I am still confused.
I get that industrial Red brass is also an alternative name for copper alloy C23000,
and from wiki copper
Mechanical properties of common copper alloys[2] Name Nominal composition (percentages) Form and condition Yield strength (0.2% offset, ksi) Tensile strength (ksi) Elongation in 2 inches (percent) Hardness (Brinell scale) Comments
Copper (ASTM B1, B2, B3, B152, B124, R133) Cu 99.9 Annealed 10 32 45 42 Electrical equipment, roofing, screens
Gilding metal (ASTM B36) Cu 95.0, Zn 5.0 Cold-rolled 50 56 5 114 Coins, bullet jackets
Cartridge brass (ASTM B14, B19, B36, B134, B135) Cu 70.0, Zn 30.0 Cold-rolled 63 76 8 155 Good for cold-working; radiators, hardware, electrical, drawn cartridge cases.
Phosphor bronze (ASTM B103, B139, B159) Cu 89.75, Sn 10.0, P 0.25 Spring temper — 122 4 241 High fatigue-strength and spring qualities
Yellow or High brass (ASTM B36, B134, B135) Cu 65.0, Zn 35.0 Annealed 18 48 60 55 Good corrosion resistance
Manganese bronze (ASTM 138) Cu 58.5, Zn 39.2, Fe 1.0, Sn 1.0, Mn 0.3 Annealed 30 60 30 95 Forgings
Naval brass (ASTM B21) Cu 60.0, Zn 39.25, Sn 0.75 Annealed 22 56 40 90 Resistance to salt corrosion
Muntz metal (ASTM B111) Cu 60.0, Zn 40.0 Annealed 20 54 45 80 Condensor tubes
Aluminium bronze (ASTM B169 alloy A, B124, B150) Cu 92.0, Al 8.0 Annealed 25 70 60 80 —
Beryllium copper (ASTM B194, B196, B197) Cu 97.75, Be 2.0, Co or Ni 0.25 Annealed, solution-treated 32 70 45 B60 (Rockwell) Electrical, valves, pumps, oilfield tools, aerospace landing gears, robotic welding, mold making [3]
Free-cutting brass Cu 62.0, Zn 35.5, Pb 2.5 Cold-drawn 44 70 18 B80 (Rockwell) Screws, nuts, gears, keys
Nickel silver (ASTM B122) Cu 65.0, Zn 17.0, Ni 18.0 Annealed 25 58 40 70 Hardware
Nickel silver (ASTM B149) Cu 76.5, Ni 12.5, Pb 9.0, Sn 2.0 Cast 18 35 15 55 Easy to machine; ornaments, plumbing [4]
Cupronickel (ASTM B111, B171) Cu 88.35, Ni 10.0, Fe 1.25, Mn 0.4 Annealed 22 44 45 – Condensor, salt-water pipes
Cupronickel Cu 70.0, Ni 30.0 Wrought – – – – Heat-exchange equipment, valves
Ounce metal[5] Copper Alloy C83600 (also known as “Red brass” or “composition metal”) (ASTM B62) Cu 85.0, Zn 5.0, Pb 5.0, Sn 5.0 Cast 17 37 25 60 —
Gunmetal (known as “red brass” in US) Varies Cu 80-90, Zn <5, Sn ~10, +other elements@ <1
But for non metallurgists it is really confusing/misleading to call bronze/brass copper and vicea versa so please Chinese STOP it.
End of rant
