Adhesive because it can be removed through application of heat. Wink
Texas_Ace
Texas_Ace's picture
Last seen: 12 hours 14 min ago
Is the center pad just connected to ground? seems like there was too it then that, although I have not looked into it that close.
DB Custom
DB Custom's picture
The negative pad and thermal pad are connected.
LichtAn
Last seen: 2 months 6 days ago
What are your thoughts on this? http://www.thermal-grizzly.com/en/products/13-minus-pad-8-en
I already posted this in another thread. I bought a 0.5mm sheet of this and will be testing it in a Tool AA with an Oslon. You think it’s too thick for good thermal contact? I think with a screwed down MCPCB it should become very thin, as it’s very elastic. At least it has the same thermal conductivity as Arctic Silver 5.
Texas_Ace
Texas_Ace's picture
LichtAn wrote:
What are your thoughts on this? http://www.thermal-grizzly.com/en/products/13-minus-pad-8-en I already posted this in another thread. I bought a 0.5mm sheet of this and will be testing it in a Tool AA with an Oslon. You think it’s too thick for good thermal contact? I think with a screwed down MCPCB it should become very thin, as it’s very elastic. At least it has the same thermal conductivity as Arctic Silver 5.
I would not want to use that under the mcpcb, it has horrible thermal properties compared to thermal paste.
LichtAn
You think the layer stays too thick? Because Artic Silver 5 is 9,0 W/mK and this is 8 W/mK. Don’t mix this up with the crap they put under cheapo heatsinks. Just by the description, this is some next level thermal pad. Big Smile Thumbs Up
Edit: They go up to >30 W/mK but really cost an arm and a leg.
Edit2: http://forum.notebookreview.com/threads/thermal-paste-roundup-performance-price-recommendations-update-thermal-pads.796820/ OK maybe they still suck. Sad
Texas_Ace
Texas_Ace's picture
I have seen the new carbon nanotube thermal pads that are promising, is that what this is? In the picture it looks like the normal silicone based thermal pad.
In which case you are correct, they are almost always way too thick. It says the thinnest version is 0.5mm thick for example. Most thermal paste would be a fraction of that.
Enderman
Enderman's picture
Last seen: 41 min 4 sec ago
Graphene thermal pads are conductive.
Those only work well when surfaces are very flat and parallel, they perform similarly to thermal paste.
These pads are not that, it is some different custom materials, much better than just regular silicon thermal pads.
They are also pretty expensive, more W/mk = more cost.
If you need to apply a layer of thermal adhesive that is insulating you need to use some sort of spacer like a piece of electrical tape on an edge in order to keep the two surfaces apart while the epoxy dries.
A piece of electrical tape will be like .2mm or so.
Using these high performance thermal pads will still be decent for a low wattage LED like the black flat, especially since the pad compresses, only problem is that you still need to secure the PCB down somehow without using screws that will create a conductive path.
LichtAn
Anodized screws maybe? May get problematic when the anodizing wears off.
I just realized there are even screws completely made from plastic, well…
Enderman
Enderman's picture
Yeah, or ceramic screws which are super expensive.
Another way is to use some sort of hold-down plate with screws outside the MCPCB area.
The easiest way is to use thermal epoxy and just remove the screws once it is dry.
eas
eas's picture
Last seen: 5 hours 49 min ago
Small insulating fiber washers + insulated sleeves work for other applications. There is no reason they shouldn’t work to insulate screws from an MCPCB.
DB Custom
DB Custom's picture
How do you keep the threaded shaft of the screw from contacting the MCPCB inside the hole? The walls of the screw hole? Easiest to use a non-conductive screw. Or none at all.
eas
eas's picture
“+ insulated sleeves”
Better if insulated washer and sleeve are one unit, but probably hard to find.
Jerommel
Jerommel's picture
Last seen: 5 min 4 sec ago
…or get some Laird thermal sheet stuff.
Various thicknesses available.
2Q19
DB Custom
DB Custom's picture
I tried putting the Black Flat in a Shooter 2X today. The driver I had in it is an original MaxToch Buck driver for 2 cells at 6A. Poof! went my little jewel. So I heated up the 32mm Noctigon, inside the light, (difficult!) and removed the fried one to put a new one in it’s place. Worked fine in testing, was in the light with the 32mm board glued with Arctic Alumina Thermal Adhesive. I reduced the output of the driver to 4.22A pushing an old XM-L T6 on a test board with 2 18350 cells. Got it back together and working, tested 424Kcd in the 2X, but wanted to try a centering ring to see if I could dial in focus. Centering ring ripped off the emitter. UGH! Managed to remove the 32mm MCPCB and clean it up, re-flow the emitter properly and it worked fine on my bench. Put the light back together with new thermal adhesive, everything checked out fine, assembled it, fired it up…. pooof! goes a second little jewel. Facepalm
clemence
clemence's picture
Last seen: 1 day 16 hours ago
To insulate the non isolated board I use this method successfully:
- Non conductive thermal paste, I use Arctic MX-4
- Lapped he MCPCB on #320 grit SiC to give some grittiness to the base of the MCPCB. Too shiny and most of the thermal paste will squeezed off the base.
- Apply thin MX-4 to the base of the MCPCB.
- Sprinkle the pasted MCPCB with #320 grit SiC powder. SiC is a relatively good conductor at 20W/MK and a very effective insulator. Much better than AlO3. This SiC powder serves as the thickness guide and separator while still provide decent thermal conductivity in between the paste. The same technique is used by some manufacturers by adding micro glass beads to their TIM.
- Gently, blow the excess powder.
- Place it on the heatsink. Move it SLOWLY in XY direction while firmly press on it. Make sure you spread the paste and SiC powder well.
- I use PEEK screws to fasten the MCPCB. It’s a very strong plastic screw with service temp up to 270C. It’s not cheap but still far below ceramic screws.
Note:
SiC powder is extremely cheap. I got mine for $3 for 1 kg, last for years. If you don’t have some, you can get some by soaking abrasive paper in the warm gasoline.
PEEK screws are available through online stores such as Ebay, Aliexpress. I paid $50 for 25pcs (M3 × 5)
MX-4 on the other hand is relatively expensive but works extremely well. Also very easy to apply. It’s rated at 8,5W/MK I guess.
- Clemence
luminarium iaculator
luminarium iaculator's picture
Last seen: 8 min 58 sec ago
I really like your story… Weird things happened to me before and they will probably happen again. Weird things like driver fail after I tested it, emitter burnout without any special reason driven on low current draw, shortcuts when reflector managed to peel 2 layers of kapton tape, UFO specks of dirt on emitter etc.
Plenty of weird things can happen… Maybe because of that some of us like modding stuff?
Oh! Another good one… Once I mixed to much flux into solder paste(some guys were giving this kind of advice for soldering paste refreshment Smile ) – I tried that same paste for reflowing emitter – I had put emitter on top of that, reflowing started and puff! Emitter flew away over whole room and of course it did not survived. Beer
clemence
clemence's picture
I also had that flying LED moments with my home brewed solder paste. If the flux you’re using is too thin and has low boiling point, it will pops the LED off the board. Slow heating can prevent this. But the better fix is to use proper tacky honey like consistency flux.
- Clemence
led4power
led4power's picture
Last seen: 17 hours 28 min ago
Moisture in flux is cause, it starts to boil over 100C and expand rapidly > parts flying.
-X3-
-X3-'s picture
Last seen: 4 days 11 hours ago
Is it bad that I still don’t use flux to reflow LEDs after all that years of modding ?
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
DB Custom
DB Custom's picture
I don’t use flux for anything I do X3, I mean, I use flux core solder from Kester and good Kester solder paste, but never put additional flux on anything.
I found that flux is must especially for nice and shiny solder joints. Also used without flux several years ago… I use dense honey like flux for driver to pill soldering and classic not so dense for wire soldering. Premium quality flux from Topnik, and I also use premium stuff Stanoll Sn60Pb39CU1 recently used with some Osram leds and it works perfect, and it looks solid and shiny. But of course I will never use flux with solder paste Smile When solder paste drys it goes straight to the junk… Btw I use that mechanic solder paste cause I can’t get any better than that. I use needle injecting package.
DB Custom
DB Custom's picture
I tried the Mechanics a long time ago and it was just too thick, too dry. The Kester solder paste in a syringe flows so smooth and easy, love it!
I don’t care about a shiny solder joint, it’s going to be inside the light anyway! Silly I have plenty of other things to be OCD about. lol At least I never have to wash a board, or otherwise clean it. Well, once in a great while if a light is giving trouble and it has to be soldered several times in the overall process it can get kind of messy and then I’ll clean the board up. Building drivers, and I’ve built hundreds, I just don’t usually find a need to clean em up. I use solder paste masks and it leaves a nice neat finished driver.
I would like to try that Koester solder paste but on ebay cheapest solution is 43$ S&H to Europe(plus potential 20% of customs tax on that Smile ), and yes mechanic solder paste is thick and it drys fast if left exposed. It does not look like premium stuff at all… That needle mechanic package is a bit better than box one which will dry a lot faster because of packing itself…
Yes sometimes after fluxing something washout is necessary(like driver to pill). But it is easy. Just few drops of isoproprly alcohol and compressed air resolves that in a second with one good blow.
But flux applicator(like flux pen for example) is also important. If it can put thin layer of flux than no cleaning will be necessary. For wires soldering for example. I like thicker layer of flux for driver to pill soldering, and for that I use thin brush applicator.
Yes… I need premium solder paste in arsenal so I could compare it to mechanic sp and see the difference.
-X3-
-X3-'s picture
Ok… but I also find that I don’t need solder paste for reflow.
I just use soldering wire Glasses
X3 wrote:
Ok… but I also find that I don’t need solder paste for reflow. I just use soldering wire Glasses
Which solder wire?
-X3-
-X3-'s picture
luminarium iaculator wrote:
Which solder wire?
Generic chinese one from a long time ago…
It says “xinfa gao ji han xi zhi pin” Party
Ok… I’ll try to believe you Beer It can be done with a lot more heat than with solder paste and with low melting point solder wire. My personal opinion that solder paste will be less stressful for emitter.
