I received the New (upgraded) Version Thorfire PF04 for review from Thorfire.
I found this to be another great example from Thorfire, with good build quality and good performance from such a small package. I forgot to mention in the video it has intelligent step down at 3 minutes to medium mode. This is an amazingly bright light for the compact size of it. These lights also have a potted driver so the usual drop of the light wont make it stop working as a lot of them do from being dropped.
Everything else is in the video review pretty much but I would like to say, IF you attempt to take the driver out of this light and reinstall it you will have to use some finesse as it is glued or thread locked in so be aware of that.
Video , link and description below…….
Very compact and lightweight pen sized flashlight for indoor outdoor everyday carry.
• Extremely bright for this size: CREE XP-G2 R5 LED gives out MAX 210LM
• 3 modes: Moonlight-Mid-High with memory, step down from High to Low in 3 min to save juice.
• IPX-8 waterproof, submersible up to 2m. Not for diving.
• What You Get: ThorFire PF04 flashlight, spare O ring.18-month warranty and friendly customer service
Product Description
Pattern Name: PF04 Upgraded version
Notice: We updated the PF04 penlight , specific adjustment is as follows
More reasonable modes: Moonlight - Mid - High with memory.
Intelligent step-down: It automatically step down from High to Low in 3 Min to save power and for longer lifespan. You can tap to go back to High.
Descriptions:
As the latest mini LED flashlight, ThorFire PF04 Flashlight is designed to provide you with a smaller size yet brighter night working experience.
Rigid Appearance
This flashlight is designed with corrosion resistant aircraft grade aluminum alloy material, which is only 24.5g in weight but solid enough in any harsh environment.
Brighter Illumination
With an improved reflecting technology, this new product is capable of outputting a maximum 210 lumens brightness along with a 55 minutes using time by only 2 AAA batteries(NOT Included).
In addition, the lighting time can last to 240 hours under its lowest illumination.
Portability
This product is only 5 inches long, which means lesser space occupancy and more flexible placement choices. You can simple clip it onto your pocket, bags, notebook or anywhere you want.
NOTE:
The highly intensified light may do severe harm to your eyes, thus, please avoid direct eye contact.
