A first look at the BLF/Kronos Limited Edition X6/X5 SS & Cu Boxd Set
44 posts / 0 new
JohnnyMac
JohnnyMac's picture
This morning the DHL truck stopped by with an early surprise for me.  W00T!!
Here is what was inside...a box!
Not just any box, but a BLF/Kronos Limited Edition box!
And inside the box was this!
Inside the fitted, velvet-over-foam lining are two accessory bags, a SS & Cu X6, and an entirely new light, the X5 in all copper.
A closer look at the lights.  Batteries (18650 & 14500) do not come with the lights.  I couldn't wait to bask in the blue glow of the lighted tail caps.  The engraving on these lights is absolutely amazing!
Another view?  Sure!  I'm in a lots of angles and views mood right now.
How about one from the other side?
A better look at the lights.  This is a limited run of only 400 sets with matching serial numbers.  Only 250 of those sets have matching serialized boxes.  The remainder of the 400 sets (250-400) are sold with the box optional and sold separately.
Each light has two flats on the battery tube.  One has the KRONOS logo and serial number.
The other side is engraved with "BLF Limited Edition".
The engraving is clean and deep.
In person these lights look more like they were minted rather than engraved.
Each light has it's own accessory bag included.  The accessories for each light include a stainless steel pocket clip with engraved model name, a spare O-ring, two spare switch boots (one black, just in case you don't like awesome backlit tail caps, and one clear in case you should need a replacement), and a lanyard with quick-release snap buckle.
The business end of each of these beauties starts with a solid copper, unibody pill/head, a thick, copper DTP MCPCB, Cree XP-L HI LED in choice of 1A or 3B tint bins, SMO reflector (The X6 model's reflector actually threads into the head and focus can be easily fine tuned), and finally, it's all capped with an ultraclear AR coated lens.
The reflector sits over the perfectly centered XP-L HI emitter without the use of any centering rings.  This allows the reflector to sit directly onto the MCPCB for a nice, tight hotspot and smooth spill.
Ahh...my favorite pic from this post.  This is a peek in at the X6 LED when the light is in Moon Low mode.  Mmmm...sexy... BRB.
OK...back and ready for a look at the first of it's kind in any production light - an LED backlit tail switch.
"BS", you say?  "Seen these tons of times on other lights", you say?  No you haven't.  This is not an electronic switch, which is where you've seen lighted switches before on plenty of other lights.  This is a mechanical Omten switch (reverse-clicky) and, thanks to the most innovative bunch of folks on BLF (budgetlightforum) who regularly figure out how to do things others thought only imaginable, this one contains an SMD LED and resistor on the switch PCB that makes the tail cap glow when the flashlight is off.  This is more visible than any tritium vials and draws less parasitic energy than many lights with unlit electronic side switches.  Want it brighter?  There is an empty set of pads for an additional SMD LED.  Want it to glow barely enough to see at all in pitch black?  Switch the resistor with one with higher resistance.
Now to the limited edition box.  Where to begin with this little beauty?  Look at it.  Just LOOK at it!  It looks like a fine humidor or jewelry box.  It is made of white birch, stained a warm honey color, and covered with what looks like LOTS of lacquer.
The first thing you notice, once your eyes adjust from the blinding they took from your lights reflecting off that shiny lacquer exterior, is the laser engraved "BLF Limited Edition" on the lid of the box.
The next thing you might notice is the "KRONOS" logo with matching serial number engraved into the front corner of the lid edge.  Only the first 250 sets will include a box with matching serial number.  Numbers 251 thru 400 are sold without the box but the box (same exact box but no serial number) will be available for..are you ready for this?  $11 USD.  ELEVEN DOLLARS!!!  How the heck can they do this?  I don't care.  I'm just thrilled they can.
Look at the joints at the corners.  Perfect.  No gaps, no wood filler, nothing.  Just perfectly mitered corners.  Amazing!
Here's another corner.  Same deal here, too.  See that faint circle on the edge there?  That is where one of the two lower magnets are located.  The lid has two more to match these.  All 4 magnets are covered with wood plugs to make them nearly invisible.  They are installed prior to the thick clear coating getting applied.  The lid holds tight enough that you can pick the box up by the lid and it won't pop open on me even when full of these monster lights with cells installed.
Sweet cabinet hinges are used here.  No cheap jewelry hinges that are two flaps with a center pin hinge joint and nailed into the back of the lid.  These are hidden, routered hinges that are counter sunk and have a built in stops to keep the lid from opening too far or falling closed while you are accessing the beauties inside.  My expensive humidor has hinges like this.
The base is completely covered with a swatch of felt to protect your desk top or fine furniture from getting scratched whilst displaying this fine set.  I'm going to say it again...$11 dollars.  E L E V E N  D O L L A R S ! !  WHAT???
So, what haven't I covered?  Actually quite a few points that need to be noted.  I'll sum them up in a bulleted list.
  • Availability: Only from Banggood.com but completely sold out.
    • Aluminum sets are still available at this time for $50 USD.
  • Price:  $85 USD + $11 USD for box.  Free shipping.  No joke.  Where were you when there was still space in the reservation list?
  • Construction
    • X6 - Stainless steel and Copper.
    • X5 - Pure Copper
  • Batteries
    • X6 - 18650 (IMR recommended for maximum output)
    • X5 - 14500 (IMR recommended for maximum output)
  • LED: Cree XP-L HI in 1A or 3B tints
  • Lens:  Double-sided AR coated Ultraclear glass
  • Reflector: SMO (X6 reflector is threaded and focusable)
  • Driver:
    • Voltage range: 2.5V-4.3V
    • BLF developed ATTiny25 FET+1
    • ToyKeeper's Bistro firmware
    • Programmable mode memory (On or Off)
    • Programmable thermal stepdown (can be turned off)
    • Hidden Modes
    • Voltage reading (whole plus tenths)
    • Programmable mode groups
  • Output:  DD in Turbo. 1250-1300 OTF for X6 and 1100-1200 for X5 have been measured.  Output depends on quality of cell used.  I will be doing full testing in the next couple days.
  • Switch type: Back-lit mechanical reverse-clicky
  • Waterproof:  Yes
User Interface:
    • While Off:
      • Fully click and release to turn the light on.  It will go to the first mode or the last-used mode, depending on whether you enabled mode memory.
    • While On:
      • Short tap: Do a short (less than 0.5s) half-press to go forward to the next mode.
      • Med tap: Do a medium (0.5s to 1.5s) half-press to go backward to the previous mode, if medium-press is enabled.
      • Long tap: Do a long (longer than 1.5s) half-press to reset to the first mode (if mode memory is turned off).
      • Or fully click and release to turn the light off.
      • Short tap a bunch of times (15+ taps, or until the light stops turning on) to enter config mode.
    • Hidden modes:
      • Go backward from moon to access the hidden modes.  They are, in order:
        • Turbo (just like the regular turbo)
        • Tactical / police strobe (7 Hz / 14 Hz alternating)
        • Battery check / beacon mode
          • It should blink out the voltage in whole numbers then a '.' then tenths.  So, for 3.6V it would blink out "--- . ------".
          •  Voltage range is from about 2.5V to 4.4V
        • Biking flasher (2-level stutter beacon, 1 Hz)
    • Configuration options:
      • The config mode has several options.  It will blink out a number to show which option is active, then "buzz" or "stutter" for a bit.  Click during the "buzz" to select that option.  Some options may enter a secondary config mode after the light turns back on.
      • Options include:
        • 1. Muggle mode / simple mode.  Good while lending the light to others.  It overrides other config settings temporarily:
          • - low/med/high, in that order, with high at about half power.
          • - no moon, no memory, no medium-presses, no hidden modes
          • - the only config option is the option to exit muggle mode
        • 2. Mode memory.  Off or on.
        • 3. Moon.  Select to turn moon mode on or off.  This is in addition to the other regular modes, so you get 2 to 9 levels when moon is enabled.
        • 4. Mode order.  Low to high, or high to low.
        • 5. Mode group.  Choice of 1 to 8 regular modes from low to turbo.
          • After clicking, the light should come on in a special group-select mode.  In this mode, it slowly blinks 8 times, pauses, then repeats.  Turn the light off after N blinks to select mode group N.  The number of levels in each group is equal to the group number, and all levels within are          evenly-spaced.
          • Example: To select low-med-high, let it blink three times then click the button.
        • 6. Medium-press.  Off or on.  If on, a medium-press will allow going backward through the mode sequence, and hidden blinky modes will be accessible.
        • 7. Thermal calibration.  Set the temperature at which the light will begin stepping down to cool itself off.  After clicking to select this, the light should turn on in a special thermal calibration mode.  It will start at a medium-low brightness, wait a second or two, then step up to turbo.
          • - To turn off thermal regulation, click within the first second (while the output is relatively low).
          • - To set a new maximum temperature, leave the light on until you think it is too hot, then turn it off.  From this point on, the light will use that new temperature as its maximum allowed heat.
          • Note that there may be a delay between when you feel the heat and when the MCU feels the heat, so the value saved may be a little bit lower than expected.
        • 8. Factory reset.  Change all settings back to default.
Parting Thoughts...
I am blessed to be a part of the design team who made this light happen.  Am I a touch biased about these lights?  Possibly.  I will say that they are arguably the highest quality, highest performing production flashlights in their classes.  There is nothing on the market similar to them, both as a whole, or their individual features - Customizable drivers, massive output, one-of-a-kind tail caps, production hosts the likes of which were previously only available as one-off uber expensive customs...  The price.  What can you say about the price?  You can say it's insanely cheap and you'd be right.  Anyone who hesitated or debated in getting in on this limited set should be kicking themselves for missing out. The entire set with box for just $96 out the door. WOW!
I'll close this out with a parting shot of the lights.
Still kicking yourself for missing out?  Learn from your mistakes.  Team 'Kronos' has only begun and there is much, much more awesomeness in the works down the line.  Stay tuned and don't hesitate next time!
Cheers,
Johnny
Edited by: JohnnyMac on 01/26/2016 - 03:17
Wrathbringer27
Wrathbringer27's picture
Last seen: 5 hours 13 min ago
Awesome review! Can’t wait to get mine already!!!
Words can be broken,
so can bones.
HighCaliber
Last seen: 2 hours 17 min ago
I have to say that I will be a Team Kronos consumer for life. What a beautiful set of groundbreaking lights.
I can't wait to get off of work tomorrow, rush home and see what DHL has left me. Thanks for the show and thanks to all who input the time, effort and imagination into this Team Kronos' project.
keengeorge
Last seen: 1 week 3 days ago
LoveLoveLoveLoveLoveLove
zoom zoom
Last seen: 11 months 1 week ago
Wonderful review! Looks like a really nice set! Can't wait for mine!
saypat
saypat's picture
Last seen: 2 hours 20 min ago
Is that the actual interface for these lights??? That is different than the UI for the A6. I thought I heard the updated firmware wasn’t installed? Is there firmware above this one? This one is fantastic!
unknown00101
Last seen: 4 days 13 hours ago
Blessed be thy DHL courier... please deliver unto me this ridiculously beautiful pair of flashlights post haste.
JohnnyMac
JohnnyMac's picture
saypat wrote:
Is that the actual interface for these lights??? That is different than the UI for the A6. I thought I heard the updated firmware wasn't installed? Is there firmware above this one? This one is fantastic!
Yup.  It's identical to the final Bistro version that didn't make it into production in time EXCEPT for a bit of fine tuning to the voltage measurement feature that corrected the 1/10v error in measurement.
leroycp
Last seen: 3 hours 46 min ago
Superb!!!
HereAgainAgain
Last seen: 1 year 8 months ago
Wow. Awesome.
1dash1
1dash1's picture
Last seen: 2 years 4 weeks ago
Beautiful pictures. Lots of important information for readers to absorb.
And here’s some output readings from Dale, for those who may have missed them:
DB Custom (from Post No. 4205 of the Group Buy Discussion) wrote:
Straight out of the beautiful box…
SS/Cu X6 with Efest Purple 3000mAh 18650 @ 4.16V rested
5.29A for 1259.25 Lumens
2.29A for 659.99
1.00A for 337.76
0.43A for 163.88
0.15A for 49.96
0.04A for 4.62
0.02A for 0.276
Lux 52Kcd for 456M Throw
Cu X5 with Red AW IMR14500 @ 4.21V rested
4.16A for 1100.55 Lumens
2.10A for 607.89
1.05A for 336.38
0.46A for 163.19
0.15A for 49.16
0.03A for 5.04
0.01A for 0.3795
Lux 28Kcd for 334.66M Throw
Rule 1-1 as it applies to life, take it as it comes.
leroycp
Just got notified mine will be here tomorrow! Talk about FAST! YEA!
Rufusbduck
Rufusbduck's picture
Last seen: 9 months 2 weeks ago
Time for yet another MtnE order for cells! Sweet set, glad it arrived safe and sound.
Scott
JohnnyMac
JohnnyMac's picture
1dash1 wrote:
Beautiful pictures. Lots of important information for readers to absorb. And here's some output readings from Dale, for those who may have missed them:
Straight out of the beautiful box… *SS/Cu X6* with Efest Purple 3000mAh 18650 @ 4.16V rested 5.29A for 1259.25 Lumens 2.29A for 659.99 1.00A for 337.76 0.43A for 163.88 0.15A for 49.96 0.04A for 4.62 0.02A for 0.276 Lux 52Kcd for 456M Throw *Cu X5* with Red AW IMR14500 @ 4.21V rested 4.16A for 1100.55 Lumens 2.10A for 607.89 1.05A for 336.38 0.46A for 163.19 0.15A for 49.16 0.03A for 5.04 0.01A for 0.3795 Lux 28Kcd for 334.66M Throw
Really?  He was getting between 1400 & 1500 in the prototype samples, IIRC.  Tomorrow night I'll set up my IS and see what numbers I get.  In the mean time, I'll change the numbers in the OP.
bugsy36
bugsy36's picture
Last seen: 9 months 18 hours ago
I think Dale's sample numbers were after just doing a spring bypass.
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
unknown00101
My prayers have been answered! I received the same notification.
2 day shipping if they make it by the estimated day. Freakin' DHL YEAH! Yell
archimedes
archimedes's picture
Last seen: 3 days 3 min ago
Oh, you lucky guy. Love This light is absolutely strong and beautiful.
Even if my three sets were sent out, it will probably take a few more weeks to arrive in Switzerland.
But anticipation is half the fun.
About one thing I am particularly pleased:
I was, thank God, there in time. :bigsmile:
MRsDNF
MRsDNF's picture
Last seen: 4 hours 37 min ago
Smile
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
Charga
Charga's picture
Last seen: 2 hours 7 min ago
Curious about beamshots!! Wink
' Lumen est omen '
Hope is no option!
bugsy36
bugsy36's picture
In the original X6/X5 thread...look at post 4213 by Dale
kronological
kronological's picture
Last seen: 7 months 6 days ago
Fantastic pics and review, JMac! My set is due in tomorrow, and I’m even more excited! Smile
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
bugsy
Last seen: 1 year 11 months ago
The copper X5… hnnnng J)
pilotdog68
pilotdog68's picture
Last seen: 1 week 4 days ago
That AR lens looks much better than the usual cheap AR.
cbrake10
Last seen: 10 months 2 weeks ago
Awesome overview JM! It makes me even more anxious for mine to get here haha.
Thanks to everyone involved in the design and production of these. Its a truly phenomenal achievement.
-Clark
UliBär
UliBär's picture
Last seen: 17 hours 2 min ago
Waaaaaaaaah!!
You are torturing me big time! LoveLoveLove
Now it is even harder to wait for the lights to arrive here in Germany!
Unfortunately the lights will for sure fritter away another week or two at our snail-customs for clearance… :_( :_( :_(
Aloha, Uli
Coolcat2005dj
Last seen: 11 months 22 hours ago
Insanely beautiful lights. I wish i had joined before this forum. Lucky you guys Smile
Doesnt matter i already ordered SS under Astrolux brand. Big Smile
THanks for the review friend.
Does anyone know any thread with Run times and lumens charts?? big help.
LSX
LSX's picture
Last seen: 17 hours 47 min ago
Seeing this makes me soo annoyed that my order was completely stuffed up by banggood. They look soo good with their matching numbers in the nice box.
From 19 and 150 on the original reserve list with boxes to no boxes, no matching numbers and random serial numbers towards the 400 range.
JohnnyMac
JohnnyMac's picture
I’m really sorry to hear that, buddy. Yeah, BG really banged a lot of people good by not informing their warehouse how these should have been shipped. What a freaking nightmare that whole deal was for us. SUCH a headache. Sad
LSX
LSX's picture
It’s all good now. The lights themselves are fantastic. Just would have been that extra bit nice to get the full set.
MRsDNF
MRsDNF's picture
If your trying to make me feel guilty its working. Facepalm
justanotherguy
Last seen: 5 hours 14 sec ago
I traded my # matching boxed set for a pair of unmatched lights, which I use every day
